Male Headers with Solder Pins
MCS MIDI Classic
6
391
With 1 x 1 mm straight solder pins
Pin spacing: 5 mm / 0.197 in.
320 V/4 kV/2 12 A
With 1.2 x 1.2 mm straight solder pins
300 V/10 A
320 V/4 kV/2 16 A
300 V/15 A
With 1 x 1 mm angled solder pins
320 V/4 kV/2 12 A
>3,8<
L = (pole no. – 1) x pin spacing + 8.2 mm
Pole No.
Item No.
231-132/001-000
231-133/001-000
231-134/001-000
231-135/001-000
231-136/001-000
231-137/001-000
231-138/001-000
231-139/001-000
231-140/001-000
231-141/001-000
231-142/001-000
231-143/001-000
231-144/001-000
231-145/001-000
231-146/001-000
231-147/001-000
231-148/001-000
231-149/001-000
231-150/001-000
231-151/001-000
231-152/001-000
231-153/001-000
231-154/001-000
7,5 <
Pack. Unit
200
200
200
200
100
100
100
100
100
100
100
50
50
50
50
50
50
50
50
50
50
50
50
Pole No.
6,5
(_10 _)
5
6
L1 = L + 5 mm
L2 = L1 + 7.4 mm
Pack. Unit
Male header with 1.2 x 1.2 mm straight solder
pins, gray
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
4,1
> 4,1<
> 4,1<
_____ L _____>
Item No.
4,1 5
5
3,8
___>
> 5<
Male header with 1 x 1 mm straight solder pins,
gray
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
>3,8<
> 8,4 <
3,8
> 4,1<
> 4,1<
_____ L _____>
> 5<
> 5
> 8,4 <
3,8
> 5
300 V/10 A
231-162/001-000
231-163/001-000
231-164/001-000
231-165/001-000
231-166/001-000
231-167/001-000
231-168/001-000
231-169/001-000
231-170/001-000
231-171/001-000
231-172/001-000
231-173/001-000
231-174/001-000
231-175/001-000
231-176/001-000
231-177/001-000
231-178/001-000
231-179/001-000
231-180/001-000
231-181/001-000
231-182/001-000
231-183/001-000
231-184/001-000
1 M
CS MIDI male headers with straight solder pins are also available with 3.8 mm pin projection upon request.
Replace item no. suffix: . . . /001-000 with . . . /046-000.
Pole No.
Item No.
Pack. Unit
Male header with 1 x 1 mm angled solder pins,
gray
200
200
200
200
100
100
100
100
100
100
100
50
50
50
50
50
50
50
50
50
50
50
50
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
231-432/001-000
231-433/001-000
231-434/001-000
231-435/001-000
231-436/001-000
231-437/001-000
231-438/001-000
231-439/001-000
231-440/001-000
231-441/001-000
231-442/001-000
231-443/001-000
231-444/001-000
231-445/001-000
231-446/001-000
231-447/001-000
231-448/001-000
231-449/001-000
231-450/001-000
231-451/001-000
231-452/001-000
231-453/001-000
231-454/001-000
200
200
200
200
100
100
100
100
100
100
100
50
50
50
50
50
50
50
50
50
50
50
50
很抱歉,暂时无法提供与“231-434/001-000”相匹配的价格&库存,您可以联系我们找货
