231-104/026-000/RN01-0000
    WAGO(万可电子)
231-104/026-000/RN01-0000 数据手册
Printview: Female connector; 4-pole; Pin spacing 5 mm / 0.197 in; codable; with 2 locking latches; CAGE CLAMP®CONNECTION; with coding finger; with latch - Item No.: 231-104/026-000 . Female connector; 4-pole; Pin spacing 5 mm / 0.197 in; codable; with 2 locking latches; CAGE CLAMP®CONNECTION; with coding finger; with latch Item No.: 231-104/026-000 . Female connector; 4-pole; Pin spacing 5 mm / 0.197 in; codable; with 2 locking latches; CAGE CLAMP®CONNECTION; with coding finger; with latch . Marking . Business data Supplier WAGO Item no. 231-104/026-000 GTIN / EAN 4044918338394 Content 1 Order amount 100 Customer item number . Notes Universal connection for all conductor typesEasy cable pre-assembly and on-unit wiring via vertical and horizontal CAGE CLAMP® actuationIntegrated test portsCoding option available Technical data Miscellaneous No. of poles 4 Pin Spacing 5 mm / 0.197 in % Total number of connection points 4 Total number of potentials 4 Color gray Ratings according to 1 IEC/EN 60664-1 Overvoltage category EN 1 III WAGO Kontakttechnik GmbH & Co. KG 1 Printview: Female connector; 4-pole; Pin spacing 5 mm / 0.197 in; codable; with 2 locking latches; CAGE CLAMP®CONNECTION; with coding finger; with latch - Item No.: 231-104/026-000 Technical data Pollution degree (1) 2 Rated voltage EN (1) [V] 320 [V] Rated surge voltage (1) [kV] 4 [kV] Nominal current [A] 16 [A] Overvoltage category EN 2 II Degree of pollution (2) 2 Rated voltage EN (2) [V] 630 [V] Rated surge voltage (2) [kV] 4 [kV] Nominal current (2) [A] 16 [A] Overvoltage category EN 3 III Degree of pollution (3) 3 Rated voltage EN (3) [V] 320 [V] Rated surge voltage (3) [kV] 4 [kV] Nominal current (3) [A] 16 [A] Number of individual connection objects at the product 1 Connection technology (1) CAGE CLAMP® Solid sizes 1 0.08 … 2.5 mm² / 28 … 12 AWG Fine-stranded wires 1 0.08 … 2.5 mm² / 28 … 12 AWG Fine-stranded wires with insulated ferrule 1 0.25 … 1.5 mm² / … Fine-stranded wires with uninsulated ferrule 1 0.25 … 2.5 mm² / … Strip length 1 8 … 9 mm / 0.31 … 0.35 in Material group I Insulating material Polyamide 66 (PA 66) Flammability rating per UL 94 V0 Limit temperature range -60 C … 85 C Clamping spring material Chrome-nickel spring steel (CrNi) Contact material Copper alloy Contact plating tin-plated Fire load [MJ] 0.106 [MJ] Weight [g] 7.267 [g] Width 21.5 mm / 0.846 in Height 14.3 mm / 0.563 in Length 26.45 mm / 1.041 in WAGO Kontakttechnik GmbH & Co. KG 2 Printview: Female connector; 4-pole; Pin spacing 5 mm / 0.197 in; codable; with 2 locking latches; CAGE CLAMP®CONNECTION; with coding finger; with latch - Item No.: 231-104/026-000 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 3 Printview: Female connector; 4-pole; Pin spacing 5 mm / 0.197 in; codable; with 2 locking latches; CAGE CLAMP®CONNECTION; with coding finger; with latch - Item No.: 231-104/026-000 . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 4
231-104/026-000/RN01-0000 价格&库存
很抱歉,暂时无法提供与“231-104/026-000/RN01-0000”相匹配的价格&库存,您可以联系我们找货
