Data sheet | Item number: 231-116/037-000
1-conductor female plug; Locking lever; 2.5 mm²; Pin spacing 5 mm; 16pole; 2,50 mm²; gray
www.wago.com/231-116_037-000
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
13.07.2020 Page 1/13
L = pole no. x pin spacing
2- to 3-pole female connectors – one latch only
Item description
Universal connection for all conductor types
Easy cable pre-assembly and on-unit wiring via vertical and horizontal CAGE CLAMP® actuation
Integrated test ports
With coding fingers
Safety information 1:
The MCS – MULTI CONNECTION SYSTEM includes connectors without breaking capacity in accordance with DIN EN 61984. When used as
intended, these connectors must not be connected/disconnected when live or under load. The circuit design should ensure header pins, which can
be touched, are not live when unmated.
Data
Electrical data
Ratings per IEC/EN 60664-1
Ratings per
IEC/EN 60664-1
Nominal voltage (III/3)
320 V
Rated surge voltage (III/3)
4 kV
Rated voltage (III/2)
320 V
Hansastr. 27
32423 Minden
13.07.2020 Page 2/13
320 V
Rated surge voltage (III/2)
4 kV
Nominal voltage (II/2)
630 V
Rated surge voltage (II/2)
4 kV
Rated current
16 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Approvals per UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
15 A
Rated voltage UL (Use Group D)
300 V
Rated current UL (Use Group D)
10 A
Approvals per UL 1977
Rated voltage UL 1977
600 V
Rated current UL 1977
15 A
Approvals per CSA
Rated voltage CSA (Use Group B)
300 V
Rated current CSA (Use Group B)
15 A
Rated voltage CSA (Use Group D)
300 V
Rated current CSA (Use Group D)
10 A
Connection data
Connection technology
CAGE CLAMP®
Actuation type
Operating tool
Solid conductor
0,08 … 2,5 mm² / 28 … 12 AWG
Fine-stranded conductor
Fine-stranded conductor; with insulated ferrule
0,25 … 1,5 mm²
Fine-stranded conductor; with uninsulated ferrule
0,25 … 2,5 mm²
Strip length
8 … 9 mm / 0.31 … 0.35 inch
Pole No.
16
Total number of connection points
16
Total number of potentials
16
Number of connection types
1
Number of levels
1
Conductor entry direction to mating direction
0 °
Hansastr. 27
32423 Minden
13.07.2020 Page 3/13
0 °
Geometrical Data
Pin spacing
5 mm / 0.197 inch
Width
96,6 mm / 3.803 inch
Height
14,3 mm / 0.563 inch
Depth
29,6 mm / 1.165 inch
Plug connection
Contact type (pluggable connector)
Female connector/socket
Connector (connection type)
for conductor
Mismating protection
No
Locking of plug-in connection
locking lever
Material Data
Color
gray
Material group
I
Insulation material
Polyamide 66 (PA 66)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Copper alloy
Contact plating
tin-plated
Fire load
0.437 MJ
Weight
29.5 g
Environmental Requirements
Limit temperature range
-60 … +85 °C
Commercial data
Product Group
3 (Multi Conn. System)
Packaging type
BOX
Country of origin
DE
GTIN
4044918342315
Customs tariff number
85366990990
Hansastr. 27
32423 Minden
13.07.2020 Page 4/13
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CB
DEKRA Certification B.V.
IEC 61984
NL-39756
CSA
C22.2
1466354
Ship Approvals
Logo
Certificate
name
Approval
ABS
American Bureau of Shipping
19HG1869876PDA
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE000016Z
UL-Approvals
Logo
Certificate
name
Approval
UL
Underwriters Laboratories Inc.
