234-216
234-216
    WAGO(万可电子)
    插件,P=2.5mm
    接线端子 间距:2.50mm 每排针脚数:16 排数:单排
234-216 数据手册
Data sheet | Item number: 234-216 PCB terminal block; push-button; 0.5 mm²; Pin spacing 2.5 mm; 16-pole; CAGE CLAMP®; 0,50 mm²; gray www.wago.com/234-216 i Picture differs from the item. Color: L = (pole no. x pin spacing) + 2.2 mm Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.06.2021    Page 1/8 Data sheet | Item number: 234-216 www.wago.com/234-216 Item description PCB terminal strips with push-buttons and CAGE CLAMP® connection Double solder pins for high mechanical stability on PCB Ideal for in-the-field wiring thanks to simplified push-button actuation Convenient, tool-free operation Data Electrical data Ratings per IEC/EN Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 63 V Rated surge voltage (III/3) 2.5 kV Rated voltage (III/2) 160 V Rated surge voltage (III/2) 2.5 kV Nominal voltage (II/2) 320 V Rated surge voltage (II/2) 2.5 kV Rated current 6  A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Ratings per UL Approvals per UL 1059 Rated voltage UL (Use Group B) 150 V Rated current UL (Use Group B) 4  A Ratings per CSA Approvals per CSA Rated voltage CSA (Use Group B) 150 V Rated current CSA (Use Group B) 4  A Connection data Connection technology CAGE CLAMP® Actuation type Push-button Solid conductor 0.08 … 0.5 mm² / 28 … 20 AWG Fine-stranded conductor 0.08 … 0.5 mm² / 28 … 20 AWG Fine-stranded conductor; withobserve insulated ferrule Subject to changes. Please also the further product documentation!0.25 mm² WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.06.2021    Page 2/8 Data sheet | Item number: 234-216 www.wago.com/234-216 Fine-stranded conductor 0.08 … 0.5 mm² / 28 … 20 AWG Fine-stranded conductor; with insulated ferrule 0.25 mm² Fine-stranded conductor; with uninsulated ferrule 0.25 mm² Strip length 5 … 6 mm / 0.2 … 0.24 inch Conductor connection direction to PCB 90 ° Pole No. 16 Total number of connection points 16 Total number of potentials 16 Number of connection types 1 Number of levels 1 Physical data Pin spacing 2.5 mm / 0.098 inch Width 42.2 mm / 1.661 inch Height 18 mm / 0.709 inch Height from the surface 14 mm / 0.551 inch Depth 14.4 mm / 0.567 inch Solder pin length 4 mm Solder pin dimensions 0.5 x 0.75 mm Drilled hole diameter with tolerance 1.1 (+0.1) mm PCB contact PCB Contact THT Solder pin arrangement over the entire terminal strip (in-line) Number of solder pins per potential 2 Material data Color gray Material group I Insulation material Polyamide (PA66) Flammability class per UL94 V0 Clamping spring material Chrome nickel spring steel (CrNi) Contact material Electrolytic copper (ECu) Contact plating tin-plated Fire load 0.116 MJ Weight 8.1 g Environmental requirements Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.06.2021    Page 3/8 Data sheet | Item number: 234-216 www.wago.com/234-216 Environmental requirements Limit temperature range -60 … +105 °C Commercial data Product Group 4 (Printed Circuit) Packaging type BOX Country of origin CH GTIN 4044918651622 Customs tariff number 85369010000 Approvals / Certificates Country specific Approvals Logo Certificate name Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60998 NTR NL 6946 CCA DEKRA Certification B.V. EN 60998 2153951.01 CCA DEKRA Certification B.V. EN 60947-7-4 NTR NL 7787 CSA DEKRA Certification B.V. C22.2 1465035 KEMA/KEUR DEKRA Certification B.V. EN 60947-7-4 71-111042 Approval Additional Approval Text ABS American Bureau of Shipping - Ship Approvals Logo Certificate name 19HG1869876PDA Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.06.2021    Page 4/8 Data sheet | Item number: 234-216 www.wago.com/234-216 BV Bureau