Data sheet | Item number: 2086-3225/300-000
THR PCB terminal block; push-button; 1.5 mm²; Pin spacing 5 mm; 5-pole;
Push-in CAGE CLAMP®; Solder pin length 1.5 mm; 1,50 mm²; black
www.wago.com/2086-3225/300-000
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at 01788 568 008.
13.09.2021 Page 1/9
Dimensions in mm
L = (pole no. – 1) x pin spacing + 4.2 mm
Dimensions in mm
A = even number of poles
B = odd number of poles
Item description
Ideal for compact device connection, panel feedthrough and tight spaces
Push-in CAGE CLAMP® allows push-in termination of solid and fine-stranded conductors with ferrules
SMD and THR variants available
Delivery in tape-and-reel packaging for full integration into SMT soldering process
Hansastr. 27
32423 Minden
13.09.2021 Page 2/9
Push-button moves in direction of conductor connection
Conductor connection and mating direction both parallel and perpendicular to the PCB
Choice of double pin spacing or alternating pin spacing, 3.5 and 5 mm pin spacing
Data
Electrical data
Ratings per IEC/EN
Ratings per
IEC/EN 60664-1
Nominal voltage (III/3)
500 V
Rated surge voltage (III/3)
6 kV
Rated voltage (III/2)
630 V
Rated surge voltage (III/2)
6 kV
Nominal voltage (II/2)
1000 V
Rated surge voltage (II/2)
6 kV
Rated current
17.5 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Ratings per UL
Approvals per
UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
10 A
Rated voltage UL (Use Group C)
300 V
Rated current UL (Use Group C)
10 A
Rated voltage UL (Use Group D)
300 V
Rated current UL (Use Group D)
10 A
Ratings per CSA
Approvals per
CSA
Rated voltage CSA (Use Group B)
300 V
Rated current CSA (Use Group B)
10 A
Rated voltage CSA (Use Group D)
300 V
Rated current CSA (Use Group D)
10 A
Hansastr. 27
32423 Minden
13.09.2021 Page 3/9
Connection data
Total number of potentials
5
Number of connection types
1
Number of levels
1
Connection 1
Connection technology
Push-in CAGE CLAMP®
Actuation type
Push-button
Solid conductor
0.14 … 1.5 mm² / 24 … 16 AWG
Fine-stranded conductor
Fine-stranded conductor; with insulated ferrule
0.25 … 0.75 mm²
Fine-stranded conductor; with uninsulated ferrule
0.25 … 1.5 mm²
Conductor diameter
24 … 16 AWG
Strip length
8 … 9 mm / 0.31 … 0.35 inch
Conductor connection direction to PCB
0 °
Pole No.
5
Physical data
Pin spacing
5 mm / 0.197 inch
Width
24.2 mm / 0.953 inch
Height
9.3 mm / 0.366 inch
Height from the surface
7.8 mm / 0.307 inch
Depth
13.6 mm / 0.535 inch
Solder pin length
1.5 mm
Solder pin dimensions
0.3 x 0.8 mm
Plated through-hole diameter (THR)
1 (+0.1) mm
PCB contact
PCB Contact
THR
Solder pin arrangement
over the entire terminal strip (staggered)
Number of solder pins per potential
1
Material data
Color
black
Insulation material
Polyphthalamide (PPA GF)
Hansastr. 27
32423 Minden
13.09.2021 Page 4/9
Insulation material
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Weight
2.9 g
Environmental requirements
Limit temperature range
-60 … +105 °C
Commercial data
PU (SPU)
132 Stück
Packaging type
BOX
Country of origin
CH
GTIN
4055144089813
Customs tariff number
85369010000
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CB
DEKRA Certification B.V.
IEC 60947-7-4
NL-74022
CSA
C22.2
80060692
KEMA/KEUR
EN 60947-7-4
71119449
Optional accessories
Tool
Operating tool
Item no.: 210-719
Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft
www.wago.com/210-719
Ferrule
Hansastr. 27
32423 Minden
13.09.2021 Page 5/9
Ferrule
Ferrule
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-101
Item no.: 216-104
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-104
Item no.: 216-102
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-102
Item no.: 216-103
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated
www.wago.com/216-103
Item no.: 216-142
Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92
www.wago.com/216-142
Item no.: 216-132
Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-132
Item no.: 216-121
www.wago.com/216-121
Item no.: 216-143
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-143
Item no.: 216-131
Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-131
Item no.: 216-141
Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-141
Item no.: 216-152
www.wago.com/216-152
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
Item no.: 216-151
www.wago.com/216-151
Item no.: 216-144
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92; silver-colored
www.wago.com/216-144
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
Hansastr. 27
32423 Minden
www.wago.com/216-242
13.09.2021 Page 6/9
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-301
Item no.: 216-302
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-302
Testing and measuring
Testing accessories
Item no.: 735-500
Test pin; 1 mm Ø; with solder connection for test wire
www.wago.com/735-500
Item no.: 859-500
www.wago.com/859-500
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
THR Soldering Process
pdf
2.0 MB
Download
pdf
548.2 kB
Download
URL
Download
URL
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 2086-3225/300-000
CAE data
ZUKEN Portal 2086-3225/300-000
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 2086-3225/300-000
THR PCB terminal block; push-button; 1.5 mm²; Pin spacing 5 mm; 5-pole; Push-in
Hansastr. 27
32423 Minden
13.09.2021 Page 7/9
Installation Notes
Conductor termination
Inserting solid conductor via push-in
termination.
Conductor removal
Removing fine-stranded conductors via
push-buttons.
Hansastr. 27
32423 Minden
13.09.2021 Page 8/9
Inserting and removing fine-stranded
conductors via push-buttons.
Testing
Testing via 1 mm Ø test pin.
Touch contact with current bar.
Marking
Pole marking via direct marking
perpendicular to conductor entry.
Hansastr. 27
32423 Minden
13.09.2021 Page 9/9
很抱歉,暂时无法提供与“2086-3225/300-000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 132+15.83575132+2.04694
