Data sheet | Item number: 2004-1307
3-conductor ground terminal block; 4 mm²; suitable for Ex e II applications;
side and center marking; for DIN-rail 35 x 15 and 35 x 7.5; Push-in CAGE
CLAMP®; 4,00 mm²; green-yellow
www.wago.com/2004-1307
Color:
Data
Connection data
Connection technology
Push-in CAGE CLAMP®
Subject to changes.
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
29.12.2019 Page 1/16
Push-in CAGE CLAMP®
Actuation type
Push-in
Open Tool Slot
Connectable conductor materials
Copper
Nominal cross section
4 mm²
Solid conductor
0.5 … 6 mm² / 20 … 10 AWG
Solid conductor, push-in termination
1.5 … 6 mm² / 14 … 10 AWG
Fine-stranded conductor
Fine-stranded conductor with ferrule with plastic collar
1.5 … 4 mm² / 18 … 12 AWG
Fine-stranded conductor with ferrule, push-in termination, from
Strip length
11 … 13 mm / 0.43 … 0.51 inch
Total number of connection points
3
Total number of potentials
1
Number of levels
1
Type of wiring
Front-entry wiring
Note (conductor cross-section)
Depending on the conductor characteristic, a conductor with a
smaller cross section can also be inserted via push-in termination.
Number of jumper slots
2
Geometrical Data
Width
6.2 mm / 0.244 inch
Height from upper-edge of DIN-35 rail
32.9 mm / 1.295 inch
Depth
65.5 mm / 2.579 inch
Mechanical data
Design
horizontal
Type of mounting
DIN-35 rail
Marking level
Center/side marking
Material Data
Color
green-yellow
Insulating material
Polyamide 66 (PA 66)
Fire load
0.15 MJ
Weight
14.6 g
Commercial data
Product Group
22 (TOPJOB S)
Packaging type
BOX
Country of origin
Subject to changes.
Hansastr. 27
32423 Minden
DE
29.12.2019 Page 2/16
Country of origin
DE
GTIN
4017332071604
Customs Tariff No.
85369010000
Approvals / Certificates
Ex-Approvals
Logo
Approval
Additional Approval Text
Certificate
name
AEx
Underwriters Laboratories Inc.
EN 60079
E185892
ATEx
Physikalisch Technische Bundesanstalt (PTB)
EN 60079
PTB 05
ATEX
1095 U (II
2 G/D Ex
eII bzw.I
M2 Ex eI)
Country specific Approvals
Logo
Certificate
name
Approval
CCA
DEKRA Certification B.V.
EN 60947
NTR NL7088
CCA
EN 60947
2160584.10
CSA
C22.2 No. 158
1645435
Approval
Certificate
name
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE00001V2
Ship Approvals
Logo
UL-Approvals
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 3/16
UL-Approvals
Logo
Approval
Certificate
name
UL
UL International Germany GmbH
UL 1059
E45172
Compatible products
End plate
Item no.: 2004-1391
End and intermediate plate; 1 mm thick; gray
www.wago.com/2004-1391
Item no.: 2004-1392
End and intermediate plate; 1 mm thick; orange
www.wago.com/2004-1392
Item no.: 2004-1393
Separator plate; 2 mm thick; oversized; gray
www.wago.com/2004-1393
Item no.: 2004-1394
Separator plate; 2 mm thick; oversized; orange
www.wago.com/2004-1394
Item no.: 209-191
Separator for Ex e/Ex i applications; 3 mm thick; 120 mm wide; orange
www.wago.com/209-191
Item no.: 2004-402
Push-in type jumper bar; insulated; 2-way; Nominal current 32 A; light gray
www.wago.com/2004-402
Item no.: 2004-403
Push-in type jumper bar; insulated; 3-way; Nominal current 32 A; light gray
www.wago.com/2004-403
Item no.: 2004-404
Push-in type jumper bar; insulated; 4-way; Nominal current 32 A; light gray
www.wago.com/2004-404
Item no.: 2004-405
Push-in type jumper bar; insulated; 5-way; Nominal current 32 A; light gray
www.wago.com/2004-405
Item no.: 2004-405/011-000
Star point jumper; insulated; 3-way (1-3-5); IN = IN terminal block; light gray
/011-000
Jumper
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 4/16
Item no.: 2004-406
Push-in type jumper bar; insulated; 6-way; Nominal current 32 A; light gray
www.wago.com/2004-406
Item no.: 2004-406/020-000
Delta jumper; insulated; 1-2 3-4 5-6; IN = IN terminal block; light gray
/020-000
Item no.: 2004-407
Push-in type jumper bar; insulated; 7-way; Nominal current 32 A; light gray
www.wago.com/2004-407
Item no.: 2004-408
Push-in type jumper bar; insulated; 8-way; Nominal current 32 A; light gray
www.wago.com/2004-408
Item no.: 2004-409
Push-in type jumper bar; insulated; 9-way; Nominal current 32 A; light gray
www.wago.com/2004-409
Item no.: 2004-410
Push-in type jumper bar; insulated; 10-way; Nominal current 32 A; light gray
www.wago.com/2004-410
Item no.: 2004-433
