Printview: Male connector; with angled solder pins; 2-pole; pin spacing 5 mm / 0.197 in; 100% protected
against mismating; without preceding ground contact; with closed end; Horizontal PCB mounting - Item No.:
721-432/001-000
/ 0.197 in; 100% protected against mismating; without preceding
Item No.: 721-432/001-000
Male connector; with angled solder pins; 2-pole; pin spacing 5 mm / 0.197 in; 100% protected against mismating;
Marking
Business data
Supplier
WAGO
Item no.
721-432/001-000
GTIN / EAN
4044918869492
Content
1
Order amount
200
Customer item number
Notes
Version with press-in pins provides solder-free connection to PCB100% protected against mismating Coding option
available
Technical data
Miscellaneous
No. of poles
2
Pin Spacing
5 mm / 0.197 in %
Color
light gray
Ratings according to 1
IEC/EN 60664-1
Overvoltage category EN 1
III
Pollution degree (1)
2
WAGO Kontakttechnik GmbH & Co. KG
1
721-432/001-000
Technical data
Rated voltage EN (1) [V]
320 [V]
Rated surge voltage (1) [kV]
4 [kV]
Nominal current [A]
12 [A]
Overvoltage category EN 2
II
Degree of pollution (2)
2
Rated voltage EN (2) [V]
630 [V]
Rated surge voltage (2) [kV]
4 [kV]
Nominal current (2) [A]
12 [A]
Overvoltage category EN 3
III
Degree of pollution (3)
3
Rated voltage EN (3) [V]
320 [V]
Rated surge voltage (3) [kV]
4 [kV]
Nominal current (3) [A]
12 [A]
Solder pin length [mm]
3.8 [mm]
Solder pin width A [mm]
1 [mm]
Solder pin width B [mm]
1 [mm]
Tolerance of drilled hole [mm]
1.4(+ 0.1) [mm]
Material group
I
Insulating material
Polyamide 66 (PA 66)
Flammability rating per UL 94
V0
Limit temperature range
-60 C … 100 C
Contact material
Electrolytic copper (Ecu)
Contact plating
tin-plated
Fire load [MJ]
0.018 [MJ]
Weight [g]
0.88 [g]
Width
13.2 mm / 0.52 in
Height
15.2 mm / 0.598 in
Height from the surface
11.4 mm / 0.449 in
Length
12 mm / 0.472 in
2
721-432/001-000
Images & drawings
3
721-432/001-000
Address
Hansastr. 27
32423 Minden
Telefon: 0571/887-0
Fax: 0571/887-169
http://www.wago.com
© WAGO Kontakttechnik GmbH & Co. KG
Technische Änderungen und Irrtümer vorbehalten.
4
很抱歉,暂时无法提供与“721-432/001-000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 20+4.9782420+0.60051
- 50+4.9549850+0.59771
- 200+4.95487200+0.59770
- 500+4.95476500+0.59768
- 2000+4.954662000+0.59767
