Data sheet | Item number: 207-1333
Gelbox; for cables; Branch; with gel; 221, 2x73 Series; max. 4 mm²
connectors; without splicing connectors; Size 3; gray
www.wago.com/207-1333
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Private Limited
NH No. 8, Block No. 94 Vadsala,
Block No. 1187 Varnama, Village Varnama / Vadsala
Ta. & Distt. Vadodara, Vadodara, Gujarat-391243
Phone: +91-265-6812100 | Email: info.india@wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
23.12.2021 Page 1/5
Item description
Note on Packaging Unit (PU) and Subpackaging Unit (SPU):
If you order a full PU, you will receive our eco-friendly, sustainable cardboard blisters packed in a shelf-ready box.
If you order a quantity smaller than a full PU, you will receive the eco-friendly, sustainable cardboard blisters without a shelf-ready box.
Please note the system description for the splicing connectors that can be used.
The Benefits for You:
Easy, fast and safe to use
Can be used immediately and accessed again later
Silicon-free
Label-free
Suitable for indefinite storage
The complete system consisting of Gelboxes and WAGO connectors has been VDE-tested and IPX8-certified.
Data
Connection data
Connection 1
Actuation type
Locking system
Physical data
Width
33.6 mm / 1.323 inch
Height
17.8 mm / 0.701 inch
Depth
52.7 mm / 2.075 inch
Mechanical data
Mounting type
Flying leads
Protection class
IPX8
Material data
Note on material data
Information on material data can be found here
Color
gray
Housing material
Polypropylene
Weight
21 g
Environmental
requirements
23.12.2021 Page 2/5
Environmental requirements
Surrounding air temperature (operation)
-55 … 85 °C
Surrounding air temperature (storage)
0 … 40 °C
Commercial data
PU (SPU)
36 (3) Stück
Packaging type
BOX
Country of origin
IT
GTIN
4055143997805
Customs tariff number
85389099990
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
VDE
VDE Prüf- und Zertifizierungsinstitut
EN 60998
400051938
Downloads
Documentation
Bid Text
207-1333
doc - Datei
207-1333
X81 - Datei
docx
20.9 kB
Download
xml
3.7 kB
Download
pdf
1.2 MB
Download
pdf
2.2 MB
Download
System Description
System Description 207 Series Gel boxes
Additional Information
Technical Section
Technical explanations
23.12.2021 Page 3/5
CAD/CAE-Data
CAD data
2D/3D Models 207-1333
URL
Download
URL
Download
URL
Download
CAE data
ZUKEN Portal 207-1333
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 207-1333
Gelbox; for cables; Branch; with gel; 221, 2x73 Series; max. 4 mm² connectors;
Installation Notes
Installation
Place the wired connector in the Gelbox.
Gelbox öffnen.
23.12.2021 Page 4/5
Close the Gelbox.
Close latch securely.
Re-accessible:
Open the Gelbox.
Remove the gel.
Rewire with new components.
Lift the flap and pull the cover perforation
forward.
Press in the perforation on the sides.
As a counter display: Bend the rear flap at
the fold, straighten it and fix it in the
cardboard cut-out
If the flap is not required, tear off from the
perforation.
Tear off the cover from the perforation.
23.12.2021 Page 5/5
很抱歉,暂时无法提供与“207-1333”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+150.859851+19.54163
