Data sheet | Item number: 2857-570/024-005
3-Phase Power Measurement Module; 3x400/690 V/5 A; Modbus RTU;
Digital output; Configuration via software; Supply voltage: 24 VDC
www.wago.com/2857-570/024-005
Item description
Short description:
WAGO’s 3-phase power measurement module in a DIN-railmount enclosure measures electrical data in three-phase supply networks – remotely
from the control level.
Measured variables such as active/apparent/reactive power, energy consumption, power factor, phase angle and frequency can be accessed via
Modbus® Interface. In addition, the measured variables can be stored on a microSD card.
Features:
Current measurement via 5A current transformer
Mobile measurement and storage of measured values on microSD card
Configuration and display of measured values during operation via configuration interface
Compact device in DIN-rail-mount enclosure saves space used for building technology
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
03.06.2020 Page 1/10
Communication of measured values via Modbus® Interface
Configurable digital signal output as pulse output
Note:
Additional setting options via interface configuration software
In the present network, ensure that the neutral conductor is not dangerously active!
Data
Technical Data
Configuration
Configuration options
WAGO interface configuration software
Input
Input signal type
Voltage
Electricity
Network configuration
3-phase power measurement with N-conductor (4-conductor)
3-phase power measurement without N-conductor (3-conductor)
Input signal (voltage)
AC 400 V (ULN); AC 690 V (ULL)
Input signal (current)
AC 5 A; (Current transformer)
Frequency range
45 … 65 Hz (Harmonics analysis: 0 … 3.3 kHz)
Input resistance (current input)
22 mΩ
Input resistance (voltage input)
1.5 MΩ
Input current (max.)
5 AAC
Input voltage (max.)
400 VAC (ULN); 690 VAC (ULL)
Response threshold
5 mA
Resolution (current)
0.15 mA
Output – Digital
Switching voltage (DO) (max.)
Supply voltage (applied)
Continuous current (DO) (max.)
100 mA (no internal restriction)
Configurable functions (DO)
Threshold value switch
Pulse output (S0 interface)
Hansastr. 27
32423 Minden
03.06.2020 Page 2/10
Communication
Communication
Modbus RTU
Interface
RS-485 (2-wire) via RJ-45
Number of devices (max.)
32
Addressing
Via Interface configuration software
Signal processing
Measurement method
True RMS measurement (measured value acquisition with 8 kHz)
Measured variables (calculated)
Line-to-line voltage
Outputs
Energy sources
Power factors
Mains frequency
Harmonics analysis (up to 41st harmonic)
Total harmonic distortion (THD)
Signal form
Any periodic signals (considering the threshold frequencies)
Limit frequency
15,9 kHz
Memory card type
WAGO 758-879/000-3102 (microSD; 2 GB)
Measurement error
Transmission error (max.)
≤ 0.5 % for current and voltage (of the full scale value)
Power supply
Power supply type
24 VDC
Nominal supply voltage US
DC 24 V (SELV)
Supply voltage range
±30 %
Power consumption at nominal supply voltage
≤ 50 mA (+ IDO)
Safety and protection:
Test voltage (input/output/supply)
AC 3,51 kV; 50 Hz; 1 min
Overvoltage category
III
Pollution degree
2
Safe isolation
Input/supply and communication per EN 61010-1
Requirement (N input)
Shall not be dangerously active
Requirement (ILx input)
Coils/converters with basic insulation
Protection type
IP20
Hansastr. 27
32423 Minden
03.06.2020 Page 3/10
Protection type
IP20
Connection data
Connection type (1)
Voltage
Connection technology
Push-in CAGE CLAMP®
WAGO Connector
WAGO 804 Series
Solid conductor
0,25 … 2,5 mm² / 20 … 12 AWG
Fine-stranded conductor
0,25 … 2,5 mm² / 22 … 12 AWG
Strip length
10 … 11 mm / 0.39 … 0.43 inch
Connection type 2
Current/Power supply/DO
Connection technology 2
Push-in CAGE CLAMP®
WAGO Connector 2
WAGO 805 Series
Solid conductor 2
0,2 … 1,5 mm² / 24 … 16 AWG
Fine-stranded conductor 2
Strip length 2
9 … 10 mm / 0.35 … 0.39 inch
Connection type (3)
Modbus® communication
Pluggable connectors
2 x RJ-45 (daisy chain configuration)
Geometrical Data
Width
72 mm / 2.835 inch
Height from upper-edge of DIN-rail
