2
216
Board-to-Board Links for SMD PCB Terminal Blocks with Push-Buttons, 0.75 mm2,
Pin Spacing: 4 mm, 8 mm
2060 Series
Board-to-board link simplifies in-line assembly of LED modules
E asy push-in termination and disconnection
without push-button actuation
Technical data:
Pin Spacing
Ratings per
Overvoltage category
Pollution degree
Rated voltage
Rated surge voltage
Nominal current
Approvals per
Rated voltage
Nominal current UL
4 mm
0.157 in.
8 mm
0.314 in.
IEC/EN 60664-1
III
III
II
3
2
2
63 V 160 V 320 V
2.5 kV 2.5 kV 2.5 kV
9A
9A
9A
UL/CSA
250 V
9A
IEC/EN 60664-1
III
III
II
3
2
2
400 V 630 V 1000 V
6 kV
6 kV
6 kV
9A
9A
9A
UL/CSA
600 V
9A
Material data:
Material group
Insulating material
Flammability class per UL 94
Lower/Upper limit temperature
Contact material
Contact plating
I
Polyamide 6.6 (PA 6.6)
V0
-60 °C / +105 °C
Copper alloy
Silver-plated
Additional approvals and corresponding ratings can be found at www.wago.com.
For additional technical information, see Section 13.
2
217
Pin spacing: 4 mm / 0.157 in.
160 V/2.5 kV/2 9 A
Pin spacing: 8 mm / 0.314 in.
250 V/9 A
630 V/6 kV/2 9 A
600 V/9 A
2,6
< >__
1
< >__
>_ 8 _<
< 8,25 4,5 <
1
2
3
4
Pole No. Item No.
min. 4,4 ‒ max. 6,4
min. 4,4 ‒ max. 6,4
很抱歉,暂时无法提供与“2060-953/028-000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+6.373051+0.82490
- 10+5.2119310+0.67461
- 375+4.86272375+0.62941
