Printview: 4-conductor ground terminal block; suitable for Ex e II applications - Item No.: 2004-1407
Item No.: 2004-1407
Marking
Business data
Supplier
WAGO
Item no.
2004-1407
GTIN / EAN
4017332071833
Content
1
Order amount
50
Customer item number
Notes
Technical data
Miscellaneous
Total number of connection points
4
Total number of potentials
1
Color
green-yellow
Connection technology (1)
Push-in CAGE CLAMP®
Nominal cross section 1
4 mm²
Solid sizes 1
0.5 … 6 mm² / 20 … 10 AWG
solid, directly pluggable 1
1 … 6 mm² / 14 … 10 AWG
Fine-stranded wires 1
min. fine-stranded with insulated ferrule, push-in terminati 0.75 mm² / 18 AWG
Strip length 1
11 … 13 mm / 0.43 … 0.51 in
WAGO Kontakttechnik GmbH & Co. KG
1
Technical data
Type of wiring
Front-entry wiring
Design
horizontal
Marking level
Center/Side marking
Insulating material
Polyamide 66 (PA 66)
Fire load [MJ]
0.174 [MJ]
Weight [g]
16.718 [g]
Width
6.2 mm / 0.244 in
Height from upper-edge of DIN-rail [mm]
32.9 [mm]
32.9 mm / 1.295 in
Length
78.7 mm / 3.098 in
Type of mounting
DIN 35 rail
2
Images & drawings
3
Address
Hansastr. 27
32423 Minden
Telefon: 0571/887-0
Fax: 0571/887-169
http://www.wago.com
© WAGO Kontakttechnik GmbH & Co. KG
Technische Änderungen und Irrtümer vorbehalten.
4
很抱歉,暂时无法提供与“2004-1407”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+144.099511+17.93167
- 10+102.6260810+12.77074
- 25+91.2778225+11.35857
- 50+84.4866650+10.51348
- 100+79.02542100+9.83389
- 250+73.50164250+9.14651
- 500+70.35561500+8.75502
- 1000+67.908741000+8.45053
- 国内价格 香港价格
- 1+71.538391+8.90220
- 5+70.646395+8.79120
- 25+69.7543925+8.68020
- 50+69.3083950+8.62470
- 150+68.14879150+8.48040
- 国内价格
- 10+31.75388
- 100+31.11759
