2050-0301
2050-0301
    WAGO(万可电子)
    WAGO - 2050-0301 - TERMINAL BLOCK, DIN RAIL, 2POS, 16AWG
2050-0301 数据手册
Data sheet | Item number: 2050-301 2-conductor miniature through terminal block; with operating slots; 1 mm²; with test port; side and center marking; End terminal block with mounting flange; Push-in CAGE CLAMP®; 1,00 mm²; gray www.wago.com/2050-301 Color: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 12.07.2021    Page 1/14 Data sheet | Item number: 2050-301 www.wago.com/2050-301 Data Electrical data Ratings per IEC/EN Ratings per IEC/EN 60947-7-1 Nominal voltage (III/3) 500 V Rated surge voltage (III/3) 6 kV Rated current 13.5 A Rated current 2 17.5 A Legend (ratings) (III / 3) ≙ Overvoltage category III / Pollution degree 3 Ratings per UL Approvals per UL 1059 Rated voltage UL (Use Group B) 300 V Rated current UL (Use Group B) 10 A Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 12.07.2021    Page 2/14 Data sheet | Item number: 2050-301 www.wago.com/2050-301 Rated current UL (Use Group B) 10 A Rated voltage UL (Use Group C) 300 V Rated current UL (Use Group C) 10 A Ratings per CSA Approvals per C22.2 No 158 Rated voltage CSA (Use Group B) 300 V Rated current CSA (Use Group B) 10 A Rated voltage CSA (Use Group C) 300 V Rated current CSA (Use Group C) 10 A Ex information Ratings per ATEX: PTB 19 ATEX 1019 U / IECEx: PTB 19.0050U (Ex eb IIC Gb) Rated voltage EN (Ex e II) 352 V Rated current (Ex e II) 13.5 A Rated current (Ex e II) with jumper 12 A Connection data Connection technology Push-in CAGE CLAMP® Actuation type Push-in Operating tool Connectable conductor materials Copper Copper Nominal cross-section 1 mm² Solid conductor 0.14 … 1.5 mm² / 24 … 16 AWG Solid conductor; push-in termination 0.5 … 1.5 mm² / 20 … 16 AWG Fine-stranded conductor 0.14 … 1.5 mm² / 24 … 16 AWG Fine-stranded conductor; with insulated ferrule 0.14 … 0.75 mm² / 24 … 18 AWG Fine-stranded conductor; with ferrule; push-in termination 0.5 … 0.75 mm² / 20 … 18 AWG Note (conductor cross-section) Depending on the conductor characteristic, a conductor with a smaller cross-section can also be inserted via push-in termination. Strip length 9 … 11 mm / 0.35 … 0.43 inch Total number of connection points 2 Total number of potentials 1 Number of levels 1 Wiring direction Front-entry wiring Number of jumper slots 1 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 12.07.2021    Page 3/14 Data sheet | Item number: 2050-301 www.wago.com/2050-301 Physical data Width 3.5 mm / 0.138 inch Height from the surface 27.2 mm / 1.071 inch Depth 33.2 mm / 1.307 inch Mechanical data Design horizontal type Mounting type Mounting flange Marking level Center/side marking Material data Color gray Insulation material Polyamide (PA66) Flammability class per UL94 V0 Weight 2.5 g Commercial data Packaging type BOX Country of origin DE GTIN 4055143968645 Customs tariff number 85369010000 Approvals / Certificates Ex-Approvals Logo Approval Additional Approval Text Certificate name AEx Underwriters Laboratories Inc. UL 60079 E185892 ATEX Physikalisch Technische Bundesanstalt EN IEC 60079-0 PTB 19 ATEX 1019 U (II 2G Ex eb IIC Gb or I M 2 EX eb I Mb) CCCEx CQST/CNEx CNCA-C23-01 2020312313000289 IECEx IEC 60079 IECEx PTB 19.0050 Physikalisch Technische Bundesanstalt Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com U (Ex eb IIC Gb or Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 12.07.2021    Page 4/14 Data sheet | Item number: 2050-301 www.wago.com/2050-301 Physikalisch Technische Bundesanstalt U (Ex eb IIC Gb or EX eb I Mb) Country specific Approvals Logo Certificate name Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60998 