243-214
243-214
    WAGO(万可电子)
243-214 数据手册
Data sheet from 18.07.2013 Item no.: 243-214 Product description: MICRO JUNCTION AND DISTRIBUTION CONNECTORS FOR EIB APPLICATIONS 4-CONDUCTOR TERMINAL BLOCK Produkt kann von Bild abweichen / product may differ Packing unit 400 pieces RoHS compliant Product group 7 (Push Wire Conn.) Cross section to [AWG] 18 AWG Cross section to [AWG] 20 AWG Cross section [AWG] 22 - 0.6 mm Diameter to 0.8 mm Diameter to 1 mm Measured voltage EN 100 V Current intensity EN 6A Weight 0.835 g Color dark gray Wiring type Side-entry No. of connection Points 4 No. of potentials 1 Height 5.75 mm Height 0.226 in Width 10 mm Width 0.394 in Depth 10 mm Depth 1 von 3 0.394 in Strip length from 5 mm Strip length to 6 mm Strip length 0.22 in 2 von 3 Data sheet from 18.07.2013 Item no. Admission office Approval no. Voltage [V] Current [A] Cross section [ mm² ] 243-214 ABS 10-HN17750340X 100 6 4x0,5-1,0 243-214 CSA 18677-31 150 7 22-20 243-214 UR E45172 150 7 22-18 Sorting criteria: admission office - approval number © WAGO Kontakttechnik GmbH & Co. KG Specifications are subject to changes and errors may be expected 3 von 3
243-214 价格&库存
很抱歉,暂时无法提供与“243-214”相匹配的价格&库存,您可以联系我们找货
