2201-1204
2201-1204
    WAGO(万可电子)
    WAGO - 2201-1204 - DIN Rail Mount Terminal Block, 2 Ways, 22 AWG, 14 AWG, 1.5 mm², Push In, 18 A
2201-1204 数据手册
Data sheet  |  Item number: 2201-1204 2-conductor through terminal block; with push-button; 1.5 mm²; with test port; suitable for Ex i applications; side and center marking; for DIN-rail 35 x 15 and 35 x 7.5; Push-in CAGE CLAMP®; 1,50 mm2; blue www.wago.com/2201-1204 Color: Data Electrical data 05.09.2019    Page 1/10 Data sheet  |  Item number: 2201-1204 www.wago.com/2201-1204 Ratings per IEC/EN 60664-1 Rated voltage (III / 3) 800 V Rated impulse voltage (III / 3) 8 kV Rated current 18 A Rated current (2) 24 A Approvals per UL 1059 Rated voltage UL (Use Group B) 600 V Rated current UL (Use Group B) 15 A Rated voltage UL (Use Group C) 600 V Rated current UL (Use Group C) 15 A Connection data Connection technology Push-in CAGE CLAMP® Actuation type Push-in Push-button Connectable conductor materials Copper Nominal cross section 1.5 mm² Solid conductor 0.25 … 2.5 mm² / 22 … 14 AWG Solid conductor, push-in termination 0.75 … 2.5 mm² / 18 … 14 AWG Fine-stranded conductor 0.25 … 2.5 mm² / 22 … 14 AWG Strip length 9 … 11 mm / 0.35 … 0.43 inch Note (conductor cross-section) Depending on the conductor characteristic, a conductor with a smaller cross section can also be inserted via push-in termination. Total number of connection points 2 Total number of potentials 1 Number of levels 1 Type of wiring Front-entry wiring Number of jumper slots 2 Geometrical Data Width 4.2 mm / 0.165 inch Height from upper-edge of DIN-35 rail 32.9 mm / 1.295 inch Depth 48.5 mm / 1.909 inch Mechanical data Design horizontal Type of mounting DIN-35 rail Marking level Center/side marking Material Data 05.09.2019    Page 2/10 Data sheet  |  Item number: 2201-1204 www.wago.com/2201-1204 Material Data Color blue Insulating material Polyamide 66 (PA 66) Fire load 0.089 MJ Weight 4.145 g Commercial data Country of origin DE GTIN 4055143694667 Customs Tariff No. 85369010000 Approvals / Certificates Ex-Approvals Logo Certificate name Approval Additional Approval Text ATEX Physikalisch Technische Bundesanstalt IEC 60079-0 PTB 18 ATEX 1004 U (II 2 G Ex eb IIC Gb bzw. I M 2 Ex eb I Mb) IECEx Physikalisch Technische Bundesanstalt IEC 60079-0 IECEx PTB 18.0011U (Ex eb IIC Gb and Ex eb I Mb) Country specific Approvals Logo Certificate name Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60947 NTR NL 7664 CSA DEKRA Certification B.V. C22.2 70173738 KEMA/KEUR DEKRA Certification B.V. EN 60947 71102875 Ship Approvals Certificate Logo Approval Additional Approval Text name 05.09.2019    Page 3/10 Data sheet  |  Item number: 2201-1204 www.wago.com/2201-1204 Certificate Logo Approval Additional Approval Text name ABS American Bureau of Shipping - 19HG1866350PDA DNV GL Det Norske Veritas, Germanischer Lloyd - TAE00003JT LR Lloyds Register - 19/20050 Approval Additional Approval Text Certificate name cURus Underwriters Laboratories Inc. UL 1059 4788308064 UL-Approvals Logo Compatible products tools Item no.: 210-647 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft www.wago.com/210-647 Item no.: 210-648 Operating tool with partially insulated shaft; Blade (2.5 x 0.4) mm; short; angled www.wago.com/210-648 Item no.: 210-719 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft www.wago.com/210-719 Item no.: 2002-880 Empty component plug housing; 10.4 mm wide; 2-pole; Type 4; gray www.wago.com/2002-880 Item no.: 2002-1291 End and intermediate plate; 0.8 mm thick; gray www.wago.com/2002-1291 plug End plate 05.09.2019    Page 4/10 Data sheet  |  Item