Printview: 2-conductor ground terminal block - Item No.: 281-907
Item No.: 281-907
Marking
Business data
Supplier
WAGO
Item no.
281-907
GTIN / EAN
4044918512046
Content
1
Order amount
50
Customer item number
Notes
Technical data
Miscellaneous
Total number of connection points
2
Total number of potentials
1
Color
green-yellow
Ratings according to 1
IEC/EN 60947-7-2
Connection technology (1)
CAGE CLAMP®
Solid sizes 1
0.08 … 4 mm² / 28 … 12 AWG
Fine-stranded wires 1
Strip length 1
9 … 10 mm / 0.35 … 0.39 in
Type of wiring
Front-entry wiring
Design
horizontal
WAGO Kontakttechnik GmbH & Co. KG
1
Technical data
Marking level
Center marking
Insulating material
Polyamide 66 (PA 66)
Fire load [MJ]
0.127 [MJ]
Weight [g]
12.018 [g]
Width
6 mm / 0.236 in
Height from upper-edge of DIN-rail [mm]
29 [mm]
29 mm / 1.142 in
Length
59 mm / 2.323 in
Type of mounting
DIN 35 rail
2
Images & drawings
3
Address
Hansastr. 27
32423 Minden
Telefon: 0571/887-0
Fax: 0571/887-169
http://www.wago.com
© WAGO Kontakttechnik GmbH & Co. KG
Technische Änderungen und Irrtümer vorbehalten.
4
