237-102
237-102
    WAGO(万可电子)
    插件,P=5mm
    接线端子 1x2P 5mm 直插 排数:单排 每排Pin数:2
237-102 数据手册
Data sheet  |  Item number: 237-102 PCB terminal block; 2.5 mm²; Pin spacing 5 mm; 2-pole; 2,50 mm²; gray www.wago.com/237-102 Color: Data Electrical data Ratings per IEC/EN 60664-1 Rated voltage (III / 2) Rated impulse voltage (III / 2) Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com 250 V 2.5 kV Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 1/5 Data sheet  |  Item number: 237-102 www.wago.com/237-102 Rated impulse voltage (III / 2) 2.5 kV Rated current 16 A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Connection data Connection technology Screw clamp connection Actuation type Operating tool Solid conductor 0.5 … 2.5 mm² / 20 … 14 AWG Fine-stranded conductor 0.5 … 2.5 mm² / 20 … 14 AWG Strip length 5 … 7 mm / 0.2 … 0.28 inch Conductor entry angle to the PCB 0  ° No. of poles 2 Total number of connection points 2 Total number of potentials 2 Number of connection types 1 Number of levels 1 Geometrical Data Pin spacing 5/5.08 mm / 0.197/0.2 inch Width 5 mm / 0.197 inch Height from the surface 11 mm / 0.433 inch Depth 9 mm / 0.354 inch PCB contact PCB contact THT Solder pin arrangement over the entire terminal strip, in line Number of solder pins per potential 1 Material Data Color gray Material group I Insulating material Polyamide 66 (PA 66) Flammability class per UL94 V0 Clamping spring material Chrome nickel spring steel (CrNi) Contact material Electrolytic copper (ECu) Contact plating tin-plated Weight Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com 1.9 g Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 2/5 Data sheet  |  Item number: 237-102 www.wago.com/237-102 Weight 1.9 g Environmental Requirements Limit temperature range -60 … +105 °C Commercial data Packaging type BOX Country of origin IN GTIN 4045454539771 Customs Tariff No. 85369010000 Approvals / Certificates Country specific Approvals Logo Certificate name Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60947 NTR NL7137 CCA DEKRA Certification B.V. EN 60947 2160584.33 CSA DEKRA Certification B.V. C22.2 No. 158 70048844 Approval Additional Approval Text UL UL International Germany GmbH UL 1059 UL-Approvals Logo Certificate name 20190731E45172 Downloads Documentation Additional Information Technical explanations Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Apr 3, 2019 pdf Download Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 3/5 Data sheet  |  Item number: 237-102 www.wago.com/237-102 Technical explanations Apr 3, 2019 pdf 3.6 MB Download URL Download CAD/CAE-Data CAD data 2D/3D Models 237-102 CAE data EPLAN Data Portal 237-102 Download PCB Design Symbol and Footprint 237-102 URL Download CAx data for your PCB design, consisting of "schematic symbols and PCB footprints", allow easy integration of the WAGO component into your development environment. Supported formats: Accel EDA 14 & 15 Altium 6 to current version Cadence Allegro DesignSpark Eagle Libraries KiCad Mentor Graphics BoardStation Mentor Graphics Design Architect Mentor Graphics Design Expedition 99 and 2000 OrCAD 9.X PCB and Capture PADS PowerPCB 3, 3.5, 4.X, and 5.X PADS PowerPCB and PowerLogic 3.0 PCAD 2000, 2001, 2002, 2004, and 2006 Pulsonix 8.5 or newer STL 3D STEP TARGET 3001! View Logic ViewDraw Quadcept Zuken CadStar 3 and 4 Zuken CR-5000 and CR-8000 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 4/5 Data sheet  |  Item number: 237-102 www.wago.com/237-102 Zuken CR-5000 and CR-8000 PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian Installation Notes Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 5/5
237-102
物料型号:237-102,是WAGO品牌的PCB端子块。
器件简介:该端子块适用于2.5 mm²的导线,具有5 mm的端子间距和2个端子。
引脚分配:端子块有2个端子,每个端子可以连接0.5至2.5 mm²的实心或绞合导线。
参数特性:额定电压为250 V,额定脉冲电压为2.5 kV,额定电流为16 A。
功能详解:端子块采用螺钉夹持连接技术,适用于直插式(THT)PCB连接,端子上的所有焊盘都排列成一条直线。
应用信息:适用于-60至+105°C的温度范围,包装类型为盒装,原产国为印度。
封装信息:端子块的尺寸为宽5 mm、高11 mm、深9 mm,重量为1.9 g。
237-102 价格&库存
很抱歉,暂时无法提供与“237-102”相匹配的价格&库存,您可以联系我们找货
    库存:100
    237-102
    • 1+8.53200
    • 10+6.93360
    • 30+6.05880
    库存:23
