737-108
737-108
    WAGO(万可电子)
    插件
    接线端子
737-108 数据手册
Data sheet  |  Item number: 737-108 Triple-deck PCB terminal block; 2.5 mm²; Pin spacing 5 mm; 3 x 8-pole; CAGE CLAMP®; 2,50 mm²; gray www.wago.com/737-108 Color: Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 28.12.2019    Page 1/12 Data sheet  |  Item number: 737-108 www.wago.com/737-108 (1) Solder pins in a row L = (pole no. x pin spacing) + 1 mm Item description PCB terminal strips with screwdriver-actuated CAGE CLAMP® High-density, double-deck design for space-efficient wiring of multiple conductors in confined areas Custom marking for all termination levels Data Electrical data Ratings per IEC/EN 60664-1 Ratings note Between the modules Rated voltage (III / 3) 250 V Rated impulse voltage (III / 3) 4 kV Rated voltage (III / 2) 320 V Rated impulse voltage (III / 2) 4 kV Rated voltage (II / 2) 630 V Rated impulse voltage (II / 2) 4 kV Rated current 21 A Ratings according to 2 IEC/EN 60664-1 Ratings note 2 Between the decks Rated voltage (III / 3) 2 320 V Rated impulse voltage (III / 3) 2 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com 4 kV Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 28.12.2019    Page 2/12 Data sheet  |  Item number: 737-108 www.wago.com/737-108 Rated impulse voltage (III / 3) 2 4 kV Rated voltage (III / 2) 2 320 V Rated impulse voltage (III / 2) 2 4 kV Rated voltage (II / 2) 2 630 V Rated impulse voltage (II / 2) 2 4 kV Rated current (2) 21 A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Approvals per UL 1059 Rated voltage UL (Use Group B) 300 V Rated current UL (Use Group B) 10 A Rated voltage UL (Use Group D) 300 V Rated current UL (Use Group D) 10 A Approvals per CSA Rated voltage CSA (Use Group B) 300 V Rated current CSA (Use Group B) 10 A Rated voltage CSA (Use Group D) 300 V Rated current CSA (Use Group D) 10 A Connection data Connection technology CAGE CLAMP® Actuation type Operating tool Solid conductor 0.08 … 2.5 mm² / 28 … 12 AWG Fine-stranded conductor 0.08 … 2.5 mm² / 28 … 12 AWG Fine-stranded conductor with ferrule with plastic collar 0.25 … 1.5 mm² Fine-stranded conductor with ferrule without plastic collar 0.25 … 2.5 mm² Strip length 5 … 6 mm / 0.2 … 0.24 inch Conductor entry angle to the PCB 45 ° No. of poles 8 Total number of connection points 24 Total number of potentials 24 Number of connection types 1 Number of levels 3 Note (conductor cross-section) 12 AWG: THHN, THWN Geometrical Data Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 28.12.2019    Page 3/12 Data sheet  |  Item number: 737-108 www.wago.com/737-108 Geometrical Data Pin spacing 5 mm / 0.197 inch Width 41 mm / 1.614 inch Height 44 mm / 1.732 inch Height from the surface 40 mm / 1.575 inch Depth 31 mm / 1.22 inch Solder pin length 4 mm Solder pin dimensions 0.7 x 0.7 mm Drilled hole diameter (tolerance) 1.3(- … +0.1) mm PCB contact PCB contact THT Solder pin arrangement within the terminal block, in line Number of solder pins per potential 1 Material Data Color gray Material group I Insulating material Polyamide 66 (PA 66) Flammability class per UL94 V0 Clamping spring material Chrome nickel spring steel (CrNi) Contact material Electrolytic copper (ECu) Contact plating tin-plated Fire load 0.494 MJ Weight 33.7 g Environmental Requirements Limit temperature range -60 … +105 °C Commercial data Product Group 4 (Printed Circuit) Packaging type BOX Country of origin PL GTIN 4045454021740 Customs Tariff No. 85369010000 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 28.12.2019    Page 4/12 Data sheet  |  Item number: 737-108 www.wago.com/737-108 Approvals / Certificates Country specific Approvals Logo Certificate name Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60947 NTR NL7150 CCA DEKRA Certification B.V. EN 60947-7-4 2169331.28 CCA DEKRA Certification B.V. EN 60947-7-4 NTR NL 7445 CSA DEKRA Certification B.V. C22.2 No. 158 70049157 Approval Additional Approval Text ABS American Bureau of Shipping - 19HG1869876PDA DNV GL Det Norske Veritas, Germanischer Lloyd - TAE000016Z Ship Approvals Logo Certificate name UL-Approvals Logo Approval Additional Approval Text UR Underwriters Laboratories Inc. UL 1059 Certificate name E45172, sec. 6 Compatible products Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 28.12.2019    Page 5/12 Data sheet  |  Item number: 737-108 www.wago.com/737-108 Compatible products tools Item no.: 210-657 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; short www.wago.com/210-657 Item no.: 210-658 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; angled; short www.wago.com/210-658 Item no.: 210-720 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft www.wago.com/210-720 check Item no.: 231-126 Testing plug module with contact stud; for 280, 736, 737, 738, 780 Series; Pin spacing 5 mm / 0.197 in; www.wago.com/231-126 2,50 mm²; gray Item no.: 231-155 Testing plug module with contact stud; Pin spacing 5 mm / 0.197 in; 2,50 mm²; gray www.wago.com/231-155 Item no.: 216-101 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated www.wago.com/216-101 Item no.: 216-102 Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated www.wago.com/216-102 Item no.: 216-103 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated www.wago.com/216-103 Item no.: 216-104 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated www.wago.com/216-104 Item no.: 216-106 Ferrule; Sleeve for 2.5 mm² / AWG 14; uninsulated; electro-tin plated www.wago.com/216-106 Item no.: 216-121 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated www.wago.com/216-121 Item no.: 216-122 Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated www.wago.com/216-122 Item no.: 216-123 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated www.wago.com/216-123 Item no.: 216-124 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated www.wago.com/216-124 