55 mm / 2.165 inch
Depth
90 mm / 3.54 inch
Mechanical data
Mounting type
DIN-35 rail
Material Data
Weight
117.5 g
Environmental Requirements
Surrounding air temperature (operation)
-40 … 70 °C
Surrounding air temperature (storage)
-40 … 85 °C
Relative humidity
5 … 95 % (non-condensing)
Hansastr. 27
32423 Minden
03.06.2020 Page 4/10
Standards and specifications
Conformity marking
CE
EMC immunity to interference
EN 61000-6-2
EMC emission of interference
EN 61000-6-3
Standards/specifications
EN 61010-1
Commercial data
Packaging type
BOX
Country of origin
DE
GTIN
4055143827461
Customs tariff number
85437090300
Approvals / Certificates
Ship Approvals
Logo
Approval
Additional Approval Text
Certificate
name
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAA00001ZY
Counterpart
Compatible products
memory card
Item no.: 758-879/000-3102
Memory Card SD Micro; 2 GByte
www.wago.com/758-879
/000-3102
tools
Item no.: 210-720
Hansastr. 27
32423 Minden
www.wago.com/210-720
03.06.2020 Page 5/10
Item no.: 210-720
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft
power supply
Item no.: 787-2850
Switched-mode power supply; Compact; 1-phase; 24 VDC output voltage; 1.25 A output current
www.wago.com/787-2850
current transformer
Item no.: 855-1005/2500-1001
www.wago.com/855-1005
Plug-in current transformer; Primary rated current: 2500 A; Secondary rated current: 5 A; Rated power:
/2500-1001
10 VA; Accuracy class: 1
Item no.: 855-305/050-103
Plug-in current transformer; Primary rated current: 50 A; Secondary rated current: 5 A; Rated power:
1.25 VA; Accuracy class: 3
www.wago.com/855-305
/050-103
Item no.: 855-305/060-101
Plug-in current transformer; Primary rated current: 60 A; Secondary rated current: 5 A; Rated power:
1.25 VA; Accuracy class: 1
/060-101
Item no.: 855-305/075-201
Plug-in current transformer; Primary rated current: 75 A; Secondary rated current: 5 A; Rated power:
2.5 VA; Accuracy class: 1
/075-201
Item no.: 855-305/100-201
Plug-in current transformer; Primary rated current: 100 A; Secondary rated current: 5 A; Rated power:
/100-201
Item no.: 855-305/150-501
Plug-in current transformer; Primary rated current: 150 A; Secondary rated current: 5 A; Rated power: 5
/150-501
Item no.: 855-305/200-501
Plug-in current transformer; Primary rated current: 200 A; Secondary rated current: 5 A; Rated power: 5
/200-501
Item no.: 855-305/250-501
Plug-in current transformer; Primary rated current: 250 A; Secondary rated current: 5 A; Rated power: 5
/250-501
Item no.: 855-305/300-501
Plug-in current transformer; Primary rated current 300 A; Secondary rated current: 5 A; Rated power: 5
/300-501
Item no.: 855-305/400-1001
Plug-in current transformer; Primary rated current: 400 A; Secondary rated current: 5 A; Rated power:
/400-1001
Item no.: 855-305/600-1001
Plug-in current transformer; Primary rated current: 600 A; Secondary rated current: 5 A; Rated power:
/600-1001
Item no.: 855-4005/150-101
Split-core current transformer; Primary rated current: 150 A; Secondary rated current: 5 A; Rated
Hansastr. 27
32423 Minden
www.wago.com/855-4005
03.06.2020 Page 6/10
power: 1 VA; Accuracy class: 1; Cable length: 0.5 m
/150-101
Item no.: 855-405/250-501
www.wago.com/855-405
/250-501
Item no.: 855-405/400-501
Plug-in current transformer; Primary rated current: 400 A; Secondary rated current: 5 A; Rated power: 5
/400-501
Item no.: 855-405/750-501
Plug-in current transformer; Primary rated current 750 A; Secondary rated current: 5 A; Rated power: 5
/750-501
Item no.: 855-4105/250-101
Split-core current transformer; Primary rated current: 250 A; Secondary rated current: 5 A; Rated
www.wago.com/855-4105
/250-101
Item no.: 855-4105/400-101
Split-core current transformer; Primary rated current: 400 A; Secondary rated current: 5 A; Rated
/400-101
Item no.: 855-5005/1000-000
Split-core current transformer; Primary rated current: 1000 A; Secondary rated current: 5 A; Rated
power: 0.5 VA; Accuracy class: 0.5; Cable length: 3 m
www.wago.com/855-5005
/1000-000
Item no.: 855-5005/400-001
power: 0.5 VA; Accuracy class: 1; Cable length: 3 m
