261-331
261-331
    WAGO(万可电子)
    板对板连接器
261-331 数据手册
Printview: 4-conductor terminal block; with fixing flange; for screw or similar mounting types; fixing hole 3.2 mm Ø; with 209-123 mounting carrier for DIN 35 rail - Item No.: 261-331 . 4-conductor terminal block; with fixing flange; for screw or similar mounting types; fixing hole 3.2 mm Ø; with 209-123 mounting carrier for DIN 35 rail Item No.: 261-331 . 4-conductor terminal block; with fixing flange; for screw or similar mounting types; fixing hole 3.2 mm Ø; with 209-123 mounting carrier for DIN 35 rail . Marking . Business data Supplier WAGO Item no. 261-331 GTIN / EAN 4044918610643 Content 1 Order amount 50 Customer item number . Notes Technical data Miscellaneous Total number of connection points 4 Total number of potentials 1 Color gray Pollution degree (1) 3 Rated voltage EN (1) [V] 500 [V] Rated surge voltage (1) [kV] 6 [kV] Nominal current [A] 24 [A] Connection technology (1) CAGE CLAMP® WAGO Kontakttechnik GmbH & Co. KG 1 Printview: 4-conductor terminal block; with fixing flange; for screw or similar mounting types; fixing hole 3.2 mm Ø; with 209-123 mounting carrier for DIN 35 rail - Item No.: 261-331 Technical data Solid sizes 1 0.08 … 2.5 mm² / 28 … 14 AWG Fine-stranded wires 1 0.08 … 2.5 mm² / 28 … 14 AWG Strip length 1 8 … 9 mm / 0.31 … 0.35 in Type of wiring Side-entry wiring Design horizontal Marking level Side marking Fire load [MJ] 0.06 [MJ] Weight [g] 3.871 [g] Width 10 mm / 0.394 in Height from the surface 18 mm / 0.709 in Length 28 mm / 1.102 in WAGO Kontakttechnik GmbH & Co. KG 2 Printview: 4-conductor terminal block; with fixing flange; for screw or similar mounting types; fixing hole 3.2 mm Ø; with 209-123 mounting carrier for DIN 35 rail - Item No.: 261-331 Images & drawings . WAGO Kontakttechnik GmbH & Co. KG 3 Printview: 4-conductor terminal block; with fixing flange; for screw or similar mounting types; fixing hole 3.2 mm Ø; with 209-123 mounting carrier for DIN 35 rail - Item No.: 261-331 Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 4
261-331 价格&库存
很抱歉,暂时无法提供与“261-331”相匹配的价格&库存,您可以联系我们找货
  • 50+23.9155550+3.09521
库存:200
261-331
库存:615
261-331
  • 83+10.8557483+1.40498
  • 100+10.37037100+1.34216
  • 250+7.50450250+0.97125
  • 500+7.23353500+0.93618
  • 1000+6.997441000+0.90563
库存:1685
261-331
  • 1+30.256441+3.91587
  • 10+21.5710510+2.79178
  • 25+18.8452025+2.43899
  • 50+17.1298850+2.21699
  • 100+15.69974100+2.03190
  • 250+14.20790250+1.83882
  • 500+13.33605500+1.72599
  • 1000+12.646471000+1.63674
  • 5000+11.572025000+1.49768
库存:1361
261-331
  • 84+10.6760184+1.38172
  • 100+10.19817100+1.31988
  • 250+7.37956250+0.95508
  • 500+7.11345500+0.92064
  • 1000+6.881421000+0.89061
库存:1205
