Data sheet | Item number: 284-687
3-conductor ground terminal block; 10 mm²; center marking; for DIN-rail 35 x
15 and 35 x 7.5; CAGE CLAMP®; 10,00 mm²; green-yellow
www.wago.com/284-687
Color:
Data
Electrical data
Ratings per IEC/EN
Ratings per
IEC/EN 60947-7-2
Connection
data
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
18.05.2021 Page 1/11
Connection data
Connection technology
CAGE CLAMP®
Actuation type
Operating tool
Connectable conductor materials
Copper
Solid conductor
0.2 … 10 mm² / 24 … 8 AWG
Fine-stranded conductor
Strip length
12 … 13 mm / 0.47 … 0.51 inch
Total number of connection points
3
Total number of potentials
1
Number of levels
1
Wiring type
Front-entry wiring
Physical data
Width
10 mm / 0.394 inch
Height
97.5 mm / 3.839 inch
Depth from upper edge of DIN-rail
35 mm / 1.378 inch
Mechanical data
Design
horizontal type
Mounting type
DIN-35 rail
Marking level
Center marking
Material data
Color
green-yellow
Insulation material
Polyamide (PA66)
Fire load
0.409 MJ
Weight
40 g
Commercial data
Packaging type
BOX
Country of origin
DE
GTIN
4045454084639
Customs tariff number
85369010000
Approvals / Certificates
Country specific Approvals
Hansastr. 27
32423 Minden
Certificate
18.05.2021 Page 2/11
Logo
Certificate
name
Approval
Additional Approval Text
CCA
DEKRA Certification B.V.
EN 60947
NTR NL7379
KEMA/KEUR
EN 60947
2178517.01
Approval
ABS
American Bureau of Shipping
EN 60947
20HG1941090PDA
BV
Bureau Veritas S.A.
EN 60947
07436/F0 BV
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE00001V2
LR
Lloyds Register
EN 60947
91/20112
(E9)
Ship Approvals
Logo
Certificate
name
UL-Approvals
Logo
Approval
UL
UL International Germany GmbH
UL 1059
Certificate
name
20190731E45172
Required accessories
End plate
Item no.: 284-308
End and intermediate plate; 2.5 mm thick; gray
Hansastr. 27
32423 Minden
www.wago.com/284-308
18.05.2021 Page 3/11
Item no.: 284-339
End and intermediate plate; 2.5 mm thick; orange
www.wago.com/284-339
Compatible products
End plate
Item no.: 284-309
Separator plate; 2 mm thick; oversized; gray
www.wago.com/284-309
Item no.: 284-340
Separator plate; 2 mm thick; oversized; orange
www.wago.com/284-340
Item no.: 709-312
B-type intermediate plate; modular; snaps on 709-310 B-type test plug modules and 709-311 B-type
spacer modules; Module width 2 mm; gray
www.wago.com/709-312
Item no.: 209-106
Mounting carrier; for isolated mounting on DIN 35 rails; gray
www.wago.com/209-106
Item no.: 249-116
Screwless end stop; 6 mm wide; for DIN-rail 35 x 15 and 35 x 7.5; gray
www.wago.com/249-116
Item no.: 709-154
Cover; Type 2; suitable for cover carrier, type 2; 1 m long; transparent
www.wago.com/709-154
Item no.: 284-400
Finger guard; touchproof cover protects unused conductor entries; yellow
www.wago.com/284-400
Item no.: 284-402
Jumper; insulated; gray
www.wago.com/284-402
Item no.: 284-409
www.wago.com/284-409
Item no.: 284-422
Jumper; insulated; yellow-green
www.wago.com/284-422
assembling
protection
Jumper
Carrier rail
Item no.: 210-112
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm; www.wago.com/210-112
silver-colored
Item no.: 210-113
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored
www.wago.com/210-113
Item no.: 210-114
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored
www.wago.com/210-114
Item no.: 210-115
Hansastr. 27
32423 Minden
18.05.2021 Page 4/11
Item no.: 210-115
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm; www.wago.com/210-115
silver-colored
Item no.: 210-118
Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored
www.wago.com/210-118
Item no.: 210-196
www.wago.com/210-196
Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored
Item no.: 210-197
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715; silver-colored
www.wago.com/210-197
Item no.: 210-198
Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored
www.wago.com/210-198
Item no.: 210-504
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715; silvercolored
www.wago.com/210-504
Item no.: 210-505
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715;
silver-colored
www.wago.com/210-505
Item no.: 210-506
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715; silvercolored
www.wago.com/210-506
Item no.: 210-508
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715; silvercolored
www.wago.com/210-508
Item no.: 216-108
Ferrule; Sleeve for 6 mm² / AWG 10; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-108
ferrule
Item no.: 216-208
Ferrule; Sleeve for 6 mm² / AWG 10; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-208
acc. to DIN 46228, Part 4/09.90; yellow
Item no.: 216-262
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-262
Item no.: 216-263
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263
acc. to DIN 46228, Part 4/09.90; red
Item no.: 216-264
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-264
Item no.: 216-266
Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; blue
www.wago.com/216-266
Item no.: 216-267
Ferrule; Sleeve for 4 mm² / AWG 12; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-267
Protective Warning Marker
Hansastr. 27