UL 1059
20190731E45172
UR
UL International Germany GmbH
UL 1977
E45171
Counterpart
Item no.231-616
1-conductor male connector; 2.5 mm²; Pin spacing 5 mm; 16-pole; 2,50 mm²; gray
www.wago.com/231-616
Hansastr. 27
32423 Minden
13.07.2020 Page 5/13
Item no.231-146/001-000
THT male header; 1.0 x 1.0 mm solder pin; straight; Pin spacing 5 mm; 16-pole; gray
www.wago.com/231-146/001-000
Item no.231-446/001-000
THT male header; 1.0 x 1.0 mm solder pin; angled; Pin spacing 5 mm; 16-pole; gray
www.wago.com/231-446/001-000
Compatible products
General accessories
Item no.: 231-668
Lockout caps; for covering unused clamping units; gray
www.wago.com/231-668
Item no.: 231-670
Insulation stop; 0.08-0.2 mm² / 0.2 mm² “s”; white
www.wago.com/231-670
Item no.: 231-671
Insulation stop; 0.25 - 0.5 mm²; light gray
www.wago.com/231-671
Item no.: 231-672
Insulation stop; 0.75 - 1 mm²; dark gray
www.wago.com/231-672
Item no.: 231-902
Jumper; for conductor entry; gray
www.wago.com/231-902
Item no.: 231-903
Jumper; for conductor entry; 3-way; insulated; gray
www.wago.com/231-903
Item no.: 231-905
Jumper; for conductor entry; 5-way; insulated; gray
www.wago.com/231-905
Item no.: 231-907
Jumper; for conductor entry; 7-way; insulated; gray
www.wago.com/231-907
Item no.: 231-910
Jumper; for conductor entry; 10-way; insulated; gray
www.wago.com/231-910
Item no.: 209-130
Operating tool; suitable for 264, 280 and 281 Series; 1-way; of insulating material
www.wago.com/209-130
Insulation stop
Jumper
tools
Hansastr. 27
32423 Minden
13.07.2020 Page 6/13
Item no.: 209-132
Operating tool; for connecting comb-style jumper bar; 2-way; of insulating material
www.wago.com/209-132
Item no.: 231-131
Push-button; loose
www.wago.com/231-131
Item no.: 231-159
Operating tool; natural
www.wago.com/231-159
Item no.: 231-231
Combination operating tool; red
www.wago.com/231-231
Item no.: 231-291
Operating tool; loose; red
www.wago.com/231-291
Item no.: 280-432
Operating tool; made of insulating material; 2-way
www.wago.com/280-432
Item no.: 280-433
Operating tool; made of insulating material; 3-way
www.wago.com/280-433
Item no.: 280-434
Operating tool; made of insulating material; 4-way
www.wago.com/280-434
Item no.: 280-435
Operating tool; made of insulating material; 5-way; gray
www.wago.com/280-435
Item no.: 280-436
Operating tool; made of insulating material; 6-way
www.wago.com/280-436
Item no.: 280-437
Operating tool; made of insulating material; 7-way
www.wago.com/280-437
Item no.: 280-438
Operating tool; made of insulating material; 8-way
www.wago.com/280-438
Item no.: 280-440
Operating tool; made of insulating material; 10-way
www.wago.com/280-440
Item no.: 210-136
Test plug; 2 mm Ø; with 500 mm cable; red
www.wago.com/210-136
Item no.: 210-137
Test plug; 2.3 mm Ø; with 500 mm cable; yellow
www.wago.com/210-137
Item no.: 231-661
Test plugs for female connectors; for 5 mm and 5.08 mm pin spacing; 2,50 mm²; light gray
www.wago.com/231-661
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated
www.wago.com/216-101
check
ferrule
Item no.: 216-102
Hansastr. 27
32423 Minden
www.wago.com/216-102
13.07.2020 Page 7/13
Item no.: 216-102
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated
Item no.: 216-103
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated
www.wago.com/216-103
Item no.: 216-104
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated
www.wago.com/216-104
Item no.: 216-106
Ferrule; Sleeve for 2.5 mm² / AWG 14; uninsulated; electro-tin plated
www.wago.com/216-106
Item no.: 216-121
www.wago.com/216-121
Item no.: 216-122
www.wago.com/216-122
Item no.: 216-123
www.wago.com/216-123
Item no.: 216-124
www.wago.com/216-124
Item no.: 216-131
Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-131
Item no.: 216-132
Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-132
Item no.: 216-141
Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92
www.wago.com/216-141
Item no.: 216-142
Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight www.wago.com/216-142
Item no.: 216-143
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-143
Item no.: 216-144
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-144
Item no.: 216-151
www.wago.com/216-151
Item no.: 216-152
www.wago.com/216-152
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
Hansastr. 27
32423 Minden
13.07.2020 Page 8/13
Item no.: 216-203
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
www.wago.com/216-203
Item no.: 216-204
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black
www.wago.com/216-204
Item no.: 216-221
www.wago.com/216-221
Item no.: 216-222
www.wago.com/216-222
Item no.: 216-223
www.wago.com/216-223
Item no.: 216-224
www.wago.com/216-224
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
Item no.: 216-243
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; red
www.wago.com/216-243
Item no.: 216-244
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-244
Item no.: 216-262
www.wago.com/216-262
Item no.: 216-263
www.wago.com/216-263
Item no.: 216-264
www.wago.com/216-264
Item no.: 216-284
www.wago.com/216-284
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-301
Item no.: 216-302
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-302
Item no.: 216-321
Hansastr. 27
32423 Minden
13.07.2020 Page 9/13
Item no.: 216-321
www.wago.com/216-321
Item no.: 216-322
www.wago.com/216-322
Marking accessories
Item no.: 210-331/500-103
Marking strips; as a DIN A4 sheet; MARKED; 1-12 (300x); Height of marker strip: 2.3 mm/0.091 in;
Strip length 182 mm; Horizontal marking; Self-adhesive; white
www.wago.com/210-331
/500-103
Item no.: 210-331/500-104
Marking strips; as a DIN A4 sheet; MARKED; 13-24 (300x); Height of marker strip: 2.3 mm/0.091 in;
/500-104
Item no.: 210-332/500-202
Marking strips; as a DIN A4 sheet; MARKED; 1-16 (160x); Height of marker strip: 3 mm; Strip length
www.wago.com/210-332
/500-202
Item no.: 210-332/500-204
Marking strips; as a DIN A4 sheet; MARKED; 17-32 (160x); Height of marker strip: 3 mm; Strip length
/500-204
Item no.: 210-332/500-205
Marking strips; as a DIN A4 sheet; MARKED; 1-32 (80x); Height of marker strip: 3 mm; Strip length
/500-205
Item no.: 210-332/500-206
Marking strips; as a DIN A4 sheet; MARKED; 33-48 (160x); Height of marker strip: 3 mm; Strip length
/500-206
Downloads
CAD/CAE-Data
CAD data
2D/3D Models 231-116/037-000
URL
Download
EPLAN Data Portal 231-116/037-000
URL
Download
ZUKEN Portal 231-116/037-000
URL
Download
CAE data
Installation Notes
Conductor termination
Hansastr. 27
32423 Minden
13.07.2020 Page 10/13
Inserting a conductor via 3.5 mm
screwdriver – CAGE CLAMP® actuation
parallel to conductor entry.
perpendicular to conductor entry.
Inserting a conductor into CAGE CLAMP®
unit via operating lever (231-291).
Inserting a conductor via operating tool.
Coding
Coding a female connector – removing
coding finger(s).
Testing
Hansastr. 27
32423 Minden
13.07.2020 Page 11/13
Testing perpendicular to conductor entry via
2 or 2.3 mm Ø test plug – female connector
with CAGE CLAMP®.
Installation
Male connector with strain relief plate
Strain relief housing shown with a male
connector equipped with CAGE CLAMP®
Marking
Labeling via direct marking or self-adhesive
strips.
Product family
Hansastr. 27
32423 Minden
13.07.2020 Page 12/13
MCS MIDI Classic
Show all products from the family
Hansastr. 27
32423 Minden
13.07.2020 Page 13/13
很抱歉,暂时无法提供与“231-116/037-000”相匹配的价格&库存,您可以联系我们找货
