Data sheet from 17.09.2013
Item no.:
773-168
Product description:
PUSH-WIRE CONNECTOR FOR JUNCTION BOXES 8CONDUCTOR TERMINAL BLOCK Cover, dark gray
Produkt kann von Bild abweichen / product may differ
Packing unit 50 pieces
RoHS compliant
Product group
7 (Push Wire Conn.)
pole count
8
Cross section [mm²]
0.75 - 2.5 mm²
Cross section [AWG]
18 - 12 AWG
Wiring method
e
Connection method
PUSH WIRE®
Cross section [mm²]
1.5 - 2.5 mm²
Cross section [AWG]
16 - 12 AWG
Wiring method
st
Connection method
PUSH WIRE®
Measured voltage EN
400 V
Measured shock voltage
4 kV
Pollution degree
2
Current intensity EN
24 A
Weight
5g
Color
dark gray
No. of connection Points
8
No. of potentials
1
Height
1 von 3
13.1 mm
Height
0.516 in
Width
24 mm
Width
0.945 in
2 von 3
Depth
19.5 mm
Depth
0.768 in
Strip length from
12 mm
Strip length to
12 mm
Strip length
0.47 in
© WAGO Kontakttechnik GmbH & Co. KG
Specifications are subject to changes and errors may be expected
3 von 3
很抱歉,暂时无法提供与“773-168/K194-4045”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+134.444971+17.37691
