1
114
PCB Terminal Strips with Operating Levers 16 mm2
Pin Spacing: 10 mm, 15 mm
2716 Series
High-current PCB terminal strips with lever-actuated CAGE CLAMP®
Tool-free opening and closing – fingers open/close levers
everal clamping units can be held open simultaneously – convenient
S
for terminating multi-core cables
Four solder pins per contact point for high mechanical stability
600 V UL for pin spacing of 15 mm / 0.591 in.
P in and dimensions compatible to high-current, screw-type
PCB terminal blocks
Technical data:
Pin Spacing
Ratings per
Overvoltage category
Pollution degree
Rated voltage
Rated surge voltage
Nominal current
Approvals per
Usegroup UL 1059
Rated voltage
Nominal current UL
Nominal current CSA
10 mm
0.394 in.
IEC/EN 60664-1
III
III
II
3
2
2
320 V 320 V 630 V
4 kV
4 kV
4 kV
76 A
76 A
76 A
UL
B
C
D
300 V 150 V 300 V
55 A
55 A
10 A
15 mm
0.591 in.
IEC/EN 60664-1
III
III
II
3
2
2
800 V 1000 V 1000 V
8 kV
8 kV
8 kV
76 A
76 A
76 A
UL
B
C
D
600 V 600 V
65 A
65 A
Conductor and solder pin data:
Connection technology
Conductor size: solid
Conductor size: fine-stranded
AWG
Strip length
Conductor entry angle
Solder pin: length/width
Solder pin: drilled hole diameter
CAGE CLAMP®
1.5 … 16 mm2
1.5 … 16 mm2
1.5 … 10 mm2
(with insulated ferrule)
(with uninsulated ferrule)
1.5 … 10 mm2
16 … 6
12 … 13 mm / 0.47 … 0.51 in.
30° to PCB
4.5 mm / 0.95 x 1.2 mm
1.6+0.1 mm
Material data:
Material group
Insulating material
Flammability class per UL 94
Lower/Upper limit temperature
Clamping spring material
Contact material
Contact plating
Approvals are available online at: www.wago.com
Current-Carrying Capacity Curve
Pin spacing: 10 mm / Conductor size: 16 mm2 "f-st"
Based on: EN 60512-5-2 / Reduction factor: 1
Current in A
80
60
40
40
50
2-, 4-, 6-, 12-pole
2716 Series accessories:
I
Polyamide 66 (PA 66)
V0
-60 °C / +105 °C
Chrome-nickel spring steel (CrNi)
Electrolytic copper (ECu)
tin-plated
For more technical information, see Section 13.
60
70
80
90 100 105
Ambient operating temperature in °C
Marking accessories
Test plug
Conductor rated current
Page:
570
568
很抱歉,暂时无法提供与“2716-102”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+20.13550
- 33+19.53160
- 65+18.94530
