HBLDS3AC
HBLDS3AC
    HUBBELL(哈伯尔公司)
HBLDS3AC 数据手册
Hubbell's CIRCUIT-LOCK® Manual Motor Controllers "Suitable as Motor Disconnects" Safety-First Priority Enhance your safety and increase your confidence with Hubbell’s Circuit-Lock motor controllers and disconnects. Because our Circuit-Lock motor controllers are also disconnects, you get the maximum safety, flexibility, compliance and productivity you need for industrial applications and motor controls. Doubles as a Disconnect The 2005 NEC requires each motor controller to have a disconnect within line of sight (article 430.102). The code also recognizes that a controller and disconnect can be the same unit (article 430.109). Hubbell has designed the operating performance of a controller and disconnect into one switch. Every Circuit-Lock motor controller is a UL 508 listed motor controller “Suitable as Motor Disconnect” to comply with both the controller and disconnect requirements of the NEC. Motor controllers activate motor loads on and off and isolate equipment from other loads as needed. Disconnects safely terminate circuit power to equipment for servicing, and they are tested to withstand high fault short circuits to remain operational following overloads. Clear Choice for Performance Hubbell’s innovative Circuit-Lock product line meets or exceeds all industry requirements to ensure premium performance. Available as a component switch or preassembled into a variety of NEMA-rated enclosures, Circuit-Lock motor controllers/disconnects provide both the size and fit for maximum flexibility and efficiency. So whether your goal is to add more disconnects for NEC “line of sight” requirements, or to implement controllers with enhanced short-circuit performance, the choice is clear with Hubbell’s Circuit-Lock line of motor controllers/ disconnects – it’s a safety first priority. 1 Hubbell Flexibility Hubbell Safety Install one switch at the controller location and another at the disconnect location. Hubbell’s disconnects are rated to withstand 10,000amp high fault short circuits for maximum safety. Because every Circuit-Lock® controller is a disconnect, more disconnect safety locations can be added across the factory floor. Hubbell Productivity Electrical designs must take into account the disconnect location to ensure line of sight placement. Line of sight can now be easily achieved at the equipment or on the wall by installing a Hubbell Circuit-Lock controller/ disconnect. Safe, strategic disconnect placement is more flexible than ever with smaller-sized switches and a variety of NEMA type enclosures. No longer is the entire circuit powered down to repair just one piece of equipment. By adding Hubbell Compliance the disconnect rating to NEC conformance is the requirement for industrial motor applications as inspected by OSHA. Because one Circuit-Lock motor controller meets both the disconnect and controller specifications, confusion is minimized about where and how each switch is used. The switch is always a disconnect, so it’s the Circuit-Lock motor controller, Hubbell lets you safely terminate power at any point in the circuit. Maintenance can now be done on a motor without the inconvenience