HBL4720C
HBL4720C
    HUBBELL(哈伯尔公司)
HBL4720C 数据手册
Twist-Lock® Devices 15A, 125V, 2 Pole, 3 Wire Grounding Insulgrip® Plug Features Individually molded face for each blade configuration Roomy wiring chamber provides ample space for wiring Ribbed nylon housing provides a secure grip that’s impact and chemical resistant Ordering Information Description Insulgrip® plug, black and white nylon.Multiple drive screws Cord Diameter .230"-.720" (5.8-18.3) UPC 783585171159 Catalog Number HBL4720C Listings Listed to UL 498 Fed.Spec. W-C-596 Certified to CSA C22.2 No.42 Specifications Housing / Cord Clamp Terminal Retainer Blades Terminal Screws Terminal Clamp Assembly Screws Nylon Clear polycarbonate Brass #8-32 Brass (Phillips / Slotted / Robertson) Cold rolled steel – nickel plated Steel - nickel plated Performance Electrical Current Interrupting Dielectric Voltage Certified for current interrupting at full rated current Withstands 2,000V minimum Mechanical Terminal Accommodation #16 AWG - #8 AWG stranded copper wire only. Accessories Terminal Identification Terminals identified in accordance with UL 498 Environmental Flammability Moisture Resistance Operating Temperatures HB or better per UL94 or CSA 22.2 No. 0.6 IP20 Suitability Maximum Continuous 75°C Minimum -40°C (w/o impact) Connector Weatherproof Boot Duplex Receptacle Single Receptacle Flanged Receptacle Resources Customer Use Drawing eCatalog Dimensions in Inches (mm) Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 Phone (800) 288-6000 • Fax (800) 255-1031 • Specifications subject to change without notice. HBL4729C HBL6023 HBL4700 HBL4710 HBL4715C
HBL4720C 价格&库存
很抱歉,暂时无法提供与“HBL4720C”相匹配的价格&库存,您可以联系我们找货