Push-in type jumper bar; insulated; from 1 to 3; Nominal current 32 A; light gray
www.wago.com/2004-433
Item no.: 2004-434
Push-in type jumper bar; insulated; from 1 to 4; Nominal current 32 A; light gray
www.wago.com/2004-434
Item no.: 2004-435
Push-in type jumper bar; insulated; from 1 to 5; Nominal current 32 A; light gray
www.wago.com/2004-435
Item no.: 2004-436
Push-in type jumper bar; insulated; from 1 to 6; Nominal current 32 A; light gray
www.wago.com/2004-436
Item no.: 2004-437
Push-in type jumper bar; insulated; from 1 to 7; Nominal current 32 A; light gray
www.wago.com/2004-437
Item no.: 2004-438
Push-in type jumper bar; insulated; from 1 to 8; Nominal current 32 A; light gray
www.wago.com/2004-438
Item no.: 2004-439
Push-in type jumper bar; insulated; from 1 to 9; Nominal current 32 A; light gray
www.wago.com/2004-439
Item no.: 2004-440
Push-in type jumper bar; insulated; from 1 to 10; Nominal current 32 A; light gray
www.wago.com/2004-440
Item no.: 210-103
Wire commoning chain; insulated; 50 connections; black
www.wago.com/210-103
Item no.: 210-123
www.wago.com/210-123
Protective Warning Marker
Item no.: 2004-115
Protective warning marker; with high-voltage symbol, black; for 5 terminal blocks; yellow
www.wago.com/2004-115
Marking accessories
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 5/16
Marking accessories
Item no.: 2009-110
Marking strips; on reel; not stretchable; plain; snap-on type; white
www.wago.com/2009-110
Item no.: 2009-115
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; white
www.wago.com/2009-115
Item no.: 2009-115/000-002
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; yellow
/000-002
Item no.: 2009-115/000-005
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; red
/000-005
Item no.: 2009-115/000-006
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; blue
/000-006
Item no.: 2009-115/000-007
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; gray
/000-007
Item no.: 2009-115/000-012
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; orange
/000-012
Item no.: 2009-115/000-017
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; light green
/000-017
Item no.: 2009-115/000-023
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; green
/000-023
Item no.: 2009-115/000-024
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; violet
/000-024
Item no.: 2009-135
www.wago.com/2009-135
Item no.: 2009-145
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; white
www.wago.com/2009-145
Item no.: 2009-145/000-002
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; yellow
/000-002
Item no.: 2009-145/000-005
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; red
/000-005
Item no.: 2009-145/000-006
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 6/16
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; blue
/000-006
Item no.: 2009-145/000-007
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; gray
/000-007
Item no.: 2009-145/000-012
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; orange
/000-012
Item no.: 2009-145/000-023
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; green
/000-023
Item no.: 2009-145/000-024
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; violet
/000-024
Item no.: 2009-191
Group marker carrier
www.wago.com/2009-191
Item no.: 2009-192
www.wago.com/2009-192
Item no.: 2009-193
www.wago.com/2009-193
Item no.: 2009-198
Adaptor
www.wago.com/2009-198
Item no.: 248-501
Miniature WSB Quick marking system; plain; Marker width 5 mm; 10 strips with 10 markers per card
www.wago.com/248-501
Item no.: 248-501/000-002
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; yellow
/000-002
Item no.: 248-501/000-005
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; red
/000-005
Item no.: 248-501/000-006
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; blue
/000-006
Item no.: 248-501/000-007
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; gray
/000-007
Item no.: 248-501/000-012
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; orange
/000-012
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 7/16
Item no.: 248-501/000-017
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; light green
/000-017
Item no.: 248-501/000-023
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; green
/000-023
Item no.: 248-501/000-024