of shutting down the entire line and sacrificing productivity. always compliant. Each Controller that Hubbell Builds is also a Disconnect Controllers/Disconnects Disconnect Motor Loads 2 www. hubbell-wiring.com AC Manual Toggle Controllers/Disconnects 30, 40, 50, 60 and 85A 600V AC Circuit-Lock® controllers are rated "Suitable as Motor Disconnect". No other manufacturer offers controllers with top horsepower and high amperage ratings in such a compact device. #10 Brass terminal screw. Clamping plate for secure back or side wiring. SHARED FEATURES Strong on/off action with quickmake, slow break operation.  Optional side guard. For close wall applications and finger safe environments. Provides long-life reliability. 10,000 Amp high fault short circuit withstand rating. Thermoset body.     Provides high resistance to electrical arc tracking. Withstands high temperatures. Excellent dimensional stability. Superior dielectric strength. 30A, 40A & 50A Steel screws and copper terminals. Four large silver alloy contacts per pole.   Recessed wiring wells. Finger safe environments. Excellent conductivity. Maximum longevity. 100% Copper contact arm.   High heat management. Reliability. 60A and 85A Lubrication-free controller.  Continued on/off cycling even in harsh, dust and high heat environments.  Safely Terminate Power at any Point in the Circuit.  Flexible Disconnect Placement.  The Industry's Broadest Offering. 3 www. hubbell-wiring.com AC Manual Toggle Controllers/Disconnects 30, 40, 50, 60 and 85A 600V AC 600V AC Manual Motor Controllers Order Information For use in any industrial environment. Ideal component switch for motor control and as a disconnect. Toggle controllers can be built into equipment and enclosures for either box or panel-mount installation. HP Rating Toggle Catalog Amp Poles Type Wire 120V AC 240V AC 480V AC 600V AC Numbers 30 2 Standard — 2 5 30 2 Short — 2 5 30 3 Standard — 3 7.5 30 3 Short — 3 7.5 40 2 Standard — 2 5 40 3 Standard — 3 7.5 50 2 Standard — 2 5 50 3 Standard — 3 7.5 60 2 Standard — — 10 60 3 Standard — — 10 60 2 Standard Front — 10 60 3 Standard Front — 10 85 2 Standard — — 10 85 3 Standard — — 10 Finger Guards (red) for use with 30, 40 and 50A switches 10 10 15 15 10 15 10 15 15 25 15 25 15 25 (set). Specifications     HBL7832D HBL7832DS HBL7810D HBL7810DS HBL7842D HBL7843D HBL7852D HBL7853D HBL7862D HBL7863D HBL7862FWD HBL7863FWD HBL7882D HBL7883D HBLFG30 15 15 20 20 15 20 15 25 20 30 20 30 20 40 HBL7810D HBL7853D HBL7863D HBLFG30 Dimensional Drawings Electrical Performance Dielectric Voltage 2,200V AC minimum for 1 minute Electrical Life 6,000 Cycles at rated switch load Max. Working Voltage 600V AC RMS Switches 10,000 RMS Short Circuit 30A & 40A 60A max. J fuses Withstand Rating 50A 50A max. J fuses as Motor Disconnect 60A & 85A 80A max. J fuses Short Circuit Withstand Rating All Switches 125A max. RK5 fuses as Motor Controller Mechanical Mechanical Life 10,000 minimum cycles Amps AWG Min. AWG Max. Terminal 30 #14 #10 Accommodations 40 & 50 #14 # 8 #14 # 4 60 & 85 Terminal Torque 30 - 50 20 inch pounds 60 - 85 25 inch pounds Environmental Flammability UL94HB/VO Operating Temp. Max. continuous 30, 40 & 60A 60 °C 75 °C Max. continuous 50 & 85A Min. continuous w/out impact -40 °C Listings UL 508 Industrial Control Equipment File #E70402 CSA-C22.2 No.14 Industrial Control Equipment File # LR-46186 30, 40 and 50 Amp Toggles 2.25" (57.2) 3.28" (83.3) 3.78" (96.0) ON 2.43" (62.0) 2.38" (60.4) 1.53" (38.9) Front Side 60 and 85 Amp Toggles 3.56" (90.4) 3.78" (96.0) 3.28" (83.3) ON Front 2.83" (71.9) 1.92" (48.8) 2.38" (60.4) Side 4 www. hubbell-wiring.com NEMA 1 Disconnect Switches "Suitable as Motor Disconnects" Thermoplastic cover on a plated steel base. Durable, non-conductive cover. SHARED FEATURES Wiring conduit knockouts.   1/2" and 3/4" NPT. Top, bottom or back wire entry points. Surface mount control. HBL1389D ®  Circuit-Lock NEMA type 1 enclosures are "Suitable as Disconnect" when used with the 30 Amp controller/disconnect. All aluminum cover and base. Base is pre-drilled for rear surface mounting.  Extra wiring room facilitates termination.  Compact size allows for strategic placement. HBL1379D CIRCUIT-LOCK® NEMA 1 Enclosures with Switch Order Information Ideal for use in industrial environments, i.e. conveyer systems, industrial fans, etc. HP Rating Enclosure Amp Poles Material 120V AC 240V AC 480V AC 600V AC 30 2 Thermoplastic 2 5 10 15 30 3 Thermoplastic 3 7.5 15 20 30 2 Aluminum 2 5 10 15 30 3 Aluminum 3 7.5 15 20 Note: For switch specifications refer to pages 3 and 4. Catalog Numbers HBL1392D HBL1389D HBL1372D HBL1379D HBL1389D HBL1379D HBL1390 HBL1370 CIRCUIT-LOCK® NEMA 1 Enclosures without Switch Order Information For use with switches shown on pages 3 and 4. Cover Material Thermoplastic Aluminum Base Material Steel Aluminum No. Equipment Grounds 1 2 Catalog Numbers HBL1390 HBL1370 Dimensional Drawings HBL1370, HBL1372D and HBL1379D HBL1390, HBL1389D and HBL1392D 3.20" (81.2) 3.15" (80.0) 3.97" (100.8) 3.43" (87.1) 0.50" x 0.75" KNOCKOUT EACH END 2.41" (61.3) 0.92" (23.2) Bottom 2 - 0.50" (12.7) 4.72" (120.0) 2.65" (67.3) KNOCKOUTS 2.75" (69.8) 2.44" (61.9) 0.88" (22.42) Bottom 0.265" (6.7) 2 - HOLES 1.50" (38.1) Back www. hubbell-wiring.com 2.76" (70.1) 2.38" (60.5) 4.52" (114.8) 2.00" (50.8) 5 Back NEMA 3/3R Disconnect Switches "Suitable as Motor Disconnects" Heavy duty flip lid. 3-sided protection. SHARED FEATURES Rain tight enclosures. Die cast aluminum enclosure. Gray zinc powder coat finish. Designed for surface mounting. Three 1/2" NPT threaded outlets. On top, bottom and back of enclosure. HBL13R13D ® VALOX enclosure. Chemical and impact resistant. External activation lever switch. Installer determined wire entry. No predrilled openings or knockouts.  CIRCUIT-LOCK® NEMA type 3/3R enclosures are "Suitable as Disconnect" when used with the 30 amp controller/ disconnect.  