HBLDS3RS
HBLDS3RS
    HUBBELL(哈伯尔公司)
    Switch 600V 30A
HBLDS3RS 数据手册
Twist-Lock® Devices Mechanical Interlock Switched Safety Enclosures Circuit-Lock® Unfused Safety-Shroud® Twist-Lock® 3.19" (81.0) IP66 UL Listed, CSA Certified TYPE 4, 4X and TYPE 12K Enclosure Rating 4.88" (124.0) SUITABILITY Mechanical Interlock Ready for Twist-Lock® Receptacle Addition This unit is a complete enclosure ready to accept any 20 or 30A Watertight Safety-Shroud Twist-Lock Receptacle. Description Ratings Catalog Number Mechanical Interlock accommodates 20A or 30A Watertight Safety-Shroud Twist-Lock receptacles. Amperage and voltage ratings will be determined by the choice of the Watertight Safety-Shroud Twist-Lock selected. Supplied with ¾" NPT Hub. HBLMITL 11.44" (290.6) Accepts the following Watertight Safety-Shroud® Twist-Lock® Receptacles: 20A Use Watertight Safety-Shroud Twist-Lock Plug Rating Voltage AC 2 Pole, 3 Wire 120 L5-20 1 HBL2310SW HBL2311SW 208-240 L6-20 2.5 HBL2320SW HBL2321SW 277 L7-20 3 HBL2330SW HBL2331SW 120/240 L14-20 2.5 HBL2410SW HBL2411SW 240 3Ø L15-20 5 (3@208V) HBL2420SW HBL2421SW 480 3Ø L16-20 10 HBL2430SW HBL2431SW 120/208 3ØY L21-20 3 HBL2510SW HBL2511SW 120 L5-30 1 HBL2610SW HBL2611SW 208-240 L6-30 3 HBL2620SW HBL2621SW 120/240 L14-30 3 HBL2710SW HBL2711SW 240 3Ø L15-30 7.5 HBL2720SW HBL2721SW 480 3Ø L16-30 15 HBL2730SW HBL2731SW 600 3Ø L17-30 15 HBL2740SW HBL2741SW 120/208 3ØY L21-30 7.5 HBL2810SW HBL2811SW 277/480 L22-30 7.5 HBL2820SW HBL2821SW 347/600 L23-30 7.5 HBL2830SW HBL2831SW L5-30 L14-30 L15-30 1 3 7.5 HBL2615SWR HBL2715SWR HBL2725SWR HBL2613SR HBL2713SR HBL2723SR 3 Pole, 4 Wire 4 Pole, 5 Wire Max. HP Rating* Receptacle Catalog Number NEMA Config. 4.19" (106.4) HBLMITL 30A 2 Pole, 3 Wire 3 Pole, 4 Wire 4 Pole, 5 Wire HBL2620SW HBL2713SR 30A Reverse Service 2 Pole, 3 Wire 3 Pole, 4 Wire 3 Pole, 4 Wire 120 120/240 240 3Ø HBLAC1 Auxiliary Contacts Description Ratings Catalog Number Auxiliary contact. “Break After Main Break”, 1 set of n/o contacts, 1 set of n/c contacts. HBLAC1 Auxiliary contact. “Break Before Main Break”, 1 set of n/o contacts. HBLAC2 HBLAC2 Replacement Parts Description Catalog Number Ground block. HBL30RGB Neutral block. HBL30RNB Replacement switch. HBLDS3RS HBL30RGB HBL30RNB Replacement Mounting Feet Description Catalog Number For 30A switches. HBLRFT1∆ Note: *HP ratings for the final unit are determined by the HP rating of the switch, limited by the full load current capability of the receptacle at 80% of rated current, number of phases and line voltage. HP ratings listed above are AC only. ∆ Package of 10 feet and 10 screws. See pages B-52 and B-53 for accessories. See page B-73 for technical information. www.hubbell-wiring.com ® Wiring Device-Kellems HBLRFT1 Dimensions in Inches (mm) B-39
HBLDS3RS 价格&库存
很抱歉,暂时无法提供与“HBLDS3RS”相匹配的价格&库存,您可以联系我们找货