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; violet
/000-024
Item no.: 793-501
WMB marking card; as card; not stretchable; plain; snap-on type; white
www.wago.com/793-501
Item no.: 793-501/000-002
WMB marking card; as card; not stretchable; plain; snap-on type; yellow
/000-002
Item no.: 793-501/000-005
WMB marking card; as card; not stretchable; plain; snap-on type; red
/000-005
Item no.: 793-501/000-006
WMB marking card; as card; not stretchable; plain; snap-on type; blue
/000-006
Item no.: 793-501/000-007
WMB marking card; as card; not stretchable; plain; snap-on type; gray
/000-007
Item no.: 793-501/000-012
WMB marking card; as card; not stretchable; plain; snap-on type; orange
/000-012
Item no.: 793-501/000-017
WMB marking card; as card; not stretchable; plain; snap-on type; light green
/000-017
Item no.: 793-501/000-023
WMB marking card; as card; not stretchable; plain; snap-on type; green
/000-023
Item no.: 793-501/000-024
WMB marking card; as card; not stretchable; plain; snap-on type; violet
/000-024
Item no.: 793-5501
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap- www.wago.com/793-5501
on type; white
Item no.: 793-5501/000-002
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snapSubject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 8/16
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snapwww.wago.com/793-5501
on type; yellow
/000-002
Item no.: 793-5501/000-005
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; red
/000-005
Item no.: 793-5501/000-006
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; blue
/000-006
Item no.: 793-5501/000-007
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; gray
/000-007
Item no.: 793-5501/000-012
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; orange
/000-012
Item no.: 793-5501/000-014
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; brown
/000-014
Item no.: 793-5501/000-017
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; light green
/000-017
Item no.: 793-5501/000-023
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; green
/000-023
Item no.: 793-5501/000-024
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; violet
/000-024
Item no.: 210-658
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; angled; short
www.wago.com/210-658
Item no.: 210-720
www.wago.com/210-720
Item no.: 2004-171
Insulation stop; 0.25 - 0.5 mm²; 5 pieces/strip; light gray
www.wago.com/2004-171
Item no.: 2004-172
Insulation stop; 0.75 - 1 mm²; 5 pieces/strip; dark gray
www.wago.com/2004-172
tools
Insulation stop
ferrule
Item no.: 216-262
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
Subject to changes.
Hansastr. 27
32423 Minden
www.wago.com/216-262
29.12.2019 Page 9/16
crimped; acc. to DIN 46228, Part 4/09.90; gray
Item no.: 216-263
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; red
www.wago.com/216-263
Item no.: 216-264
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-264
Item no.: 216-266
Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; blue
www.wago.com/216-266
Item no.: 216-267
Ferrule; Sleeve for 4 mm² / AWG 12; insulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-267
Item no.: 210-112
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25
mm
www.wago.com/210-112
Item no.: 210-113
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715
www.wago.com/210-113
Item no.: 210-114
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715
www.wago.com/210-114
Item no.: 210-115
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18
mm
www.wago.com/210-115
Item no.: 210-118
Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715
www.wago.com/210-118
Item no.: 210-196
Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silvercolored
www.wago.com/210-196
Item no.: 210-197
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715
www.wago.com/210-197
Item no.: 210-198
Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored
www.wago.com/210-198
Item no.: 210-504
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715
www.wago.com/210-504
Item no.: 210-505
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715
www.wago.com/210-505
Item no.: 210-506
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715
www.wago.com/210-506
Carrier rail
Item no.: 210-508
Subject to changes.
