733-104
733-104
    WAGO(万可电子)
    P=2.5mm
    接线端子 间距:2.50mm 1x4P
733-104 数据手册
Printview: Female connector; codable; 4-pole; pin spacing 2.5 mm / 0.098 in; 100% protected against mismating - Item No.: 733-104 . Female connector; codable; 4-pole; pin spacing 2.5 mm / 0.098 in; 100% protected against mismating Item No.: 733-104 . Female connector; codable; 4-pole; pin spacing 2.5 mm / 0.098 in; 100% protected against mismating . Marking . Business data Supplier WAGO Item no. 733-104 GTIN / EAN 4044918294003 Content 1 Order amount 200 Customer item number . Notes Universal connection for all conductor typesEasy cable pre-assembly and on-unit wiring via vertical and horizontal CAGE CLAMP® actuationStrain relief plates, factory assembled or in-the-field installation100% protected against mismatingCoding option available Technical data Miscellaneous No. of poles 4 Pin Spacing 2.5 mm / 0.098 in % Total number of connection points 4 Total number of potentials 4 Color light gray Ratings according to 1 IEC/EN 60664-1 Overvoltage category EN 1 III WAGO Kontakttechnik GmbH & Co. KG 1 Printview: Female connector; codable; 4-pole; pin spacing 2.5 mm / 0.098 in; 100% protected against mismating - Item No.: 733-104 Technical data Pollution degree (1) 2 Rated voltage EN (1) [V] 160 [V] Rated surge voltage (1) [kV] 2.5 [kV] Nominal current [A] 6 [A] Overvoltage category EN 2 II Degree of pollution (2) 2 Rated voltage EN (2) [V] 320 [V] Rated surge voltage (2) [kV] 2.5 [kV] Nominal current (2) [A] 6 [A] Overvoltage category EN 3 III Degree of pollution (3) 3 Rated voltage EN (3) [V] 100 [V] Rated surge voltage (3) [kV] 2.5 [kV] Nominal current (3) [A] 6 [A] Number of individual connection objects at the product 1 Connection technology (1) CAGE CLAMP® Solid sizes 1 0.08 … 0.5 mm² / 28 … 20 AWG Fine-stranded wires 1 0.08 … 0.5 mm² / 28 … 20 AWG Fine-stranded wires with insulated ferrule 1 0.25 … 0.34 mm² / … Fine-stranded wires with uninsulated ferrule 1 0.25 … 0.34 mm² / … Strip length 1 5 … 6 mm / 0.2 … 0.24 in Material group I Insulating material Polyamide 66 (PA 66) Flammability rating per UL 94 V0 Limit temperature range -60 C … 100 C Clamping spring material Chrome-nickel spring steel (CrNi) Contact material Copper alloy Contact plating tin-plated Fire load [MJ] 0.034 [MJ] Weight [g] 1.807 [g] Width 12.1 mm / 0.476 in Height 11.8 mm / 0.465 in Length 17.1 mm / 0.673 in WAGO Kontakttechnik GmbH & Co. KG 2 Printview: Female connector; codable; 4-pole; pin spacing 2.5 mm / 0.098 in; 100% protected against mismating - Item No.: 733-104 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 3 Printview: Female connector; codable; 4-pole; pin spacing 2.5 mm / 0.098 in; 100% protected against mismating - Item No.: 733-104 . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 4
733-104 价格&库存
很抱歉,暂时无法提供与“733-104”相匹配的价格&库存,您可以联系我们找货
    • 1+10.91310
    • 200+9.82190
    • 400+9.82080
    库存:91
