2604-1102
2604-1102
    WAGO(万可电子)
    插件,P=5mm
    接线端子 间距:5.00mm 每排针脚数:2 排数:单排
2604-1102 数据手册
Data sheet | Item number: 2604-1102 PCB terminal block; lever; 4 mm²; Pin spacing 5 mm; 2-pole; Push-in CAGE CLAMP®; 4,00 mm²; gray www.wago.com/2604-1102 i Picture differs from the item. Color: L = (pole no. - 1) x pin spacing + 7.4 mm Item description PCB terminal blocks with levers and Push-in CAGE CLAMP® connection Push-in termination of solid and ferruled conductors Intuitive and tool-free operation clamping units be held open simultaneously – convenient for terminating multi-core cables Subject Several to changes. Please alsocan observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 24.09.2020    Page 1/6 Data sheet | Item number: 2604-1102 www.wago.com/2604-1102 Intuitive and tool-free operation Several clamping units can be held open simultaneously – convenient for terminating multi-core cables Testing can be performed both parallel and perpendicular to conductor entry Data Electrical data Ratings per IEC/EN 60664-1 Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 320 V Rated surge voltage (III/3) 4 kV Rated voltage (III/2) 400 V Rated surge voltage (III/2) 4 kV Nominal voltage (II/2) 630 V Rated surge voltage (II/2) 4 kV Rated current 32 A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Ratings per UL 1059 Approvals per UL 1059 Rated voltage UL (Use Group B) 300 V Rated current UL (Use Group B) 20 A Rated voltage UL (Use Group D) 300 V Rated current UL (Use Group D) 10 A Ratings per CSA Approvals per CSA Connection data Connection technology Push-in CAGE CLAMP® Actuation type Lever Solid conductor 0.2 … 4 mm² / 24 … 12 AWG Fine-stranded conductor 0.2 … 4 mm² / 24 … 12 AWG Fine-stranded conductor; with insulated ferrule 0.25 … 2.5 mm² Fine-stranded conductor; with uninsulated ferrule 0.25 … 2.5 mm² Fine-stranded conductor; with twin ferrule 0.25 … 1.5 mm² Strip length 9 … 11 mm / 0.35 … 0.43 inch Conductor connection direction to PCB 0  ° Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 24.09.2020    Page 2/6 Data sheet | Item number: 2604-1102 www.wago.com/2604-1102 Conductor connection direction to PCB 0  ° Pole No. 2 Total number of connection points 2 Total number of potentials 2 Number of connection types 1 Number of levels 1 Physical data Pin spacing 5 mm / 0.197 inch Width 12.4 mm / 0.488 inch Height 20.7 mm / 0.815 inch Height from the surface 16.7 mm / 0.657 inch Depth 19.2 mm / 0.756 inch Solder pin length 4 mm Solder pin dimensions 0.8 x 1 mm Drilled hole diameter with tolerance 1.3 (+0.1) mm PCB contact PCB contact THT Solder pin arrangement over the entire terminal strip (in-line) Number of solder pins per potential 2 Material Data Color gray Material group I Insulation material Polyamide (PA66) Flammability class per UL94 V0 Clamping spring material Chrome nickel spring steel (CrNi) Contact material Electrolytic copper (ECu) Contact plating tin-plated Color of actuator orange Weight 3.3 g Environmental Requirements Limit temperature range -60 … +105 °C Commercial data Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 24.09.2020    Page 3/6 Data sheet | Item number: 2604-1102 www.wago.com/2604-1102 Commercial data Packaging type BOX Country of origin DE GTIN 4055143564298 Customs tariff number 85369010000 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CB DEKRA Certification B.V. EN 60947-7-4 NL-47057 CSA DEKRA Certification B.V. C22.2 No. 158 70117145 KEMA/KEUR DEKRA Certification B.V. EN 60947-7-4 71100535 Approval Additional Approval Text Certificate name cURus Underwriters Laboratories Inc. UL 1059 E45172 UL-Approvals Logo Counterpart Compatible products ferrule Item no.: 216-108 Ferrule; Sleeve for 6 mm² / AWG 10; uninsulated; electro-tin plated www.wago.com/216-108 Item no.: 216-208 Ferrule; Sleeve for 6 mm² / AWG 10; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-208 acc. to DIN 46228, Part 4/09.90; yellow Item no.: 216-263 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/216-263 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 24.09.2020    Page 4/6 Data sheet | Item number: 2604-1102 www.wago.com/2604-1102 Item no.: 216-263 www.wago.com/216-263 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; red Item no.: 216-264 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-264 Item no.: 216-266 Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; blue www.wago.com/216-266 Item no.: 216-267 Ferrule; Sleeve for 4 mm² / AWG 12; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-267 acc. to DIN 46228, Part 4/09.90; gray Downloads Documentation Additional Information Technical explanations 03-Apr-2019 pdf 3.6 MB Download URL Download URL Download CAD/CAE-Data CAD data 2D/3D Models 2604-1102 PCB Design Symbol and Footprint 2604-1102 CAx data for your PCB design, consisting of "schematic symbols and PCB footprints", allow easy integration of the WAGO component into your development environment. Supported formats: Accel EDA 14 & 15 Altium 6 to current version Cadence Allegro DesignSpark Eagle Libraries KiCad Mentor Graphics BoardStation Mentor Graphics Design Architect Mentor Graphics Design Expedition 99 and 2000 OrCAD 9.X PCB and Capture Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 24.09.2020    Page 5/6 Data sheet | Item number: 2604-1102 www.wago.com/2604-1102 OrCAD 9.X PCB and Capture PADS PowerPCB 3, 3.5, 4.X, and 5.X PADS PowerPCB and PowerLogic 3.0 PCAD 2000, 2001, 2002, 2004, and 2006 Pulsonix 8.5 or newer STL 3D STEP TARGET 3001! View Logic ViewDraw Quadcept Zuken CadStar 3 and 4 Zuken CR-5000 and CR-8000 PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian CAE data ZUKEN Portal 2604-1102 URL Download Installation Notes Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 24.09.2020    Page 6/6
2604-1102 价格&库存
很抱歉,暂时无法提供与“2604-1102”相匹配的价格&库存,您可以联系我们找货
  • 1+36.761771+4.76981
  • 1+13.237851+1.71760
  • 5+12.454035+1.61590
  • 10+12.0185810+1.55940
库存:500
