Data sheet | Item number: 2042-3859
Relay module; 230 VAC/VDC; 1 make contact
www.wago.com/2042-3859
Similiar to picture
03.04.2019 Page 1/7
DC load limit curve
Data
Technical Data
Control circuit
Nominal input voltage UN
AC/DC 24 … 230 V
Input voltage range
±10 %
Nominal input current at UN
1.7 mA (230 V); 26.3 mA (24 V)
Load circuit:
Number of break contacts/switch off contacts
1
Contact material (relay)
AgSnO2
Limiting continuous current
6 A
Max. switching voltage
AC 250 V
Max. switching power (resistive)
AC 1,500 VA; DC see load limit curve
Recommended minimum load
10 V / 10 mA; 24 V / 1 mA
Min. switching current
0 µA
Pull-in time (typ.)
8 ms
Drop-out time (typ.)
4 ms
Drop-out time
≤ 0 µs
Electrical life (N.O.; resistive load; 23 °C)
10 x 103 switching operations
Mechanical life (N.O.; resistive load; 23 °C)
5 x 106 switching operations
Signaling
Status indication
LED green
03.04.2019 Page 2/7
Safety and protection:
Rated voltage
250 V
Rated impulse voltage
4 kV
Pollution degree
2
Dielectric strength, control/load circuit (AC, 1 min)
3 kVrms
Dielectric strength open contact (AC, 1 min)
1 kVrms
Dielectric strength, channel/channel (AC, 1 min)
2.5 kVrms
Protection class
IP20
Geometrical Data
Width
10.3 mm / 0.406 inch
Height
77.7 mm / 3.059 inch
Height from the surface
59.3 mm / 2.335 inch
Depth
52 mm / 2.047 inch
Mechanical data
Type of mounting
Pluggable module for TOPJOB® S carrier terminal block
Material Data
Flammability class per UL94
V0
Fire load
0.204 MJ
Weight
27.75
Environmental Requirements
Pollution degree
2
Surrounding air (operating) temperature at UN
-40 … 70 °C
Surrounding air (storage) temperature
-40 … 85 °C
Max. operating altitude
2000 m
Standards and specifications
Standards/specifications
EN 61010-2-201; EN 61373; EN 50121-3-2
Commercial data
Country of origin
DE
GTIN
4055143709569
03.04.2019 Page 3/7
Compatible products
Terminal Block
Item no.: 2002-1661
Carrier terminal block; for disconnect; fuse or component plug; rail mount; 2-conductor; 5.2 mm wide;
gray
www.wago.com/2002-1661
Item no.: 2002-1761
Carrier terminal block; for disconnect; fuse or component plug; rail mount; 3-conductor; 5.2 mm wide;
gray
www.wago.com/2002-1761
Item no.: 2002-1861
Carrier terminal block; for disconnect; fuse or component plug; rail mount; 4-conductor; 5.2 mm wide;
gray
www.wago.com/2002-1861
Item no.: 2002-1961
Carrier terminal block; for disconnect; fuse or component plug; with additional jumper location; rail
mount; 2-conductor; 5.2 mm wide; gray
www.wago.com/2002-1961
Marking accessories
Item no.: 2009-110
Marking strips; on reel; not stretchable; plain; snap-on type
www.wago.com/2009-110
Item no.: 2009-115
WMB-Inline; for smartPRINTER; on reel; stretchable 5 - 5.2 mm; plain; snap-on type
www.wago.com/2009-115
Item no.: 2009-115/000-002
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type
/000-002
Item no.: 2009-115/000-006
/000-006
Item no.: 2009-115/000-007
/000-007
Item no.: 2009-115/000-012
/000-012
Item no.: 2009-115/000-017
/000-017
Item no.: 2009-115/000-023
/000-023
Item no.: 2009-115/000-024
/000-024
Item no.: 793-501
www.wago.com/793-501
03.04.2019 Page 4/7
Item no.: 793-501
WMB marking card; as card; not stretchable; plain; snap-on type
Item no.: 793-501/000-002
/000-002
Item no.: 793-501/000-005
/000-005
Item no.: 793-501/000-006
/000-006
Item no.: 793-501/000-007
/000-007
Item no.: 793-501/000-012
/000-012
Item no.: 793-501/000-017
/000-017
Item no.: 793-501/000-023
/000-023
Item no.: 793-501/000-024
/000-024
Item no.: 793-5501
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501
type
Item no.: 793-5501/000-002
/000-002
type
Item no.: 793-5501/000-005
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type
/000-005
Item no.: 793-5501/000-006
/000-006
Item no.: 793-5501/000-007
/000-007
Item no.: 793-5501/000-012
/000-012
Item no.: 793-5501/000-014
03.04.2019 Page 5/7
/000-014
Item no.: 793-5501/000-017
/000-017
Item no.: 793-5501/000-023
/000-023
Item no.: 793-5501/000-024
/000-024
Item no.: 2002-1691
TOPJOB®S end/intermediate plate; for 2002-16xx series terminal blocks; 1.0 mm wide; gray
www.wago.com/2002-1691
Item no.: 2002-1692
TOPJOB®S end/intermediate plate; for 2002-16xx series terminal blocks; 1.0 mm wide; orange
www.wago.com/2002-1692
Item no.: 2002-1791
TOPJOB®S end/intermediate plate; for 2002-17xx series terminal blocks; 1.0 mm wide; gray
www.wago.com/2002-1791
Item no.: 2002-1792
TOPJOB®S end/intermediate plate; for 2002-17xx series terminal blocks; 1.0 mm wide; orange
www.wago.com/2002-1792
Item no.: 2002-1891
TOPJOB®S end/intermediate plate; for 2002-18xx series terminal blocks; 1.0 mm wide; gray
www.wago.com/2002-1891
Item no.: 2002-1892
TOPJOB®S end/intermediate plate; for 2002-18xx series terminal blocks; 1.0 mm wide; orange
www.wago.com/2002-1892
End plate
Downloads
Documentation
Additional Information
Disposal; Electrical and electronic equipment, Packaging
V 1.0.0
10-Oct-2018
pdf
265.8 kB
Download
URL
Download
CAD files
CAD data
3D Download 2042-3859
03.04.2019 Page 6/7
Subject to changes.
WAGO Corporation
Germantown, WI 53022
Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222
Email: info.us@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at {0}.
03.04.2019 Page 7/7
很抱歉,暂时无法提供与“2042-3859”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 6+648.011016+83.83012
