Data sheet | Item number: 713-1431/107-000
THT male header, 2-row; 0.8 x 0.8 mm solder pin; angled; 100% protected
against mismating; Threaded flange; Pin spacing 3.5 mm; 2 x 11-pole; black
www.wago.com/713-1431_107-000
Color:
Subject to changes.
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
29.12.2019 Page 1/7
L = [(pole no./2) – 1] x pin spacing + 13.6 mm
Item description
Male headers may be mounted horizontally or vertically via straight or angled solder pins
Header housing is molded of THT-compatible insulation material for lead-free reflow soldering
Separated pin slots prevent damage and make the headers touch-proof when unplugged
100% protected against mismating
Coding pins available
Safety information 1:
The MULTI CONNECTION SYSTEM (MCS) is designed without breaking capacity for compliance with DIN EN 61984. When used as intended, MCS
Connectors shall not be connected/disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are
not live when unmated.
Data
Electrical data
Ratings per IEC/EN 60664-1
Rated voltage (III / 3)
80 V
Rated impulse voltage (III / 3)
2.5 kV
Rated voltage (III / 2)
160 V
Rated impulse voltage (III / 2)
2.5 kV
Rated voltage (II / 2)
250 V
Rated impulse voltage (II / 2)
Subject to changes.
Hansastr. 27
32423 Minden
2.5 kV
29.12.2019 Page 2/7
2.5 kV
Rated current
10 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Approvals per UL 1059
Rated voltage UL (Use Group B)
150 V
Rated current UL (Use Group B)
10 A
Rated voltage UL (Use Group C)
50 V
Rated current UL (Use Group C)
10 A
Approvals per CSA
Rated voltage CSA (Use Group B)
150 V
Rated current CSA (Use Group B)
12 A
Connection data
No. of poles
22
Total number of potentials
22
Number of connection types
1
Number of levels
2
Geometrical Data
Pin spacing
3.5 mm / 0.138 inch
Width
48.6 mm / 1.913 inch
Height
17.1 mm / 0.673 inch
Height from the surface
13.3 mm / 0.524 inch
Depth
13.5 mm / 0.531 inch
Solder pin length
3.8 mm
Solder pin dimensions
0.8 x 0.8 mm
Drilled hole diameter (tolerance)
1.2(- … +0.1) mm
Plug connection
Contact type (pluggable connector)
Male connector/plug
Connector connection type
for PCBs
Mismating protection
Yes
Mating direction to the PCB
0 °
Locking of plug-in connection
Threaded flange
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 3/7
PCB contact
PCB contact
THT
Solder pin arrangement
over the entire male connector, in line
Number of solder pins per potential
1
Material Data
Color
black
Material group
I
Insulating material
Polyphthalamide (PPA GF)
Flammability class per UL94
V0
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Fire load
0.125 MJ
Weight
6.6 g
Environmental Requirements
Limit temperature range
-60 … +100 °C
Commercial data
Product Group
3 (Multi Conn. System)
Packaging type
BOX
Country of origin
PL
GTIN
4045454809188
Customs Tariff No.
85366990990
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CCA
DEKRA Certification B.V.
IEC 61984
NL-30980
CCA
EN 61984
2169947.01
CSA
C22.2 No. 158
2315087
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 4/7
UL-Approvals
Logo
Approval
UL
Underwriters Laboratories Inc.
UL 1059
Certificate
name
20190122E45172
Compatible products
Coding
Item no.: 714-101
Coding key; orange
www.wago.com/714-101
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
3.6 MB
Download
URL
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 713-1431/107-000
PCB Design
Symbol and Footprint 713-1431/107-000
CAx data for your PCB design, consisting of "schematic symbols and PCB footprints",
allow easy integration of the WAGO component into your development environment.
Supported formats:
Accel EDA 14 & 15
Altium 6 to current version
Cadence Allegro
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 5/7
Cadence Allegro
DesignSpark
Eagle Libraries
KiCad
Mentor Graphics BoardStation
Mentor Graphics Design Architect
Mentor Graphics Design Expedition 99 and 2000
OrCAD 9.X PCB and Capture
PADS PowerPCB 3, 3.5, 4.X, and 5.X
PADS PowerPCB and PowerLogic 3.0
PCAD 2000, 2001, 2002, 2004, and 2006
Pulsonix 8.5 or newer
STL
3D STEP
TARGET 3001!
View Logic ViewDraw
Quadcept
Zuken CadStar 3 and 4
Zuken CR-5000 and CR-8000
PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian
Installation Notes
Coding
Coding a male header by inserting a coding
pin.
Product family
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 6/7
MCS MINI HD
Show all products from the family
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 7/7
很抱歉,暂时无法提供与“713-1431/107-000”相匹配的价格&库存,您可以联系我们找货