Compact size allows for strategic placement. HBL13R23D CIRCUIT-LOCK® NEMA 3/3R Enclosures with Switch Order Information Ideal for use on outdoor equipment. Enclosure HP Rating Amp Poles Material 120V AC 240V AC 480V AC 600V AC 30 2 Thermoplastic 2 5 10 15 30 3 Thermoplastic 3 7.5 15 20 30 2 Aluminum 2 5 10 15 30 3 Aluminum 3 7.5 15 20 Note: Catalog Numbers HBL13R22D* HBL13R23D* HBL13R12D† HBL13R13D† For switch specifications refer to page 4. * Drill weephole to alter from NEMA 3 to NEMA 3R. † Equipped with HBLFG30 sidewall insulation barriers. HBL13R23D HBL13R13D Dimensional Drawings HBL13R22D and HBL13R23D HBL13R12D and HBL13R13D 2.93" (74.4) 1.84" (46.7) 2.99" (75.9) 4.76" (120.9) 5.42" (137.7) 2.25" (57.2) 3.94" (100.1) 0.30" (7.6) ON PADLOCK HOLE 4.51" (114.6) 3.24" (82.3) OFF 0.34" (8.6) 2.22" (56.4) Front ® PADLOCK HOLE 2.99" (75.9) 4.55" (115.6) Side VALOX is a registered trademark of General Electric Company (GE). Back Front Inside Cover 6 www. hubbell-wiring.com NEMA 3R Disconnect Switches "Suitable as Motor Disconnects" SHARED FEATURES All aluminum cover and base.  Base is pre-drilled for rear surface mounting. Rain tight drip shield top.  Rolled seamless sides. Wiring conduit knockouts.    1/2" NPT K.O. for 30A. 3/4" -1" NPT K.O. for 60A. Top, bottom or back wire entry points. ®  CIRCUIT-LOCK NEMA Type 3R enclosures are "Suitable as Disconnect" when used with the 30 or 60 amp controller/disconnect. HBL13R89D HBL16R93D  Front activated lever allows mounting in tight spaces. CIRCUIT-LOCK® NEMA 3R Enclosures with Switch Order Information Ideal for use in outdoor environments. HP Rating Amp 30 30 60 60 Poles 2 3 2 3 120V AC 240V AC 2 5 3 7.5 — 10 — 10 480V AC 600V AC 10 15 15 20 15 20 25 30 Catalog Numbers HBL13R92D HBL13R89D HBL16R92D HBL16R93D HBL13R89D Note: For switch specifications refer to pages 2 and 3. HBL16R93D CIRCUIT-LOCK® NEMA 3R Enclosures without Switch Order Information For use with switches shown on pages 3 and 4. Description For use with 30A switch. For use with 60A switch. Catalog Numbers HBL13R90 HBL16R90 4.40" (111.8) Dimensional Drawings HBL13R90, HBL13R89D and HBL13R92D 4.40" (111.8) 2 - 3/4" KNOCKOUTS HBL16R90, HBL16R92D and HBL16R93D 3.30" (83.3) 2 - 3/4" x 1" 2.75" (69.9) 1.06" (26.9) 1.99" (50.5) KNOCKOUTS 3.30" 2.75" (83.8) (69.9) 5.52" (140.2) 1.52" (38.6) 10.11" (256.8) 2.00" (50.8) 0.31" (7.9) Bottom Bottom PADLOCK HOLE 0.31" (7.9) PADLOCK HOLE 4.28" (108.7) 4.28" (108.7) Front www. hubbell-wiring.com 7 Front NEMA 4X Disconnect Switches "Suitable as Motor Disconnects" Hinged cover with removable continuous pin. SHARED FEATURES Undrilled case.  Allows custom placement of wire entry. 304 stainless steel enclosure. Chemical and corrosion resistant. ® VALOX handle and collar. Chemical and impact resistant. Poured in closed cell neoprene gasket. Interlocking shaft and handle. Prevents cover removal when switch is on. HBL13S33D ®  CIRCUIT-LOCK NEMA Type 4X enclosures are "Suitable as Disconnect" when used with the 30 or 60 amp controller/disconnect.  High impact, chemical and corrosion resistant.  Neutral and ground bus included for wiring ease (60A product).  Up to two optional auxiliary contacts for PLC's and external indicators. Up to 2 optional auxiliary contacts. For PLCs and external indicators. CIRCUIT-LOCK® NEMA 4X Enclosures with Switch and Accessories Order Information Ideal for use in environments where washdown is necessary, i.e. food processing, laboratories, etc. HP Rating Amp Poles 120V AC 240V AC 480V AC 600V AC 30 3 3 7.5 15 20 60 3 — 10 25 30 Finger Guard option for 30A switch NO/NC auxiliary contact, 10A 120/250 V AC for 30 and 60 Amp switches Catalog Numbers HBL13S33D HBL16S63D HBLFG30 HBLAUX HBL13S33D Note: For switch specifications refer to page 4. HBL16S63D Dimensional Drawings HBL13S33D HBL16S63D 6.95" (176.5) 6.96" (176.8) 4.00" (101.6) 6.10" (154.9) 8.75" (222.3) 6.00" 6.75" (152.4) (171.5) 7.44" (189.0) Front 4.00" (101.6) Side Front ® 6.10" (154.9) 4.25" (108.0) VALOX is a registered trademark of General Electric Company (GE). 