NTR NL 7840 CSA CSA C22.2 No. 158 80034182 KEMA/KEUR DEKRA Certification B.V. EN 60998 71113957 Approval Additional Approval Text cURus Underwriters Laboratories Inc. UL 1059 UL-Approvals Logo Certificate name E4517220200212 Counterpart Item no.2050-321 www.wago. 2-conductor miniature through terminal block; with operating slots; 1 mm²; with test port; side and center marking; com/2050Center terminal block without snap-in mounting foot, without mounting flange; Push-in CAGE CLAMP®; 1,00 mm²; gray 321 Required accessories End plate Item no.: 2050-381 End plate; with fixing flange; 1.3 mm thick; gray www.wago.com/2050-381 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 12.07.2021    Page 5/14 Data sheet | Item number: 2050-301 www.wago.com/2050-301 Optional accessories Marking accessories Item no.: 2009-113 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; white www.wago.com/2009-113 Item no.: 2009-113/000-002 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; yellow www.wago.com/2009-113 /000-002 Item no.: 2009-113/000-005 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; red www.wago.com/2009-113 /000-005 Item no.: 2009-113/000-006 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; blue www.wago.com/2009-113 /000-006 Item no.: 2009-113/000-007 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; gray www.wago.com/2009-113 /000-007 Item no.: 2009-113/000-012 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; orange www.wago.com/2009-113 /000-012 Item no.: 2009-113/000-017 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; light green www.wago.com/2009-113 /000-017 Item no.: 2009-113/000-023 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; green www.wago.com/2009-113 /000-023 Item no.: 2009-113/000-024 WMB-Inline; for Smart Printer; 2300 pieces on roll; plain; snap-on type; violet www.wago.com/2009-113 /000-024 Item no.: 2009-191 Group marker carrier www.wago.com/2009-191 Item no.: 793-3501 WMB marking card; as card; plain; snap-on type; white www.wago.com/793-3501 Push-in type wire jumper Item no.: 2009-402 Push-in type wire jumper; 0.75 mm²; insulated; 60 mm long; gray www.wago.com/2009-402 Item no.: 2009-404 Push-in type wire jumper; 0.75 mm²; insulated; 110 mm long; gray www.wago.com/2009-404 Item no.: 2009-406 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/2009-406 Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 12.07.2021    Page 6/14 Data sheet | Item number: 2050-301 www.wago.com/2050-301 Item no.: 2009-406 Push-in type wire jumper; 0.75 mm²; insulated; 250 mm long; gray www.wago.com/2009-406 Testing and measuring Item no.: 2009-174 Test plug adapter; for 4 mm Ø test plugs; for testing TOPJOB®S rail-mounted terminal blocks; gray www.wago.com/2009-174 Item no.: 2009-182 Testing tap; for max. 2.5 mm²; tool-free connection for individual test wires 0.08 - 2.5 mm; gray www.wago.com/2009-182 Item no.: 210-136 Test plug; 2 mm Ø; with 500 mm cable; red www.wago.com/210-136 Item no.: 2000-402 Jumper; 2-way; insulated; light gray www.wago.com/2000-402 Item no.: 2000-402/000-005 Jumper; 2-way; insulated; red www.wago.com/2000-402 /000-005 Item no.: 2000-402/000-006 Jumper; 2-way; insulated; blue www.wago.com/2000-402 /000-006 Item no.: 2000-402/000-018 Jumper; 2-way; insulated; yellow-green www.wago.com/2000-402 /000-018 Item no.: 2000-403 Jumper; 3-way; insulated; light gray www.wago.com/2000-403 Item no.: 2000-403/000-005 Jumper; 3-way; insulated; red www.wago.com/2000-403 /000-005 Item no.: 2000-403/000-006 Jumper; 3-way; insulated; blue www.wago.com/2000-403 /000-006 Item no.: 2000-404 Jumper; 4-way; insulated; light