Data sheet | Item number: 726-601
Common potential matrix patchboard; Marking 1-24; with 1 input module
incl. end plate; Color of modules: gray; Numbering of modules arranged
vertically; for 19" racks; Slimline version; 2,50 mm²; dark gray
www.wago.com/726-601
Dimensions in mm
Common potential matrix patchboards – slimline version, for
19” racks
Color:
Data
Electrical data
Ratings per IEC/EN 60664-1
Rated current
24 A
Rated current (2)
76 A
Connection data
Connection type (1)
Side 1
Connection technology
CAGE CLAMP®
Number of connection points (connection type)
Subject to changes.
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
2
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
29.12.2019 Page 1/7
2
Actuation type
Operating tool
Connectable conductor materials
Copper
Solid conductor
0.08 … 2.5 mm² / 28 … 14 AWG
Fine-stranded conductor
Strip length
8 … 10 mm / 0.31 … 0.39 inch
Connection type (2)
Side 2
1
Solid conductor (2)
0.2 … 16 mm² / 24 … 6 AWG
Fine-stranded conductor (2)
Strip length (2)
16 … 17 mm / 0.63 … 0.67 inch
Type of wiring
Front-entry wiring
Geometrical Data
Width
34.6 mm / 1.362 inch
Height
132 mm / 5.197 inch
Depth
80.7 mm / 3.177 inch
Mechanical data
Design
slimline
Marking
1 … 24
Material Data
Color
dark gray
Module color
gray
Fire load
1.95 MJ
Weight
203.7 g
Commercial data
Product Group
12 (Matrix Patch Board)
Packaging type
BOX
Country of origin
DE
GTIN
4055143628662
Customs Tariff No.
85369010000
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 2/7
Approvals / Certificates
Country specific Approvals
Logo
Certificate
name
Approval
Additional Approval Text
CCA
DEKRA Certification B.V.
EN 60998
NTR NL7623
CSA
C22.2 No. 158
1101143
KEMA/KEUR
EN 60998
71100850
Approval
Certificate
name
UL
UL International Germany GmbH
UL 1059
E45172
UL-Approvals
Logo
Compatible products
General accessories
Item no.: 726-902
Adaptor
www.wago.com/726-902
Marking accessories
Item no.: 2009-110
Marking strips; on reel; not stretchable; plain; snap-on type; white
www.wago.com/2009-110
Item no.: 2009-115
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; white
www.wago.com/2009-115
Item no.: 209-185
Adaptor
www.wago.com/209-185
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 3/7
Adaptor
Item no.: 210-612
Marking strips; for self-marking; plain; Self-adhesive; transparent
www.wago.com/210-612
Item no.: 726-905
Adaptor
www.wago.com/726-905
Item no.: 793-5501
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501
type; white
Item no.: 793-5501/000-002
/000-002
type; yellow
Item no.: 793-5501/000-005
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; red
/000-005
Item no.: 793-5501/000-006
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; blue
/000-006
Item no.: 793-5501/000-007
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; gray
/000-007
Item no.: 793-5501/000-012
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; orange
/000-012
Item no.: 793-5501/000-014
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; brown
/000-014
Item no.: 793-5501/000-017
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; light green
/000-017
Item no.: 793-5501/000-023
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; green
/000-023
Item no.: 793-5501/000-024
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; violet
/000-024
Item no.: 210-137
Test plug; 2.3 mm Ø; with 500 mm cable; yellow
www.wago.com/210-137
check
Jumper
Item no.: 709-107
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 4/7
Item no.: 709-107
Wire commoning chain; insulated; 32 connections; gray
www.wago.com/709-107
Downloads
Documentation
Bid Text
726-601
Feb 21, 2019
docx
15.1 kB
Download
Feb 19, 2019
xml
3.5 kB
Download
Apr 3, 2019
pdf
2.1 MB
Download
URL
Download
docx - Datei
726-601
X81 - Datei
Additional Information
Technical explanations
CAD/CAE-Data
CAD data
2D/3D Models 726-601
CAE data
EPLAN Data Portal 726-601
Download
WSCAD Universe 726-601
Download
Installation Notes
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 5/7
CAGE CLAMP® connection
Inserting a conductor via 210‑719 Operating
Tool (2.5 x 0.4 mm blade).
Testing with a 2.3 mm Ø test plug (210‑137).
Snapping on an additional module with
contact to mounting frame.
Assembling a matrix patchboard with
additional module – direct connection to the
mounting frame.
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 6/7
Factory-marked modules
WFB continuous marking strip – fits into the
matrix patchboards’ marker slot and group
marker carrier.
Individual group marking via WSB Quick
Marking System.
Side 1: 1, 2, 3, 4 …
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 7/7
很抱歉,暂时无法提供与“726-601”相匹配的价格&库存,您可以联系我们找货