Item no.: 216-131 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-131 ferrule Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 28.12.2019    Page 6/12 Data sheet  |  Item number: 737-108 www.wago.com/737-108 Item no.: 216-132 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-132 Item no.: 216-141 Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-141 Item no.: 216-142 Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-142 Item no.: 216-143 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-143 Item no.: 216-144 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-144 Item no.: 216-151 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-151 Item no.: 216-152 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-152 Item no.: 216-201 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white www.wago.com/216-201 Item no.: 216-202 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray www.wago.com/216-202 Item no.: 216-203 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red www.wago.com/216-203 Item no.: 216-204 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black www.wago.com/216-204 Item no.: 216-221 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white www.wago.com/216-221 Item no.: 216-222 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray www.wago.com/216-222 Item no.: 216-223 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red www.wago.com/216-223 Item no.: 216-224 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black www.wago.com/216-224 Item no.: 216-241 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; white www.wago.com/216-241 Item no.: 216-242 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-242 Item no.: 216-243 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 28.12.2019    Page 7/12 Data sheet  |  Item number: 737-108 www.wago.com/737-108 Item no.: 216-243 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243 acc. to DIN 46228, Part 4/09.90; red Item no.: 216-244 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-244 Item no.: 216-262 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-262 Item no.: 216-263 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263 acc. to DIN 46228, Part 4/09.90; red Item no.: 216-264 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-264 Item no.: 216-284 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-284 Item no.: 216-301 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-301 Item no.: 216-302 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-302 Item no.: 216-321 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-321 Item no.: 216-322 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-322 Marking accessories Item no.: 210-332/500-202 www.wago.com/210-332 Marking strips; as a DIN A4 sheet; MARKED; 1-16 (160x); Height of marker strip: 3 mm; Strip length 182 /500-202 mm; Horizontal marking; Self-adhesive; white Item no.: 210-332/500-204 Marking strips; as a DIN A4 sheet; MARKED; 17-32 (160x); Height of marker strip: 3 mm; Strip length 182 mm; Horizontal marking; Self-adhesive; white www.wago.com/210-332 /500-204 Item no.: 210-332/500-205 Marking strips; as a DIN A4 sheet; MARKED; 1-32 (80x); Height of marker strip: 3 mm; Strip length 182 mm; Horizontal marking; Self-adhesive; white www.wago.com/210-332 /500-205 Item no.: 210-332/500-206 Marking strips; as a DIN A4 sheet; MARKED; 33-48 (160x); Height of marker strip: 3 mm; Strip length 182 mm; Horizontal marking; Self-adhesive; white www.wago.com/210-332 /500-206 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 28.12.2019    Page 8/12 Data sheet  |  Item number: 737-108 www.wago.com/737-108 Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 3.6 MB Download URL Download CAD/CAE-Data CAD data 2D/3D Models 737-108 CAE data EPLAN Data Portal 737-108 Download PCB Design Symbol and Footprint 737-108 URL Download CAx data for your PCB design, consisting of "schematic symbols and PCB footprints", allow easy integration of the WAGO component into your development environment. Supported formats: Accel EDA 14 & 15 Altium 6 to current version Cadence Allegro DesignSpark Eagle Libraries KiCad Mentor Graphics BoardStation Mentor Graphics Design Architect Mentor Graphics Design Expedition 99 and 2000 OrCAD 9.X PCB and Capture PADS PowerPCB 3, 3.5, 4.X, and 5.X PADS PowerPCB and PowerLogic 3.0 PCAD 2000, 2001, 2002, 2004, and 2006 Pulsonix 8.5 or newer STL 3D STEP Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 28.12.2019    Page 9/12 Data sheet  |  Item number: 737-108 www.wago.com/737-108 3D STEP TARGET 3001! View Logic ViewDraw Quadcept Zuken CadStar 3 and 4 Zuken CR-5000 and CR-8000 PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian Installation Notes Inserting a conductor Inserting a conductor via 3.5 mm screwdriver. Screwdriver actuation parallel to conductor entry. Application Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 28.12.2019    Page 10/12 Data sheet  |  Item number: 737-108 www.wago.com/737-108 Low space requirements due to high-density design – double-deck PCB terminal strip – 736 Series. Possible combination: Possible combination: Double- (736 Series) and triple-deck PCB terminal strips (737 Series) upon request Double- (736 Series) and triple-deck PCB terminal strips (737 Series) upon request Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 28.12.2019    Page 11/12 Data sheet  |  Item number: 737-108 www.wago.com/737-108 Possible combination: Possible combination: Double- (737 Series) and quadruple-deck PCB terminal strips (738 Series) upon request Double- (737 Series) and quadruple-deck PCB terminal strips (738 Series) upon request Testing Testing via contact area above the conductors. Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 28.12.2019    Page 12/12
737-108 价格&库存
很抱歉,暂时无法提供与“737-108”相匹配的价格&库存,您可以联系我们找货
