Data sheet from 03.02.2009
Item no.:
231-375/001-000
Product description:
HEADER; STRAIGHT SOLDER PIN, 1.2 X 1.2 MM /0.047 X
0.047 IN; 15 POLE; PIN SPACING 5.08 MM / 0.2 IN; WITH
CLOSED END; MATING DIRECTION PERPENDICULAR TO
PCB
Packing unit 50 5*10 pieces
Product group
3 (Multi Conn. System)
Pin spacing from
5,08 mm
Pin spacing from
0,2 in
pole count
15
Measured voltage EN
250 V
Measured shock voltage
4 kV
Pollution degree
3
Current intensity EN
16 A
Weight
5,92 g
Color
orange
Height
12 mm
Height
0,472 in
Width
79,4 mm
Width
3,126 in
Depth
8,4 mm
Depth
0,331 in
1 von 2
Item number
Admission office
Approval no.
Voltage [V]
Current [A]
Cross section [ mm² ]
231-375/001-000
BV
11915/A0
400
16
2,5
231-375/001-000
CCA
5764
250
16
1,2x,21
231-375/001-000
CSA
154112-1466354
300
15
231-375/001-000
DEMKO
88126
250
231-375/001-000
KEMA
2083746.02
250
16
1,2x,21
231-375/001-000
KR
HMB05880-EL003
250/400
12/16
2,5
231-375/001-000
NEMKO
P94101840
250
231-375/001-000
UR
E45171
600
15
231-375/001-000
UR
E45172
300
15
Sorting criteria: admission office - approval number
© WAGO Kontakttechnik GmbH & Co. KG
Specifications are subject to changes and errors may be expected
2 von 2
2,5
2,5
很抱歉,暂时无法提供与“231-375/001-000”相匹配的价格&库存,您可以联系我们找货
