2002-1811
2002-1811
    WAGO(万可电子)
2002-1811 数据手册
Printview: 4-conductor fuse disconnect terminal block with pivoting fuse holder; for 5 x 20 mm miniature metric fuse; without blown fuse indication - Item No.: 2002-1811 . 4-conductor fuse disconnect terminal block with pivoting fuse holder; for 5 x 20 mm miniature metric fuse; without blown fuse indication Item No.: 2002-1811 . 4-conductor fuse disconnect terminal block with pivoting fuse holder; for 5 x 20 mm miniature metric fuse; without blown fuse indication . Marking . Business data Supplier WAGO Item no. 2002-1811 GTIN / EAN 4045454974763 Content 1 Order amount 50 Customer item number . Notes Technical data Miscellaneous Total number of connection points 4 Total number of potentials 1 Color gray Ratings according to 1 IEC/EN 60947-7-3 Pollution degree (1) 3 Rated voltage EN (1) [V] 250 [V] Rated surge voltage (1) [kV] 6 [kV] Nominal current [A] 6.3 [A] WAGO Kontakttechnik GmbH & Co. KG 1 Printview: 4-conductor fuse disconnect terminal block with pivoting fuse holder; for 5 x 20 mm miniature metric fuse; without blown fuse indication - Item No.: 2002-1811 Technical data Connection technology (1) Push-in CAGE CLAMP® Nominal cross section 1 2.5 mm² Solid sizes 1 0.25 … 4 mm² / 22 … 12 AWG solid, directly pluggable 1 0.75 … 4 mm² / 18 … 12 AWG Fine-stranded wires 1 0.25 … 4 mm² / 22 … 12 AWG min. fine-stranded with insulated ferrule, push-in terminati 0.75 mm² / 18 AWG Strip length 1 10 … 12 mm / 0.39 … 0.47 in Type of wiring Front-entry wiring Design horizontal Marking level Center/Side marking Insulating material Polyamide 66 (PA 66) Fire load [MJ] 0.341 [MJ] Weight [g] 16.143 [g] Width 6.2 mm / 0.244 in Height from upper-edge of DIN-rail [mm] 57.2 [mm] Height from upper-edge of DIN-rail 57.2 mm / 2.252 in Length 87.5 mm / 3.445 in Type of mounting DIN 35 rail Safety information 1 Electrical ratings are given by the fuse. WAGO Kontakttechnik GmbH & Co. KG 2 Printview: 4-conductor fuse disconnect terminal block with pivoting fuse holder; for 5 x 20 mm miniature metric fuse; without blown fuse indication - Item No.: 2002-1811 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 3 Printview: 4-conductor fuse disconnect terminal block with pivoting fuse holder; for 5 x 20 mm miniature metric fuse; without blown fuse indication - Item No.: 2002-1811 . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 4
2002-1811 价格&库存
很抱歉,暂时无法提供与“2002-1811”相匹配的价格&库存,您可以联系我们找货
