286-364/006-000
286-364/006-000
    WAGO(万可电子)
    WAGO - 286-364/006-000 - RELAY, SPST-NC, 250VAC, 30VDC, 5A
286-364/006-000 数据手册
Pluggable Module - Switching Relay 1/2 Front-entry , 1 make contact Data sheet A1 + 13 14 A2 Similar photo Item-No. Description Switching relay for medium switching power • Relay module with miniature switching relay 1 make contact. • Extended input voltage and temperature range for railway applications. • Installation on terminal block for pluggable module. The relay modules meet the requirements for an extended input voltage and temperature range in accordance with DIN EN 50155 / VDE 0115 part 200, “Railway applications. Electronical traction equipment”. They can be used on vehicles operated with alternating current having a supply from the catenary via a transformer with battery charger and battery. The constant deviation from the operating voltage can, in this case, vary between –30 % and +25 %. The temperature range extended to 70 °C corresponds to the maximum air temperature range in inner rooms of vehicles and housings located unprotected in the open air. WAGO Kontakttechnik GmbH & Co. KG Subject to design changes 02.12.2008 / d436400e.doc Postfach 2880 • D-32385 Minden Hansastr. 27 • D-32423 Minden 286-364/004-000 Pack.-unit pcs 1 Technical Data Contact material Input nominal voltage UN Input voltage range Current input at UN (coil 20 °C) Max. switching voltage Max. continuous current AgSnO2 DC 24 V UN –30 %...+25 % 10 mA AC 250 V 5 A modules not in a row 3 A modules in a row (see diagram) Max. breaking power (resistive) AC 1250 VA (resistive) DC see load limiting value graph Recommended min. load ≥100 mA / AC/DC 12 V Pull-in/operating power 140 mW / 280 mW Pull-in/dropout/bounce timetyp 5 ms / 4 ms / 5 ms Operating at normal rating 100 % continuous duty Dielectric strength contact/ coil 2.5 kV open contact 1 kV Nominal voltage acc. to VDE 0110 / Part1/ 4.97 IEC 60664-1 250 V / 4 kV / 3 6 Mechanical life 5 x 10 switching operations 4 at max.load (resistive) 5 x 10 switching operations Ambient operating temperature -25 °C...+70 °C Storage temperature -40 °C...+70 °C Module dimensions (W x H) (10 x 82,5*) mm / (0.394 x 3.25*) in * from upper edge of DIN 35 rail Tel.: Fax.: 05 71 / 8 87-0 E-Mail: 05 71 / 8 87-169 Web: info@wago.com http://www.wago.com Pluggable Module - Switching Relay 2/2 Front-entry , 1 make contact Data sheet Standards / prescriptions Load limiting value graph U (V) 10³ Accessories Terminal block Dimensions (W x D) DIN VDE 0115 Part 200 DIN VDE 0160 and IEC 60255 DIN VDE 0435 (corresponding parts) DIN EN 50155 280-608 (12 x 73) mm / (0.472 x 2.874) in 10² 1010,1 1 10 / (A) Power diagram Cont. current I (A) 50 % cont. duty 5 4 3 2 1 75 % cont. duty 100 % cont. duty 1 2 3 4 not in a row 5 Modules in a row Note: Inductive loads have to be attenuated by an appropriate protective circuit in order to protect relay coils and contacts! WAGO Kontakttechnik GmbH & Co. KG Subject to design changes 02.12.2008 / d436400e.doc Postfach 2880 • D-32385 Minden Hansastr. 27 • D-32423 Minden Tel.: Fax.: 05 71 / 8 87-0 E-Mail: 05 71 / 8 87-169 Web: info@wago.com http://www.wago.com
286-364/006-000 价格&库存
很抱歉,暂时无法提供与“286-364/006-000”相匹配的价格&库存,您可以联系我们找货
