HBL7567C
HBL7567C
    HUBBELL(哈伯尔公司)
HBL7567C 数据手册
Product Datasheet HBL7567C -- Twist-Lock Plug 3P3W, 10A 250V, 15A 125V, Non-NEMA, Black & White Nylon Product Specifications Product Type Product Item Plug Wiring Scheme 3-Pole, 3-Wire Non-Grounding Multi-Rating 10A 250V AC, 15A 125V Item Style Insulgrip Device Color Black/White Cord Dia. .230"-.720" (5.8-18.3) Blade Holder Material Natural White Nylon Terminal Retainer Material Clear polycarbonate Housing Material Black nylon Cord Clamp Material Natural (white) nylon Blade Material Brass Terminal Clamp Material Cold rolled steel-nickel-plated Terminal Screw Material #8-32 Brass, Copper plated for terminal identification Cord Clamp Screw Material Steel-zinc-plated Body Holding Screw Material Steel-zinc-plated Ratings Molded In or Stamped On Catalog No Permanently ink marked on product Dielectric Voltage Withstand 2,000V minimum Temperature Rise Max 30C temperature rise at full rated current after 50 cycles of overload at 150% of rated current at a power factor of .75. Cord Accommodation Round portable service cords of diameters commensurate with the device rating as defined in UL Standard 62, CSA C22.2 No. 49. Terminal Accommodation 15A #14 AWG Terminal Identification Terminals identified in accordance with UL 498 (X, Y, Z, White, Green) Flammability HB or better per UL 94 or CSA 22.2 No. 0.6 Operating Temperatures Maximum Continuous 75 C Minimum -40 C (w/o impact) Moisture Resistance IP20 UPC Number 783585178752 Weight in LBs 0.15 Link to Drawing Library Click here for Library Link to PDF Catalog Click here for Catalog Configuration
HBL7567C 价格&库存
很抱歉,暂时无法提供与“HBL7567C”相匹配的价格&库存,您可以联系我们找货