number: 2201-1204 www.wago.com/2201-1204 Item no.: 2002-1292 End and intermediate plate; 0.8 mm thick; orange www.wago.com/2002-1292 Item no.: 2002-1293 Separator plate; 2 mm thick; oversized; gray www.wago.com/2002-1293 Item no.: 2002-1294 Separator plate; 2 mm thick; oversized; orange www.wago.com/2002-1294 Item no.: 2001-402 Push-in type jumper bar; insulated; 2-way; Nominal current 18 A; light gray www.wago.com/2001-402 Item no.: 2001-403 Push-in type jumper bar; insulated; 3-way; Nominal current 18 A; light gray www.wago.com/2001-403 Item no.: 2001-404 Push-in type jumper bar; insulated; 4-way; Nominal current 18 A; light gray www.wago.com/2001-404 Item no.: 2001-405 Push-in type jumper bar; insulated; 5-way; Nominal current 18 A; light gray www.wago.com/2001-405 Item no.: 2001-405/011-000 Star point jumper; insulated; 3-way (1-3-5); IN = IN terminal block; light gray www.wago.com/2001-405 /011-000 Item no.: 2001-406 Push-in type jumper bar; insulated; 6-way; Nominal current 18 A; light gray www.wago.com/2001-406 Item no.: 2001-406/020-000 Delta jumper; insulated; 1-2 3-4 5-6; IN = IN terminal block; light gray www.wago.com/2001-406 /020-000 Item no.: 2001-407 Push-in type jumper bar; insulated; 7-way; Nominal current 18 A; light gray www.wago.com/2001-407 Item no.: 2001-408 Push-in type jumper bar; insulated; 8-way; Nominal current 18 A; light gray www.wago.com/2001-408 Item no.: 2001-409 Push-in type jumper bar; insulated; 9-way; Nominal current 18 A; light gray www.wago.com/2001-409 Item no.: 2001-410 Push-in type jumper bar; insulated; 10-way; Nominal current 18 A; light gray www.wago.com/2001-410 Item no.: 2001-433 Push-in type jumper bar; insulated; from 1 to 3; Nominal current 18 A; light gray www.wago.com/2001-433 Item no.: 2001-434 Push-in type jumper bar; insulated; from 1 to 4; Nominal current 18 A; light gray www.wago.com/2001-434 Item no.: 2001-435 Push-in type jumper bar; insulated; from 1 to 5; Nominal current 18 A; light gray www.wago.com/2001-435 Item no.: 2001-436 Push-in type jumper bar; insulated; from 1 to 6; Nominal current 18 A; light gray www.wago.com/2001-436 Item no.: 2001-437 Push-in type jumper bar; insulated; from 1 to 7; Nominal current 18 A; light gray www.wago.com/2001-437 Jumper 05.09.2019    Page 5/10 Data sheet  |  Item number: 2201-1204 www.wago.com/2201-1204 Item no.: 2001-438 Push-in type jumper bar; insulated; from 1 to 8; Nominal current 18 A; light gray www.wago.com/2001-438 Item no.: 2001-439 Push-in type jumper bar; insulated; from 1 to 9; Nominal current 18 A; light gray www.wago.com/2001-439 Item no.: 2001-440 Push-in type jumper bar; insulated; from 1 to 10; Nominal current 18 A; light gray www.wago.com/2001-440 Item no.: 2006-499 Step-down jumper; insulated; from 6/4 mm² to 4/2.5/1.5 mm²; Nominal current 32 A; light gray www.wago.com/2006-499 Item no.: 2009-412 Push-in type wire jumper; insulated; wire length 60 mm; Conductor cross section 1.5 mm²; suitable for 2001, 2002, 2003 and 2022 Series rail-mounted terminal blocks; black www.wago.com/2009-412 Item no.: 2009-414 Push-in type wire jumper; insulated; wire length 110 mm; Conductor cross section 1.5 mm²; suitable for 2001, 2002, 2003 and 2022 Series rail-mounted terminal blocks; black www.wago.com/2009-414 Item no.: 2009-414/000-005 Push-in type wire jumper; insulated; wire length 110 mm; Conductor cross section 1.5 mm²; suitable for 2001, 2002, 2003 and 2022 Series rail-mounted terminal blocks; red www.wago.com/2009-414 /000-005 Item no.: 2009-414/000-006 Push-in type wire jumper; insulated; wire length 110 mm; Conductor cross section 1.5 mm²; suitable for 