709-581
    WAGO(万可电子)
    WAGO - 709-581 - SWITCHGEAR CABINET OUTLET, 16A, 250VAC
709-581 数据手册
Data sheet  |  Item number: 709-581 Switchgear cabinet outlet; for DIN-rail and screw mounting; for plug, type F, CEE 7/4 (Schuko); common in DE, NL, AT; with LED status indicator; with Push-in Cage Clamp double connection www.wago.com/709-581 Color: Data 07.01.2019    Page 1/3 Data sheet  |  Item number: 709-581 www.wago.com/709-581 Data Electrical data Voltage type (1) AC Ratings per IEC/EN 60664-1 Rated voltage (III / 3) 250 V Rated impulse voltage (III / 3) 2 kV Rated current 16 A Connection data Connection type (1) L, PE, N Connection technology Push-in CAGE CLAMP® Actuation type Push-in Actuation direction (1) Operation parallel to conductor entry Connectable conductor materials Copper Nominal cross section 2.5 mm² Solid conductor 0.2 … 2.5 mm² / 24 … 14 AWG Stranded conductor 0.2 … 2.5 mm² / 24 … 14 AWG Fine-stranded conductor 0.2 … 2.5 mm² / 24 … 14 AWG Strip length 9 … 10 mm / 0.35 … 0.39 Inch No. of poles 3 Number of connection types 3 Number of test slots 2 Geometrical Data Width 45 mm / 1.772 inch Height 65 mm / 2.559 inch Height from the surface 65 mm / 2.559 inch Height from upper-edge of DIN-35 rail 59.8 mm / 2.354 inch Depth 84.7 mm / 3.335 inch Mechanical data Type of mounting DIN-35 rail Degree of protection IP20 Potential marking L N Material Data Color light gray Material group I Insulating material Polyamide 66 (PA 66) 07.01.2019    Page 2/3 Data sheet  |  Item number: 709-581 www.wago.com/709-581 Insulating material Polyamide 66 (PA 66) Flammability class per UL94 V0 Clamping spring material Chrome nickel spring steel (CrNi) Contact material Copper alloy Contact plating Sn Weight 81.6 g Commercial data Packaging type BOX Country of origin BG GTIN 4055143721295 Approvals / Certificates Country specific Approvals Logo Approval Certificate name VDE VDE Prüf- und Zertifizierungsinstitut 40047680 (IEC 60884-1) Downloads smartDATA CAD data 3D Download 709-581 URL Download   Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 07.01.2019    Page 3/3
709-581 价格&库存
很抱歉,暂时无法提供与“709-581”相匹配的价格&库存,您可以联系我们找货
  • 1+162.998901+20.28350
  • 2+145.019082+18.04610
  • 5+126.857645+15.78610
    • 1+151.05271
    库存:34