8.00" (203.2) 9.44" (239.8) 4.25" (108.0) Side 8 www. hubbell-wiring.com NEMA 4X Disconnect Switches "Suitable as Motor Disconnects" SHARED FEATURES Internal frame bonds all grounds. For use with plastic or metallic conduit. VALOX® enclosure.  For impact and chemical resistance. Identified drill locations.  Enables custom placement of wire entry. Front activated pistol handle grip. Minimizes side space clearance. Up to two optional auxiliary contacts.  For PLCs and external indicators. Interlocking shaft and handle. Prevents cover removal in "ON" position. Ample wiring room for drip loops. Adjustable external mounting feet. HBLDS3 Safety interlocked fuse access door. Quick, easy access to fuses. Compact fused disconnect switch. Accepts Class "J" fuses. Safety features. Switch can only be turned "ON" with cover closed. Fuses can only be accessed with switch in the off position. Side activated highly visible red handle. FDS30  Safely Terminate Power at any Point in the Circuit.  Flexible Disconnect Placement. 9 www. hubbell-wiring.com VALOX® is a registered trademark of General Electric Company (GE). NEMA 4X Disconnect Switches "Suitable as Motor Disconnects" NEMA 4X Switched Enclosure, Unfused Order Information Used primarily in heavy wash-down and corrosive environments. HP Rating Catalog Description 120V AC 240V AC 480V AC 600V AC Numbers 30A Disconnect switch 1 7.5 15 15 HBLDS3 30A Disconnect switch w/aux. contact 1 7.5 15 15 HBLDS3AC 60A Disconnect Switch 7.5 30 50 50 HBLDS6 60A Disconnect switch w/aux. contact 7.5 30 50 50 HBLDS6AC 100A Disconnect Switch 7.5 30 50 50 HBLDS10 100A Disconnect switch w/aux. contact 7.5 30 50 50 HBLDS10AC Aux. contact, break after break — — — — HBLAC1 Aux. contact, break before break — — — — HBLAC2 — — — HBL30RGB Ground block (30A switch) — Ground block (60A and 100A switch) — — — — HBL60100RGB Neutral block (30A switch) — — — — HBL30RNB — — — HBL60RNB Neutral block (60A switch) — Neutral block (100A switch) — — — — HBL100RNB Replacement 30A switch — — — — HBLDS3RS Replacement 60A and 100A switch — — — — HBLDS60100RS HBLDS3 HBLAC1 NEMA 4X Switched Enclosure, Fused Disconnect Order Information Used primarily in heavy wash-down and corrosive environments. HP Rating Catalog Description 120V AC 240V AC 480V AC 600V AC Numbers 30A Disconnect switch 2 7.5 15 20 FDS30 60A Disconnect switch 3 15 30 40 FDS60 Aux. contact, norm. open, A600 pilot duty — — — — ACFSNO Aux. contact, norm. closed, A600 pilot duty — — — — ACFSNC Specifications    Electrical Performance Dielectric Voltage 3,000V AC minimum Electrical Life 6,000 Cycles at rated switch parameters Max Working Voltage 600V AC RMS Short Circuit Use on a circuit capable of delivering not Withstand Rating more than 10,000 symmetrical amperes as Motor Disconnect (for HBL series 600V AC max) (for FDS and ACFSN series - at a voltage rating when protected by Class “J” fuses) Mechanical Mechanical Life 10,000 minimum cycles Amps AWG Min. AWG Max. #14 #10 Terminal 30 Accommodations 60A #14 # 4 100A Terminal Torque 30A 20 inch pounds 25 inch pounds 60A 25 inch pounds 100A Impact Resistance UL746C Environmental Flammability Operating Temp.  