2001, 2002, 2003 and 2022 Series rail-mounted terminal blocks; blue www.wago.com/2009-414 /000-006 Item no.: 2009-416 Push-in type wire jumper; insulated; wire length 250 mm; Conductor cross section 1.5 mm²; suitable for 2001, 2002, 2003 and 2022 Series rail-mounted terminal blocks; black www.wago.com/2009-416 Item no.: 210-103 Wire commoning chain; insulated; 50 connections; black www.wago.com/210-103 Item no.: 210-123 Wire commoning chain; insulated; 50 connections www.wago.com/210-123 Marking accessories Item no.: 2009-110 Marking strips; on reel; not stretchable; plain; snap-on type; white www.wago.com/2009-110 Item no.: 2009-114 WMB-Inline; for Smart Printer; on reel; stretchable 4 - 4.2 mm; plain; snap-on type; white www.wago.com/2009-114 Item no.: 2009-114/000-002 WMB-Inline; for Smart Printer; on reel; stretchable 4 - 4.2 mm; plain; snap-on type; yellow www.wago.com/2009-114 /000-002 Item no.: 2009-114/000-005 WMB-Inline; for Smart Printer; on reel; stretchable 4 - 4.2 mm; plain; snap-on type; red www.wago.com/2009-114 /000-005 Item no.: 2009-114/000-006 WMB-Inline; for Smart Printer; on reel; stretchable 4 - 4.2 mm; plain; snap-on type; blue www.wago.com/2009-114 /000-006 Item no.: 2009-114/000-007 WMB-Inline; for Smart Printer; on reel; stretchable 4 - 4.2 mm; plain; snap-on type; gray www.wago.com/2009-114 /000-007 05.09.2019    Page 6/10 Data sheet  |  Item number: 2201-1204 www.wago.com/2201-1204 Item no.: 2009-114/000-012 WMB-Inline; for Smart Printer; on reel; stretchable 4 - 4.2 mm; plain; snap-on type; orange www.wago.com/2009-114 /000-012 Item no.: 2009-114/000-023 WMB-Inline; for Smart Printer; on reel; stretchable 4 - 4.2 mm; plain; snap-on type; green www.wago.com/2009-114 /000-023 Item no.: 2009-114/000-024 WMB-Inline; for Smart Printer; on reel; stretchable 4 - 4.2 mm; plain; snap-on type; violet www.wago.com/2009-114 /000-024 Item no.: 793-4501 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; white www.wago.com/793-4501 Item no.: 793-4501/000-002 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; yellow www.wago.com/793-4501 /000-002 Item no.: 793-4501/000-005 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; red www.wago.com/793-4501 /000-005 Item no.: 793-4501/000-006 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; blue www.wago.com/793-4501 /000-006 Item no.: 793-4501/000-007 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; gray www.wago.com/793-4501 /000-007 Item no.: 793-4501/000-012 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; orange www.wago.com/793-4501 /000-012 Item no.: 793-4501/000-017 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; light green www.wago.com/793-4501 /000-017 Item no.: 793-4501/000-023 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; green www.wago.com/793-4501 /000-023 Item no.: 793-4501/000-024 WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; violet www.wago.com/793-4501 /000-024 Item no.: 210-112 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm www.wago.com/210-112 Item no.: 210-113 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715 www.wago.com/210-113 Item no.: 210-114 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715 www.wago.com/210-114 Carrier rail Item no.: 210-115 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 www.wago.com/210-115 05.09.2019    Page 7/10 Data sheet  |  Item number: 2201-1204 www.wago.com/2201-1204 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm www.wago.com/210-115 Item no.: 210-118 Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715 www.wago.com/210-118 Item no.: 210-196 Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silvercolored www.wago.com/210-196 Item no.: 210-197 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715 www.wago.com/210-197 Item no.: 210-198 Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored www.wago.com/210-198 Item no.: 216-241 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; white www.wago.com/216-241 Item no.: 216-242 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-242 Item no.: 216-243 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; red www.wago.com/216-243 Item no.: 216-244 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-244 Item no.: 2001-171 Insulation stop; 0.25 - 0.5 mm²; 5 pieces/strip; light gray www.wago.com/2001-171 Item no.: 2001-511 Modular TOPJOB®S connector; modular; for jumper contact slot; 1-pole; 1,50 mm2; gray www.wago.com/2001-511 Item no.: 2001-549 Spacer module; modular; e.g., for bridging commoned terminal blocks; gray www.wago.com/2001-549 Item no.: 2001-552 Modular TOPJOB®S connector; modular; for jumper contact slot; 2-pole; 1,50 mm2; gray www.wago.com/2001-552 Item no.: 2001-553 Modular TOPJOB®S connector; modular; for jumper contact slot; 3-pole; 1,50 mm2; gray www.wago.com/2001-553 Item no.: 2001-554 Modular TOPJOB®S connector; modular; for jumper contact slot; 4-pole; 1,50 mm2; gray www.wago.com/2001-554 Item no.: 2001-555 Modular TOPJOB®S connector; modular; for jumper contact slot; 5-pole; 1,50 mm2; gray www.wago.com/2001-555 Item no.: 2001-556 Modular TOPJOB®S connector; modular; for jumper contact slot; 6-pole; 1,50 mm2; gray www.wago.com/2001-556 Item no.: 2001-557 Modular TOPJOB®S connector; modular; for jumper contact slot; 7-pole; 1,50 mm2; gray www.wago.com/2001-557 ferrule Insulation stop check 05.09.2019    Page 8/10 Data sheet  |  Item number: 2201-1204 www.wago.com/2201-1204 Item no.: 2001-558 Modular TOPJOB®S connector; modular; for jumper contact slot; 8-pole; 1,50 mm2; gray www.wago.com/2001-558 Item no.: 2001-559 Modular TOPJOB®S connector; modular; for jumper contact slot; 9-pole; 1,50 mm2; gray www.wago.com/2001-559 Item no.: 2001-560 Modular TOPJOB®S connector; modular; for jumper contact slot; 10-pole; 1,50 mm2; gray www.wago.com/2001-560 Item no.: 2009-174 Test plug adapter; for 4 mm Ø test plugs; for testing TOPJOB®S rail-mounted terminal blocks; gray www.wago.com/2009-174 Item no.: 2009-182 Testing tap; for max. 2.5 mm²; tool-free connection for individual test wires 0.08 - 2.5 mm; gray www.wago.com/2009-182 General accessories Item no.: 2002-880/1000-411 Component plug; 2-pole; with diode 1N4007; 10.4 mm wide; Operating temperature 85°C max.; gray www.wago.com/2002-880 /1000-411 Item no.: 2002-880/1000-541 Component plug; 2-pole; LED (red); 10.4 mm wide; Operating temperature 85°C max.; gray www.wago.com/2002-880 /1000-541 Item no.: 2002-880/1000-542 LED module; with red LED; 10.4 mm wide; 30 - 65 V; Operating temperature 85°C max. www.wago.com/2002-880 /1000-542 Item no.: 2002-880/1000-836 Component plug; 2-pole; LED (red); 10.4 mm wide; Operating temperature 85°C max.; gray www.wago.com/2002-880 /1000-836 Downloads Documentation Bid Text 2201-1204 docx 15.0 kB Download pdf 2.1 MB Download URL Download Additional Information Technical explanations Apr 3, 2019 CAD/CAE-Data CAD data 3D Download 2201-1204 EPLAN EPLAN Data Portal Download 05.09.2019    Page 9/10 Data sheet  |  Item number: 2201-1204 www.wago.com/2201-1204   Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 05.09.2019    Page 10/10
2201-1204 价格&库存
很抱歉,暂时无法提供与“2201-1204”相匹配的价格&库存,您可以联系我们找货
    • 100+5.32981
    库存:200
    2201-1204
      • 1+8.96881
      库存:1