gray www.wago.com/2000-404 Item no.: 2000-404/000-005 Jumper; 4-way; insulated; red www.wago.com/2000-404 /000-005 Item no.: 2000-404/000-006 Jumper; 4-way; insulated; blue www.wago.com/2000-404 /000-006 Item no.: 2000-405 Jumper; 5-way; insulated; light gray www.wago.com/2000-405 Jumpers Item no.: 2000-405/000-005 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 12.07.2021    Page 7/14 Data sheet | Item number: 2050-301 www.wago.com/2050-301 Item no.: 2000-405/000-005 Jumper; 5-way; insulated; red www.wago.com/2000-405 /000-005 Item no.: 2000-405/000-006 Jumper; 5-way; insulated; blue www.wago.com/2000-405 /000-006 Item no.: 2000-405/011-000 Star point jumper; 3-way; insulated; light gray www.wago.com/2000-405 /011-000 Item no.: 2000-406 Jumper; 6-way; insulated; light gray www.wago.com/2000-406 Item no.: 2000-406/000-005 Jumper; 6-way; insulated; red www.wago.com/2000-406 /000-005 Item no.: 2000-406/000-006 Jumper; 6-way; insulated; blue www.wago.com/2000-406 /000-006 Item no.: 2000-406/020-000 Delta jumper; insulated; light gray www.wago.com/2000-406 /020-000 Item no.: 2000-407 Jumper; 7-way; insulated; light gray www.wago.com/2000-407 Item no.: 2000-407/000-005 Jumper; 7-way; insulated; red www.wago.com/2000-407 /000-005 Item no.: 2000-407/000-006 Jumper; 7-way; insulated; blue www.wago.com/2000-407 /000-006 Item no.: 2000-408 Jumper; 8-way; insulated; light gray www.wago.com/2000-408 Item no.: 2000-408/000-005 Jumper; 8-way; insulated; red www.wago.com/2000-408 /000-005 Item no.: 2000-408/000-006 Jumper; 8-way; insulated; blue www.wago.com/2000-408 /000-006 Item no.: 2000-409 Jumper; 9-way; insulated; light gray www.wago.com/2000-409 Item no.: 2000-409/000-005 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 12.07.2021    Page 8/14 Data sheet | Item number: 2050-301 www.wago.com/2050-301 Item no.: 2000-409/000-005 Jumper; 9-way; insulated; red www.wago.com/2000-409 /000-005 Item no.: 2000-409/000-006 Jumper; 9-way; insulated; blue www.wago.com/2000-409 /000-006 Item no.: 2000-410 Jumper; 10-way; insulated; light gray www.wago.com/2000-410 Item no.: 2000-410/000-005 Jumper; 10-way; insulated; red www.wago.com/2000-410 /000-005 Item no.: 2000-410/000-006 Jumper; 10-way; insulated; blue www.wago.com/2000-410 /000-006 Item no.: 2000-433 Jumper; from 1 to 3; insulated; light gray www.wago.com/2000-433 Item no.: 2000-433/000-005 Jumper; from 1 to 3; insulated; red www.wago.com/2000-433 /000-005 Item no.: 2000-433/000-006 Jumper; from 1 to 3; insulated; blue www.wago.com/2000-433 /000-006 Item no.: 2000-434 Jumper; from 1 to 4; insulated; light gray www.wago.com/2000-434 Item no.: 2000-435 Jumper; from 1 to 5; insulated; light gray www.wago.com/2000-435 Item no.: 2000-436 Jumper; from 1 to 6; insulated; light gray www.wago.com/2000-436 Item no.: 2000-437 Jumper; from 1 to 7; insulated; light gray www.wago.com/2000-437 Item no.: 2000-438 Jumper; from 1 to 8; insulated; light gray www.wago.com/2000-438 Item no.: 2000-439 Jumper; from 1 to 9; insulated; light gray www.wago.com/2000-439 Item no.: 2000-440 Jumper; from 1 to 10; insulated; light gray www.wago.com/2000-440 Item no.: 2009-110 Marking strips; for Smart Printer; on reel; not stretchable; plain; snap-on type; white www.wago.com/2009-110 Mounting Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 12.07.2021    Page 9/14 Data sheet | Item number: 2050-301 www.wago.com/2050-301 Mounting Item no.: 209-123 Mounting foot with screw; can be screwed on terminal blocks with fixing flange; 6.4 mm wide; gray www.wago.com/209-123 Item no.: 209-137 Mounting adapter; can be used as end stop; 6.5 mm wide; gray www.wago.com/209-137 