734-106
734-106
    WAGO(万可电子)
734-106 数据手册
Data sheet from 18.07.2013 Item no.: 734-106 Product description: FEMALE CONNECTOR 6 POLE PIN SPACING 3.5 MM / 0.138 IN 100% PROTECTED AGAINST MISMATING WITH CODING FINGERS Produkt kann von Bild abweichen / product may differ Packing unit 100 pieces RoHS compliant Product group 3 (Multi Conn. System) Weight 4.737 g Color light gray No. of connection Points 6 No. of potentials 6 pole count 6 Height 13.4 mm Height 0.528 in Width 23.2 mm Width 0.913 in Depth 18.6 mm Depth 0.732 in Pin spacing from 3.5 mm Pin spacing from 0.138 in Pollution degree 2 Measured voltage EN 160 V Measured shock voltage 2.5 kV Current intensity EN 1 von 4 10 A Pollution degree 2 Measured voltage EN 320 V Measured shock voltage 2.5 kV Current intensity EN 10 A 2 von 4 Data sheet from 18.07.2013 Connection method CAGE CLAMP® CONNECTION Cross section [mm²] 0.08 - 1.5 mm² Wiring method solid Cross section [mm²] 0.08 - 1.5 mm² Cross section [mm²] 0.25 - 1.5 mm² Cross section [mm²] 0.25 - 1.5 mm² Cross section [AWG] 28 - 14 AWG Strip length from 6 mm Strip length to 7 mm Material group I xxx-xxx/033-000 Strain relief plate 12,5 mm 3 von 4 Data sheet from 18.07.2013 Item no. Admission office Approval no. Voltage [V] Current [A] Cross section [ mm² ] 734-106 ABS 04-HG469925/1-PDA 250 10 0,5-1,5 734-106 BV 11915/A0 250 10 0,5-1,5 734-106 CCA NL5641 250 10 0,5-1,5 734-106 CSA 154112-1465035 300 10 28-14 734-106 DNV E-9218 250 10 0,5-1,5 734-106 GL 17296-00HH 250 10 0,5-1,5 734-106 KEMA 2077592.02 250 10 0,5-1,5 734-106 LR 96/20035 250 10 0,5-1,5 734-106 RMR 11130002 250 10 0,5-1,5 734-106 UR E45171 250 10 28-14 734-106 UR E45172 300 10 28-14 Sorting criteria: admission office - approval number © WAGO Kontakttechnik GmbH & Co. KG Specifications are subject to changes and errors may be expected 4 von 4
734-106 价格&库存
很抱歉,暂时无法提供与“734-106”相匹配的价格&库存,您可以联系我们找货
  • 10+96.8839510+12.55801
  • 25+69.3489625+8.98895
  • 100+67.19256100+8.70944
库存:100
734-106
  • 1+72.891711+9.44816
  • 10+62.5646110+8.10957
  • 25+57.5932825+7.46519
  • 50+40.0581750+5.19231
  • 100+39.00801100+5.05618
  • 250+37.32409250+4.83792
  • 500+36.25562500+4.69942
  • 1000+35.703871000+4.62790
库存:95
734-106
    • 13+82.1697513+10.65077
    • 25+72.6737125+9.41990
    • 50+48.8356550+6.33003
    • 100+47.05027100+6.09861
    • 250+44.26364250+5.73741
    • 500+42.55278500+5.51565
    • 1000+41.685201000+5.40320
    库存:100
    734-106
      • 2+74.350052+9.63719
      • 10+63.8159610+8.27177
      • 25+58.7450325+7.61448
      • 50+40.8589350+5.29610
      • 100+39.78802100+5.15729
      • 250+38.06987250+4.93458
      • 500+36.98034500+4.79336
      • 1000+36.417341000+4.72038
      库存:94