Veritas S.A. IEC 60998 11915/D0 BV DNV GL Det Norske Veritas, Germanischer Lloyd - TAE000016Z UL-Approvals Logo Approval Additional Approval Text UL UL International Germany GmbH UL 1059 Certificate name 20190731E45172 Optional accessories Ferrule Item no.: 216-131 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored www.wago.com/216-131 Item no.: 216-151 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-151 Item no.: 216-301 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-301 Item no.: 216-321 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-321 Marking accessories Item no.: 210-331/250-202 Marking strips; as a DIN A4 sheet; MARKED; 1-16 (400x); Height of marker strip: 2.3 mm/0.091 in; Strip length 182 mm; Horizontal marking; Self-adhesive; white www.wago.com/210-331 /250-202 Item no.: 210-331/250-204 www.wago.com/210-331 Marking strips; as a DIN A4 sheet; MARKED; 17-32 (400x); Height of marker strip: 2.3 mm/0.091 in; Strip /250-204 length 182 mm; Horizontal marking; Self-adhesive; white Item no.: 210-331/250-206 www.wago.com/210-331 Marking strips; as a DIN A4 sheet; MARKED; 33-48 (400x); Height of marker strip: 2.3 mm/0.091 in; Strip /250-206 length 182 mm; Horizontal marking; Self-adhesive; white Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.06.2021    Page 5/8 Data sheet | Item number: 234-216 www.wago.com/234-216 length 182 mm; Horizontal marking; Self-adhesive; white Item no.: 210-331/250-207 Marking strips; as a DIN A4 sheet; MARKED; 1-48 (100x); Height of marker strip: 2.3 mm/0.091 in; Strip length 182 mm; Horizontal marking; Self-adhesive; white www.wago.com/210-331 /250-207 Item no.: 210-648 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft; angled; short www.wago.com/210-648 Item no.: 210-719 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft www.wago.com/210-719 Tool Downloads Documentation Additional Information Technical explanations 2019 Apr 3 pdf 2.0 MB Download URL Download URL Download CAD/CAE-Data CAD data 2D/3D Models 234-216 PCB Design Symbol and Footprint 234-216 CAx data for your PCB design, consisting of "schematic symbols and PCB footprints", allow easy integration of the WAGO component into your development environment. Supported formats: Accel EDA 14 & 15 Altium 6 to current version Cadence Allegro DesignSpark Eagle Libraries KiCad Mentor Graphics BoardStation Mentor Graphics Design Architect Mentor Graphics Design Expedition 99 and 2000 OrCAD 9.X PCB and Capture PADS PowerPCB 3, 3.5, 4.X, and 5.X Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.06.2021    Page 6/8 Data sheet | Item number: 234-216 www.wago.com/234-216 PADS PowerPCB 3, 3.5, 4.X, and 5.X PADS PowerPCB and PowerLogic 3.0 PCAD 2000, 2001, 2002, 2004, and 2006 Pulsonix 8.5 or newer STL 3D STEP TARGET 3001! View Logic ViewDraw Quadcept Zuken CadStar 3 and 4 Zuken CR-5000 and CR-8000 PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian CAE data EPLAN Data Portal 234-216 URL Download ZUKEN Portal 234-216 URL Download URL Download Environmental Product Compliance Compliance Search Environmental Product Compliance 234-216 PCB terminal block; push-button; 0.5 mm²; Pin spacing 2.5 mm; 16-pole; CAGE CLAMP®; 0,50 mm²; gray Installation Notes Conductor termination Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.06.2021    Page 7/8 Data sheet | Item number: 234-216 www.wago.com/234-216 Nominal cross-section: 0.5 mm² (20 AWG), 0.75 mm² (18 AWG) only in every other position Inserting/removing a conductor. Marking Labeling via self-adhesive marking strips or factory direct marking. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.06.2021    Page 8/8
234-216 价格&库存
很抱歉,暂时无法提供与“234-216”相匹配的价格&库存,您可以联系我们找货
