2006-1611
    WAGO(万可电子)
    端子块连接器 2 位置 断连 灰色 8-14 AWG
2006-1611 数据手册
Printview: 2-conductor fuse disconnect terminal block with pivoting fuse holder; for 5 x 20 mm miniature metric fuse; without blown fuse indication - Item No.: 2006-1611 . 2-conductor fuse disconnect terminal block with pivoting fuse holder; for 5 x 20 mm miniature metric fuse; without blown fuse indication Item No.: 2006-1611 . 2-conductor fuse disconnect terminal block with pivoting fuse holder; for 5 x 20 mm miniature metric fuse; without blown fuse indication . Marking . Business data Supplier WAGO Item no. 2006-1611 GTIN / EAN 4045454821166 Content 1 Order amount 25 Customer item number . Notes Technical data Miscellaneous Total number of connection points 2 Total number of potentials 1 Color gray Ratings according to 1 IEC/EN 60947-7-3 Pollution degree (1) 3 Rated voltage EN (1) [V] 800 [V] Rated surge voltage (1) [kV] 8 [kV] Nominal current [A] 10 [A] WAGO Kontakttechnik GmbH & Co. KG 1 Printview: 2-conductor fuse disconnect terminal block with pivoting fuse holder; for 5 x 20 mm miniature metric fuse; without blown fuse indication - Item No.: 2006-1611 Technical data Connection technology (1) Push-in CAGE CLAMP® Nominal cross section 1 6 mm² Solid sizes 1 0.5 … 10 mm² / 20 … 8 AWG solid, directly pluggable 1 1 … 10 mm² / 14 … 8 AWG Fine-stranded wires 1 0.5 … 10 mm² / 20 … 8 AWG min. fine-stranded with insulated ferrule, push-in terminati 1.5 mm² / 16 AWG Strip length 1 13 … 15 mm / 0.51 … 0.59 in Type of wiring Front-entry wiring Design horizontal Marking level Center/Side marking Insulating material Polyamide 66 (PA 66) Fire load [MJ] 0.46 [MJ] Weight [g] 24.979 [g] Width 7.5 mm / 0.295 in Height from upper-edge of DIN-rail [mm] 59 [mm] Height from upper-edge of DIN-rail 59 mm / 2.323 in Length 96.3 mm / 3.791 in Type of mounting DIN 35 rail Safety information 1 Electrical ratings are given by the fuse. WAGO Kontakttechnik GmbH & Co. KG 2 Printview: 2-conductor fuse disconnect terminal block with pivoting fuse holder; for 5 x 20 mm miniature metric fuse; without blown fuse indication - Item No.: 2006-1611 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 3 Printview: 2-conductor fuse disconnect terminal block with pivoting fuse holder; for 5 x 20 mm miniature metric fuse; without blown fuse indication - Item No.: 2006-1611 . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 4
2006-1611 价格&库存
很抱歉,暂时无法提供与“2006-1611”相匹配的价格&库存,您可以联系我们找货
    • 2+46.651592+5.80530
    • 10+45.4919910+5.66100
    • 30+44.7783930+5.57220
    • 75+44.1539975+5.49450
    • 200+42.81599200+5.32800
      • 1+727.97928
      库存:65
      2006-1611
        • 1+2320.78607
        库存:65
        2006-1611
          • 1+95.800781+11.92140
          • 4+94.641184+11.77710
          • 20+93.3031820+11.61060
          • 40+92.7679840+11.54400
          • 125+91.25158125+11.35530
          库存:40
