2006-115
2006-115
    WAGO(万可电子)
2006-115 数据手册
  0.5 … 6 (10) mm²1 AWG 20 … 8 800 V/8 kV/3 2 600 V, 50 AU 600 V, 50 A2 IN 41 A (57 A) 0.5 … 6 (10) mm²1 AWG 20 … 8 800 V/8 kV/3 2 600 V, 50 AU 600 V, 50 A2 IN 41 A (57 A) Terminal block width 7.5 mm / 0.295 in. L 13 … 15 mm / 0.55 in.3 Terminal block width 7.5 mm / 0.295 in. L 13 … 15 mm / 0.55 in.3 1 Conductor sizes: 0.5 mm² … 10 mm² “s + f-st”; Push-in conductor sizes: 1 mm² … 10 mm² “s” and 1.5 mm² … 6 mm² “insulated ferrule, 12 mm” 2 800 V = rated voltage 8 kV = rated surge voltage 3 = pollution degree (see Section 14) 3 Strip length, see packaging or instructions. 4 Suitable for Ex i applications 24,8 mm/0.98 in 57,4 mm/2.26 in Item No. 5 Suitable for Ex e II applications 550 V, 38 A for 2-conductor terminal blocks 550 V, 36 A for 3-conductor terminal blocks Jumper 33 A (see Section 14) 32,9 mm/ 1.3 in 20 32,9 mm/ 1.3 in 1 TOPJOB® S Through/Ground Conductor/Shield and Ex Terminal Blocks 6 (10) mm² 2006 Series 6 See application notes for: Ex e/Ex i separator plate, page 19 Step-down jumper, page 23 Star point jumper, page 103 TOPJOB® S connector, page 98 40,8 mm/1.61 in 73,3 mm/2.89 in Pack. Unit Item No. Pack. Unit 2-conductor through terminal block 2006-1201 5 gray 4 2006-1204 4 5 blue 4 2006-1202 5 orange 4 50 50 50 3-conductor through terminal block 2006-1301 5 gray 4 2006-1304 4 5 blue 4 2006-1302 5 orange 4 25 25 25 2-conductor ground terminal block 2006-1207 5 green-yellow 4 50 3-conductor ground terminal block 2006-1307 5 green-yellow 4 25 2-conductor shield terminal block 2006-1208 5 white 4 50 Lockout cap for covering unused clamping units of 2006 Series TOPJOB® S terminal blocks. Item-Specific Accessories Item-Specific Accessories End and intermediate plate, 1 mm thick orange 2006-1292 gray 2006-1291 100 (4x25) 100 (4x25) End and intermediate plate, 1 mm thick orange 2006-1392 gray 2006-1391 100 (4x25) 100 (4x25) Separator, oversized, 2 mm thick orange 2006-1294 gray 2006-1293 100 (4x25) 100 (4x25) Separator, oversized, 2 mm thick orange 2006-1394 gray 2006-1393 100 (4x25) 100 (4x25) 2006 Series Accessories Appropriate marking systems: WMB/Marking strips (see Section 13) Ex e/Ex i separator, orange, 6 3 mm thick 120 mm 209-191 Step-down jumper, insulated, 6 IN 32 A 50 (2x25) light gray 2006-499 Push-in type jumper bar, insulated, IN 41 A, light gray 2-way 2006-402 3-way 2006-403 4-way 2006-404 5-way 2006-405 50 50 50 50 Push-in type jumper bar, insulated, IN 41 A, light gray from 1 to 3 2006-433 from 1 to 4 2006-434 from 1 to 5 2006-435 50 (2x25) 50 (2x25) 50 (2x25) (2x25) (2x25) (2x25) (2x25) 50 (2x25) Protective warning marker, with high-voltage symbol, black, for 5 terminal blocks yellow 2006-115 100 (4x25) Lockout cap, for conductor entry hole and operating slot 25 gray 2006-191 Modular TOPJOB® S connector, 6 can be snapped together, for jumper contact slot 50 (2x25) gray 2006-511 Test plug adapter, for 4 mm Ø test plug gray 2009-174 100 (4x25) Star point jumper, insulated, WMB Multi marking system, 6 IN = IN terminal block, light gray 10 strips with 10 markers per card, 1-3-5 stretchable 5 … 5.2 mm 2006-405/011-000 50 (2x25) plain 793-5501 Certification organizations can be found in the overview on page 622. 5 Commoning with step-down jumpers An end plate must be inserted between the terminal blocks to be jumpered. Step-down jumper 2006-499 commons 6/4 mm² AWG 10/12 (2006/2004 Series) terminal blocks with 4/2.5/1.5 mm² AWG 12/14/16 (2004/2002/2001Series) terminal blocks. Step-down jumpers are simply pushed down for full insertion, similar to other push-in type jumper bars. Note: The total current flowing shall not exceed the rating of the step-down jumper/push-in type jumper bar.
2006-115 价格&库存
很抱歉,暂时无法提供与“2006-115”相匹配的价格&库存,您可以联系我们找货
  • 1+12.41079
  • 100+8.93435
  • 500+7.97328
  • 1000+7.60547
  • 2500+7.13087
  • 5000+6.98849
库存:16
2006-115
    • 10+8.74242
    库存:130
    2006-115
      • 1+204.84018
      库存:50