32423 Minden
18.05.2021 Page 5/11
Item no.: 284-415
Protective warning marker; with high-voltage symbol, black; for 5 terminal blocks; yellow
www.wago.com/284-415
Item no.: 209-170
Test plug adapter; 8.3 mm wide; for 4 mm Ø test plugs; suitable for 1.5 mm² - 10 mm² tbs; gray
www.wago.com/209-170
Item no.: 709-310
B-type test plug module; modular; suitable for all WAGO 282 Series rail-mounted terminal blocks with
jumper slots; 6,00 mm²; gray
www.wago.com/709-310
Item no.: 709-311
B-type spacer module; modular; e.g., for bridging commoned terminal blocks; gray
www.wago.com/709-311
check
Marking accessories
Item no.: 2009-115
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white
www.wago.com/2009-115
Item no.: 2009-115/000-002
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow
/000-002
Item no.: 2009-115/000-006
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue
/000-006
Item no.: 2009-115/000-007
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray
/000-007
Item no.: 2009-115/000-012
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; orange
/000-012
Item no.: 2009-115/000-017
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; light
green
/000-017
Item no.: 2009-115/000-023
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; green
/000-023
Item no.: 2009-115/000-024
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; violet
/000-024
Item no.: 249-105
Group marker carrier; gray
www.wago.com/249-105
Item no.: 793-501
WMB marking card; as card; not stretchable; plain; snap-on type; white
www.wago.com/793-501
Item no.: 793-501/000-002
Hansastr. 27
32423 Minden
18.05.2021 Page 6/11
WMB marking card; as card; not stretchable; plain; snap-on type; yellow
/000-002
Item no.: 793-501/000-005
WMB marking card; as card; not stretchable; plain; snap-on type; red
/000-005
Item no.: 793-501/000-006
WMB marking card; as card; not stretchable; plain; snap-on type; blue
/000-006
Item no.: 793-501/000-007
WMB marking card; as card; not stretchable; plain; snap-on type; gray
/000-007
Item no.: 793-501/000-012
WMB marking card; as card; not stretchable; plain; snap-on type; orange
/000-012
Item no.: 793-501/000-017
WMB marking card; as card; not stretchable; plain; snap-on type; light green
/000-017
Item no.: 793-501/000-023
WMB marking card; as card; not stretchable; plain; snap-on type; green
/000-023
Item no.: 793-501/000-024
WMB marking card; as card; not stretchable; plain; snap-on type; violet
/000-024
Item no.: 793-5501
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501
type; white
Item no.: 793-5501/000-002
/000-002
type; yellow
Item no.: 793-5501/000-005
/000-005
type; red
Item no.: 793-5501/000-006
/000-006
type; blue
Item no.: 793-5501/000-007
/000-007
type; gray
Item no.: 793-5501/000-012
/000-012
type; orange
Hansastr. 27
32423 Minden
18.05.2021 Page 7/11
type; orange
Item no.: 793-5501/000-017
/000-017
type; green
Item no.: 793-5501/000-023
/000-023
type; light green
Item no.: 793-5501/000-024
/000-024
type; violet
tools
Item no.: 210-721
Operating tool; Blade: 5.5 x 0.8 mm; with a partially insulated shaft; multicoloured
www.wago.com/210-721
Downloads
Documentation
Bid Text
284-687
2017 Feb 28
doc
24.6 kB
Download
2019 Feb 19
xml
3.1 kB
Download
2019 Apr 3
pdf
2.2 MB
Download
URL
Download
EPLAN Data Portal 284-687
URL
Download
WSCAD Universe 284-687
URL
Download
ZUKEN Portal 284-687
URL
Download
doc - Datei
284-687
X81 - Datei
Additional Information
Technical explanations
CAD/CAE-Data
CAD data
2D/3D Models 284-687
CAE data
Hansastr. 27
32423 Minden
18.05.2021 Page 8/11
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 284-687
URL
Download
3-conductor ground terminal block; 10 mm²; center marking; for DIN-rail 35 x 15 and
Installation Notes
Installation
Snapping a ground conductor block onto the
DIN-rail automatically makes a direct
electrical connection to the rail.
Quick assembly keys prevent reverse
mounting.
Removing a terminal block from the
assembly.
Conductor termination
CAGE CLAMP® connection
Inserting a conductor.
Hansastr. 27
32423 Minden
18.05.2021 Page 9/11
Removing a solid conductor.
With ferruled conductors, it is necessary to
use a terminal block one size larger than the
conductor's nominal cross-section.
Commoning
Commoning ground conductor terminal
blocks with through terminal blocks is
possible in one direction only (via rear side
of terminal block) using adjacent jumpers.
WAGO recommends using yellow–green
adjacent jumpers in addition to the required
marking of these blocks.
Testing
Hansastr. 27
32423 Minden
18.05.2021 Page 10/11
Testing with a test plug.
Picture shows a test plug adapter (209-170).
Marking
Labeling via WMB Multi Marking System.
Hansastr. 27
32423 Minden
18.05.2021 Page 11/11
很抱歉,暂时无法提供与“284-687”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3+249.262793+32.28825
- 10+177.9630210+23.05244
- 25+168.8495425+21.87192
- 50+165.3907450+21.42389
- 国内价格 香港价格
- 1+254.023781+32.90497
- 10+182.5852610+23.65118
- 25+163.8265325+21.22127
- 50+152.7436250+19.78564
- 100+143.91455100+18.64197
- 250+135.05760250+17.49469
- 500+130.04483500+16.84536