/400-001
Item no.: 855-5005/600-000
Split-core current transformer; Primary rated current: 600 A; Secondary rated current: 5 A; Rated
/600-000
Item no.: 855-505/1000-1001
www.wago.com/855-505
Plug-in current transformer; Primary rated current: 1000 A; Secondary rated current: 5 A; Rated power:
/1000-1001
Item no.: 855-505/400-1001
/400-1001
Item no.: 855-505/600-1001
/600-1001
Item no.: 855-505/800-1001
Plug-in current transformer; Primary rated current: 800 A; Secondary rated current: 5 A; Rated power:
/800-1001
Item no.: 855-5105/1000-000
Hansastr. 27
32423 Minden
03.06.2020 Page 7/10
www.wago.com/855-5105
/1000-000
Item no.: 855-605/1500-501
www.wago.com/855-605
Plug-in current transformer; Primary rated current: 1500 A; Secondary rated current: 5 A; Rated power:
/1500-501
Item no.: 855-805/2000-1001
www.wago.com/855-805
Plug-in current transformer; Primary rated current: 2000 A; Secondary rated current: 5 A; Rated power:
/2000-1001
transfer module
Item no.: 289-175/790-108
Interface module; RJ-45; PCB terminal blocks, double-row; Cat. 5; in mounting carrier; with shield
connection; with shield clamping saddle
www.wago.com/289-175
/790-108
Item no.: 289-176
Interface module; RJ-45; with power jumper contacts; RJ-45; Cat. 5; in mounting carrier
www.wago.com/289-176
wiring and connectors
Item no.: 750-923
Configuration cable; USB connector; Length: 2.5 m; black
www.wago.com/750-923
Item no.: 750-923/000-001
Configuration cable; USB connector; Length: 5 m
/000-001
Item no.: 750-978/000-011
Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568A; AWG 22; Strain relief
www.wago.com/750-978
/000-011
General accessories
Item no.: 2007-8874
Compact terminal block; for current and voltage transformers; 6,00 mm²; multicoloured
www.wago.com/2007-8874
Item no.: 2007-8877
Compact terminal block; for current transformer circuit; 6,00 mm²; multicoloured
www.wago.com/2007-8877
Item no.: 855-8001
Power tap; with fuse; 2,5 mm² (12 AWG) - 6 mm² (10 AWG); Phase
www.wago.com/855-8001
Item no.: 855-8002
Power tap; without fuse; 2,5 mm² (12 AWG) - 6 mm² (10 AWG); N-conductor
www.wago.com/855-8002
Item no.: 855-8003
Power tap; with fuse; 10 mm² (8 AWG) - 16 mm² (6 AWG); Phase
www.wago.com/855-8003
Item no.: 855-8004
Power tap; without fuse; 10 mm² (8 AWG) - 16 mm² (6 AWG); N-conductor
www.wago.com/855-8004
Item no.: 855-8006
Power tap; for busbar; with fuse; Mounting screw M6
www.wago.com/855-8006
Hansastr. 27
32423 Minden
03.06.2020 Page 8/10
Item no.: 855-8008
Power tap; for busbar; with fuse; Mounting screw M8
www.wago.com/855-8008
Item no.: 855-8015
Power tap; for busbar; with fuse; Clamping connection
www.wago.com/855-8015
Downloads
Documentation
Manual
V 1.0.0
pdf
16.4 MB
Download
Jul 15, 2019
docx
20.4 kB
Download
Jul 15, 2019
xml
8.8 kB
Download
V 1.1.0
pdf
1.2 MB
Download
V 1.0.0
pdf
265.8 kB
Download
V 1.0.0
Feb 28, 2019
zip
2.2 MB
Download
1.6.3.7
exe
Download
Bid Text
2857-570/024-005
GAEB docx - Datei
2857-570/024-005
GAEB X81 - Datei
Instruction Leaflet
3-Phasen-Leistungsmessmodul
Additional Information
Disposal; Electrical and electronic equipment, Packaging
Libraries
Library
Library for the Wago 3-Phase Powertransducer module 2857-570
WAGO-I/O-PRO Library for
2857-0570/0024-000x
3-Phase Powertransducer modules
Engineering-Software
Software for Interface-Products
WAGO Interface
Configuration
SMALL
Subject
to changes.
Please also Software
observe the
Hansastr. 27
32423 Minden
03.06.2020 Page 9/10
1.6.3.7
Sep 17, 2019
exe
48.0 MB
Download
1.6.3.7
The full setup, in addition to the WAGO Interface Configuration Software, includes the Sep 17, 2019
installation for the Microsoft .NET Framework.
exe
98.5 MB
Download
WAGO Interface Configuration Software SMALL
The full setup only includes the WAGO Interface Configuration Software.
WAGO Interface Configuration Software FULL
Handling Instructions
Configuring
Configuration via WAGO interface
Hansastr. 27
32423 Minden
03.06.2020 Page 10/10
很抱歉,暂时无法提供与“2857-570/024-005”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+9482.203461+1227.55322