Hansastr. 27
32423 Minden
www.wago.com/210-508
29.12.2019 Page 10/16
Item no.: 210-508
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715
check
Item no.: 2004-511
Modular TOPJOB®S connector; modular; for jumper contact slot; 1-pole; 4,00 mm²; gray
www.wago.com/2004-511
Item no.: 2004-549
Spacer module; modular; e.g., for bridging commoned terminal blocks; gray
www.wago.com/2004-549
Item no.: 2004-552
Modular TOPJOB®S connector; modular; for jumper contact slot; 2-pole; 4,00 mm²; gray
www.wago.com/2004-552
Item no.: 2004-553
Modular TOPJOB®S connector; modular; for jumper contact slot; 3-pole; 4,00 mm²; gray
www.wago.com/2004-553
Item no.: 2004-554
Modular TOPJOB®S connector; modular; for jumper contact slot; 4-pole; 4,00 mm²; gray
www.wago.com/2004-554
Item no.: 2004-555
Modular TOPJOB®S connector; modular; for jumper contact slot; 5-pole; 4,00 mm²; gray
www.wago.com/2004-555
Item no.: 2009-174
Test plug adapter; for 4 mm Ø test plugs; for testing TOPJOB®S rail-mounted terminal blocks; gray
www.wago.com/2009-174
Item no.: 2009-182
Testing tap; for max. 2.5 mm²; tool-free connection for individual test wires 0.08 - 2.5 mm; gray
www.wago.com/2009-182
Downloads
Documentation
Bid Text
2004-1307
Feb 19, 2019
xml
3.7 kB
Download
Aug 7, 2018
docx
14.9 kB
Download
Apr 3, 2019
pdf
2.1 MB
Download
URL
Download
X81 - Datei
2004-1307
docx - Datei
Additional Information
Technical explanations
CAD/CAE-Data
CAD data
2D/3D Models 2004-1307
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 11/16
CAE data
EPLAN Data Portal 2004-1307
Download
WSCAD Universe 2004-1307
Download
Installation Notes
Inserting a conductor
All conductor types at a glance
Terminating solid and ferruled conductors
via push-in connection.
Inserting conductors via push-in
termination.
Solid conductors with cross-sections from
either one size above, or up to two sizes
below, the rated cross-section can be simply
pushed in – no tools needed.
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 12/16
Inserting a conductor via operating tool.
Conductor termination – Insulation stop.
Connecting fine-stranded conductors
without ferrules, or small cross-sectional
conductors that cannot be pushed in, is
performed similarly to the original CAGE
CLAMP® – just use an operating tool.
The smart feature:
To open the clamp, the operating tool is
inserted vertically. The conductor entry is
less than 15 degrees for easier wiring.
Jumpered
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 13/16
The push-in type jumper bar system is based
on the common plug and socket principle.
Each terminal block is spring-loaded with a
double socket and a resilient CrNi steel
spring. The jumper contact material is pure
electrolytic copper, which allows for an
extremely small design capable of carrying
the full-rated current of the terminal block.
Ground terminal blocks can also be
commoned using the same jumper system.
Custom jumpers are created by breaking
and removing jumper contacts (2000, 2001,
2002, 2004 Series).
Removing a push-in type jumper bar.
Insert the operating tool between the jumper
and and partition wall of the dual jumper
slots, then lift up the jumper.
Place the operating tool in the center of
jumpers up to five contacts (see above), or
alternately on both sides for jumpers with
more than five contacts.
Jumpered
This star point jumper has been specially
developed to create a “star point” and is
used on motor terminal boards equipped
with TOPJOB® S rail-mount terminal blocks.
This delta jumper has been specially
developed to create a delta configuration
and is used on motor terminal boards
equipped with TOPJOB® S rail-mount
terminal blocks.
Push down the wire jumper until fully
inserted. Lift the jumper with an operating
tool for rewiring.
Testing
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 14/16
The modular TOPJOB® S connectors also
connect conductors of the same size as the
terminal blocks being used.
TOPJOB® S Connectors with a 2 mm Ø test
socket for testing voltage via 2-pole voltage
tester
Test plug adapter (2009‑174, CAT I) for
4 mm Ø plugs – compatible with 2000 to
2016 Series
Testing tap (2009‑182) for tool-free
connection of test cables up to 2.5 mm² (12
AWG) – compatible with 2000 to 2016 Series
Rail-mount terminal block assembly for
electric motor wiring
Marking
Snapping WMB Inline markers into marker
slots.
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 15/16
TOPJOB® S 2009‑193 Group Marker Carrier
(equipped with a marking strip) for all 2001 to
2016 Series TOPJOB® S Rail-Mount Terminal
Blocks
Do not use on an end plate!
Product family
TOPJOB® S
TOPJOB® S: In various industrial applications and modern building installations, WAGO's wide and versatile range of railmount terminal blocks provides more than just reliable electrical connections.
Show all products from the family
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 16/16
很抱歉,暂时无法提供与“2004-1307”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+19.54117
- 50+17.58702
- 国内价格
- 10+21.39761
- 100+20.96929
