2624-3303
2624-3303
    WAGO(万可电子)
    插件,P=7.5mm
    接线端子 间距:7.50mm 每排针脚数:3 排数:单排
2624-3303 数据手册
Printview: PCB terminal block; 4 mm²; Pin spacing 7.5 mm; 3-pole; Push-in CAGE CLAMP® - Item No.: 2624-3303 . PCB terminal block; 4 mm²; Pin spacing 7.5 mm; 3-pole; Push-in CAGE CLAMP® Item No.: 2624-3303 . PCB terminal block; 4 mm²; Pin spacing 7.5 mm; 3-pole; Push-in CAGE CLAMP® . Marking . Business data Supplier WAGO Item no. 2624-3303 GTIN / EAN 4055143582506 Content 1 Order amount 120 Customer item number . Notes Item description:Terminal strips with Push-in CAGE CLAMP® connectionPush-in termination of solid and ferruled, fine-stranded conductorsFlush-mount push-buttons that close with minimal force for convenient termination/removal of fine-stranded conductorsConvenient, tool-free operationVersions with/without test slots and spacersVersions available with custom internal commoning (factory assembly), e.g., commoning ground conductor Technical data Miscellaneous No. of poles 3 Pin spacing 7.5 mm (0.295 in) WAGO Kontakttechnik GmbH & Co. KG 1 Printview: PCB terminal block; 4 mm²; Pin spacing 7.5 mm; 3-pole; Push-in CAGE CLAMP® - Item No.: 2624-3303 Technical data Total number of connection points 3 Total number of potentials 3 Color gray Ratings per IEC/EN 60664-1 Rated voltage (III / 3) [V] 630 [V] Rated impulse voltage (III / 3) [kV] 6 [kV] Rated voltage (III/2) [V] 1000 [V] Rated impulse voltage (III / 2) [kV] 6 [kV] Rated voltage (II / 2) [V] 1000 [V] Rated impulse voltage (II / 2) [kV] 6 [kV] Rated current [A] 32 [A] Legend for ratings (III / 2) Overvoltage category III / Pollution degree 2 Number of connection objects 1 Number of levels 1 Connection technology Push-in CAGE CLAMP® Number of connection points connector 1 Actuation type Operating tool Solid conductor 0.2 … 6 mm² / 24 … 10 AWG Fine-stranded conductor 0.2 … 6 mm² / 24 … 10 AWG Fine-stranded conductor with ferrule with plastic collar 0.25 … 2.5 mm² / … Fine-stranded conductor with ferrule without plastic collar 0.25 … 2.5 mm² / … Strip length 10 … 12 mm / 0.39 … 0.47 Inch Conductor entry angle to the PCB [°] 90 [°] Solder pin arrangement over the entire terminal strip, in line Solder pin length [mm] 4 [mm] Drilled hole diameter (tolerance) [mm] 1.3(+ 0.1) [mm] Material group I Insulating material Polyamide 66 (PA 66) Flammability class per UL94 V0 Limit temperature range -60 … 105 °C Clamping spring material Chrome-nickel spring steel (CrNi) Contact material Electrolytic copper (Ecu) Contact plating tin-plated Weight [g] 5.68 [g] WAGO Kontakttechnik GmbH & Co. KG 2 Printview: PCB terminal block; 4 mm²; Pin spacing 7.5 mm; 3-pole; Push-in CAGE CLAMP® - Item No.: 2624-3303 Technical data Width 21.5 mm / 0.846 Inch Height 20.3 mm / 0.799 Inch Height from the surface 16.3 mm / 0.642 Inch Depth 16.3 mm / 0.642 Inch Pin spacing from [mm] 7.5 [mm] WAGO Kontakttechnik GmbH & Co. KG 3 Printview: PCB terminal block; 4 mm²; Pin spacing 7.5 mm; 3-pole; Push-in CAGE CLAMP® - Item No.: 2624-3303 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 4 Printview: PCB terminal block; 4 mm²; Pin spacing 7.5 mm; 3-pole; Push-in CAGE CLAMP® - Item No.: 2624-3303 . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 5
2624-3303 价格&库存
很抱歉,暂时无法提供与“2624-3303”相匹配的价格&库存,您可以联系我们找货
  • 1+48.353511+6.22959
  • 10+34.3358110+4.42363
  • 25+30.1186225+3.88031
  • 50+27.5042150+3.54349
  • 100+25.35213100+3.26623
  • 250+23.12885250+2.97979
  • 500+21.84133500+2.81391
  • 1000+20.828791000+2.68346
库存:71
2624-3303
