0221-2503
0221-2503
    WAGO(万可电子)
    WAGO - 0221-2503 - MOUNTING CARRIER W/ SR, 3POS, DIN35 RAIL
0221-2503 数据手册
| : 221-2503 Mounting carrier with strain relief; 3-way; for inline splicing connector with lever; for screw mounting; gray https://www.wago.com/221-2503 : gray Physical data Width 29.8 mm / 1.173 inches Height from the surface 6.5 mm / 0.256 inches Depth 100 mm / 3.937 inches . Material data Note (material data) Information on material data can be found here Color gray Fire load 0 MJ Weight 5.9 g . Commercial data PU (SPU) 25 (5) Pieces Packaging type Box Country of origin VKOrg Germany CN GTIN 4066966119848 Customs tariff number VKOrg Germany 39269097900 . Downloads Environmental Product Compliance Compliance Search Environmental Product Compliance 221-2503 . Seite 1/3 Stand: 24.05.2022 Fortsetzung nächste Seite ›› | : 221-2503 https://www.wago.com/221-2503 Documentation Additional Information Technical Section pdf 2142.18 KB . CAD/CAE-Data CAD data CAE data 2D/3D Models 221-2503 ZUKEN Portal 221-2503 . . 1 Compatible products 1.1 Optional accessories 1.1.1 Installation 1.1.1.1 Mounting accessories : 209-119 Fixing screw; for 209-120 mounting carri­ er : 209-123 Mounting foot with screw; can be screwed on terminal blocks with fixing flange; 6.4 mm wide; gray : 209-120 Mounting foot; can be snapped on termi­ nal blocks with snap-in mounting foot; for mounting on relay-modules; 6.4 mm wide; gray Push the connector to the center positi­ on until it snaps into place. Mounting carrier without strain relief – snapped onto DIN-rail . 1.1.2 Marking 1.1.2.1 Marking strip : 210-334 Marking strips; as a DIN A4 sheet; Strip width 5 mm; Strip length 182 mm; plain; Self-adhesive; white . Installation notes Installation Place the inline splicing connector on the carrier in front of the mounting position. . Seite 2/3 Stand: 24.05.2022 Fortsetzung nächste Seite ›› | : 221-2503 https://www.wago.com/221-2503 Various combinations of 1- to 5-connector mounting carriers are possible via side-byside latching mechanism. . Strain relief 3-pole mounting carrier with strain relief . Änderungen vorbehalten. Bitte beachten Sie auch die weitere Produktdokumentation! Adressen finden Sie unter: w w w.wago.com Seite 3/3 Stand: 24.05.2022
0221-2503 价格&库存
很抱歉,暂时无法提供与“0221-2503”相匹配的价格&库存,您可以联系我们找货
