Data sheet from 02.02.2009
Item no.:
231-168/001-000
Product description:
HEADER; STRAIGHT SOLDER PIN, 1.2 X 1.2 MM /0.047 X
0.047 IN; 8 POLE; PIN SPACING 5 MM / 0.197 IN; MATING
DIRECTION PERPENDICULAR TO PCB; WITH CLOSED END
Packing unit 100 pieces
Product group
3 (Multi Conn. System)
Pin spacing from
5 mm
Pin spacing from
0,197 in
pole count
8
Measured voltage EN
250 V
Measured shock voltage
4 kV
Pollution degree
4
Current intensity EN
16 A
Weight
3,164 g
Color
grey
Height
12 mm
Height
0,472 in
Width
43,2 mm
Width
1,701 in
Depth
8,4 mm
Depth
0,331 in
1 von 2
Item number
Admission office
Approval no.
Voltage [V]
Current [A]
Cross section [ mm² ]
231-168/001-000
ABS
04-HG469925-PDA
400
16
5,0
231-168/001-000
BV
11915/A0
400
16
2,5
231-168/001-000
CCA
5764
250
16
1,2x1,2
231-168/001-000
CSA
154112-1466354
300
15
231-168/001-000
DEMKO
88126
250
16
2,5
231-168/001-000
GL
17296-00HH
400
16
5,0
231-168/001-000
KEMA
2083746.02
250
16
1,2x1,2
231-168/001-000
KR
HMB05880-EL003
250/400
12/16
2,5
231-168/001-000
LR
96/20035
400
16
5,0
231-168/001-000
NEMKO
P94101840
250
231-168/001-000
RMR
11130002
400
16
231-168/001-000
UR
E45171
600
15
231-168/001-000
UR
E45172
300
15
Sorting criteria: admission office - approval number
© WAGO Kontakttechnik GmbH & Co. KG
Specifications are subject to changes and errors may be expected
2 von 2
2,5
5,0
很抱歉,暂时无法提供与“231-168/001-000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+41.759321+5.40930
- 10+35.4687410+4.59445
- 100+30.14603100+3.90497
- 500+26.91051500+3.48586
- 1000+25.626911000+3.31959