Item no.: 216-241 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; white www.wago.com/216-241 Item no.: 216-242 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-242 Ferrule Item no.: 216-243 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243 acc. to DIN 46228, Part 4/09.90; red Protective warning marker Item no.: 2000-115 Protective warning marker; with high-voltage symbol, black; for 5 terminal blocks; yellow www.wago.com/2000-115 Item no.: 210-647 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft; multicoloured www.wago.com/210-647 Item no.: 210-648 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft; angled; short www.wago.com/210-648 Item no.: 210-719 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft www.wago.com/210-719 Tool Downloads Documentation Additional Information Technical explanations 3 Apr 2019 pdf 2.2 MB Download URL Download URL Download CAD/CAE-Data CAD data 2D/3D Models 2050-301 CAE data ZUKEN Portal 2050-301 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 12.07.2021    Page 10/14 Data sheet | Item number: 2050-301 www.wago.com/2050-301 EPLAN Data Portal 2050-301 URL Download URL Download URL Download Environmental Product Compliance Compliance Search Environmental Product Compliance 2050-301 2-conductor miniature through terminal block; with operating slots; 1 mm²; with test port; side and center marking; End terminal block with mounting flange; Push-in CAGE CLAMP®; 1,00 mm²; gray Installation Notes Conductor termination Insert solid conductors via push-in termination. Insert ferruled conductors via push-in termination. Insert fine-stranded conductors via operating tool. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 12.07.2021    Page 11/14 Data sheet | Item number: 2050-301 www.wago.com/2050-301 Remove all conductors via operating tool. Commoning Insert a jumper (delta jumper) and push down until it hits the backstop (picture shows terminal blocks with push-buttons). Marking strip (2009‑110) inserted in the marking slot with jumper symbols of the inserted jumper (picture shows terminal blocks with push-buttons) Insert a jumper (star point jumper) and push down until it hits the backstop (picture shows terminal blocks with push-buttons). Marking strip (2009‑110) inserted in the marking slot with jumper symbols of the inserted jumper (2000‑405/011‑000 Delta Jumper) (picture shows terminal blocks with push-buttons) Testing Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 12.07.2021    Page 12/14 Data sheet | Item number: 2050-301 www.wago.com/2050-301 Testing with a 2 mm Ø 210‑136 Test Plug (max. 42 V). Installation Mounting and securing a terminal strip directly to the plate via screw-type flanges (picture shows terminal blocks with pushbuttons). Terminal strip; with mounting flanges; screw mounting (picture shows terminal blocks with push-buttons) Marking Snapping a WMB marking strip into a marker slot. Snapping a marking strip (2009‑110) into a marker slot. Product family TOPJOB® S TOPJOB® S: In various applications and modern building installations, WAGO's wide and versatile range of railSubject to changes. Please also observe the furtherindustrial product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 12.07.2021    Page 13/14 Data sheet | Item number: 2050-301 www.wago.com/2050-301 TOPJOB® S: In various industrial applications and modern building installations, WAGO's wide and versatile range of railmount terminal blocks provides more than just reliable electrical connections. Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 12.07.2021    Page 14/14
2050-0301 价格&库存
很抱歉,暂时无法提供与“2050-0301”相匹配的价格&库存,您可以联系我们找货