Listings UL 508 CSA-C22.2 No.14 FDS30 Dimensional Drawings UL94-5VA and V0 Classification Max. continuous 75 °C Min. continuous -40 °C 7.27" (184.7) Fused 11.46" (291.6) 15.03" (381.8) 8.43" (214.1) Unfused A B 30A 60A/100A Key inch (mm) inch (mm) C G .87" (22.1) ON OFF D E F A 6.00 152 7.75 197 B 5.12 130 6.87 175 C 4.12 105 4.75 121 D 6.62 168 8.00 203 E 7.62 194 9.95 253 F 8.50 216 11.00 279 G 4.12 105 5.94 151 Industrial Control Equipment File #E70402 Industrial Control Equipment File # LR-46186 10 www. hubbell-wiring.com Hubbell's CIRCUIT-LOCK® Manual Motor Controllers "Suitable as Motor Disconnects" QUICK REFERENCE Toggle Switches Catalog Numbers HBL7810D HBL7853D HBL7863D Amps HBL7832D HBL7832DS HBL7810D HBL7810DS HBL7842D HBL7843D HBL7852D HBL7853D HBLFG30 HBL7862D HBL7863D HBL7862FWD HBL7863FWD HBL7882D HBL7883D 30 30 30 30 40 40 50 50 — 60 60 60 60 85 85 Description Phase Poles Toggle Switch Short Toggle Switch Toggle Switch Short Toggle Switch Toggle Switch Toggle Switch Toggle Switch Toggle Switch Finger guard (30-50A Switches) Toggle Switch Toggle Switch Toggle Switch - Front Wire Toggle Switch - Front Wire Toggle Switch Toggle Switch 120 240 HP 480 600 1 1 3 3 1 3 1 3 2 2 3 3 2 3 2 3 2 2 3 3 2 3 2 3 5 5 7.5 7.5 5 7.5 5 7.5 10 10 15 15 10 15 10 15 15 15 20 20 15 20 15 25 1 3 1 3 1 3 2 3 2 3 2 3 — — — — — — 10 10 10 10 10 10 15 25 15 25 15 25 20 30 20 30 20 40 120 240 2 3 2 3 2 3 2 3 2 3 — — 1 7.5 7.5 3 — 2 3 5 7.5 5 7.5 5 7.5 5 7.5 5 7.5 10 10 7.5 30 30 7.5 10 7.5 15 Toggle Switches in Enclosures Catalog Numbers HBL1379D HBL13R92D HBL13S33D HBLDS3 HBL1372D HBL1379D HBL1392D HBL1389D HBL13R22D HBL13R23D HBL13R12D HBL13R13D HBL13R92D HBL13R89D HBL16R92D HBL16R93D HBLDS3 HBLDS6 HBLDS10 HBL13S33D HBL16S63D FDS30 FDS60 Amps 30 30 30 30 30 30 30 30 30 30 60 60 30 60 100 30 60 30 60 Description Phase Poles NEMA 1 Aluminum NEMA 1 Aluminum NEMA 1 Plastic NEMA 1 Plastic NEMA 3/3R Plastic NEMA 3/3R Plastic NEMA 3R Die Cast Aluminum NEMA 3R Die Cast Aluminum NEMA 3R Aluminum NEMA 3R Aluminum NEMA 3R Aluminum NEMA 3R Aluminum NEMA 4X Non-Metallic NEMA 4X Non-Metallic NEMA 4X Non-Metallic NEMA 4X Stainless Steel NEMA 4X Stainless Steel NEMA 4X Non-Metallic Fused Disconnect NEMA 4X Non-Metallic Fused Disconnect 1 3 1 3 1 3 1 3 1 3 1 3 3 3 3 3 3 3 3 2 3 2 3 2 3 2 3 2 3 2 3 3 3 3 3 3 3 3 HP 480 10 15 10 15 10 15 10 15 10 15 15 25 15 50 50 15 25 15 30 600 15 20 15 20 15 20 15 20 15 20 20 30 15 50 50 20 30 20 40 FDS30 Printed In U.S.A. Specifications subject to change without notice. ® Registered trademark of Hubbell Incorporated. CIRCUIT-LOCK® is a Registered trademark of Hubbell Wiring Device-Kellems. H5184 Hubbell Incorporated (Delaware) • 185 Plains Road • Milford, CT 06460-2420 • (203) 882-4800 • FAX (800) 255-1031 www. hubbell-wiring.com
HBLDS3AC 价格&库存
很抱歉,暂时无法提供与“HBLDS3AC”相匹配的价格&库存,您可以联系我们找货
