Data sheet | Item number: 733-102/037-000
1-conductor female plug; 100% protected against mismating; Locking lever;
0.5 mm²; Pin spacing 2.5 mm; 2-pole; 0,50 mm2; light gray
www.wago.com/733-102/037-000
Color:
L = pole no. x pin spacing
Item description
Universal connection for all conductor types
25.09.2019 Page 1/6
Easy cable pre-assembly and on-unit wiring via vertical and horizontal CAGE CLAMP® actuation
Strain relief plates for factory and in-the-field assembly
Coding via coding fingers
Safety information 1:
The MULTI CONNECTION SYSTEM (MCS) is designed without breaking capacity for compliance with DIN EN 61984. When used as intended, MCS
Connectors shall not be connected/disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are
not live when unmated.
Data
Electrical data
Ratings per IEC/EN 60664-1
Rated voltage (III / 3)
100 V
Rated impulse voltage (III / 3)
2.5 kV
Rated voltage (III / 2)
160 V
Rated impulse voltage (III / 2)
2.5 kV
Rated voltage (II / 2)
320 V
Rated impulse voltage (II / 2)
2.5 kV
Rated current
6 A
Approvals per UL 1059
Rated voltage UL (Use Group B)
150 V
Rated current UL (Use Group B)
4 A
Approvals per CSA
Rated voltage CSA (Use Group B)
150 V
Rated current CSA (Use Group B)
4 A
Connection data
Connection technology
CAGE CLAMP®
Actuation type
Operating tool
Solid conductor
0.08 … 0.5 mm² / 28 … 20 AWG
Fine-stranded conductor
Fine-stranded conductor with ferrule with plastic collar
0.25 … 0.34 mm²
Fine-stranded conductor with ferrule without plastic collar
0.25 … 0.34 mm²
Strip length
5 … 6 mm / 0.2 … 0.24 inch
Total number of connection points
2
Total number of potentials
2
25.09.2019 Page 2/6
2
Number of connection types
1
Number of levels
1
Conductor entry direction to mating direction
0 °
No. of poles
2
Geometrical Data
Pin spacing
2.5 mm / 0.098 inch
Width
16.8 mm / 0.661 inch
Height
11.8 mm / 0.465 inch
Depth
17.1 mm / 0.673 inch
Plug connection
Contact type (pluggable connector)
Female connector/socket
Connector connection type
for conductors
Mismating protection
Yes
Locking of plug-in connection
locking lever
Material Data
Color
light gray
Material group
I
Insulating material
Polyamide 66 (PA 66)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Copper alloy
Contact plating
tin-plated
Fire load
0.032 MJ
Weight
1.45 g
Environmental Requirements
Limit temperature range
-60 … +100 °C
Commercial data
Product Group
3 (Multi Conn. System)
Country of origin
DE
GTIN
4045454215491
Customs Tariff No.
85366990990
Approvals / Certificates
UL-Approvals
Certificate
25.09.2019 Page 3/6
UL-Approvals
Logo
Approval
Additional Approval Text
UL
Underwriters Laboratories Inc.
UL 1059
Certificate
name
20190122E45172
Compatible products
Strain relief plate
Item no.: 734-127
Strain relief plate; light gray
www.wago.com/734-127
Item no.: 216-131
Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-131
Item no.: 216-132
Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-132
Item no.: 216-151
www.wago.com/216-151
Item no.: 216-152
www.wago.com/216-152
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-301
Item no.: 216-302
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-302
Item no.: 216-321
www.wago.com/216-321
Item no.: 216-322
www.wago.com/216-322
ferrule
Marking accessories
Item no.: 210-331/250-202
Marking strips; as a DIN A4 sheet; MARKED; 1-16 (400x); Height of marker strip: 2.3 mm/0.091 in; Strip
length 182 mm; Horizontal marking; Self-adhesive; white
www.wago.com/210-331
/250-202
Item no.: 210-331/250-204
Marking strips; as a DIN A4 sheet; MARKED; 17-32 (400x); Height of marker strip: 2.3 mm/0.091 in; Strip
/250-204
Item no.: 210-331/250-206
Marking strips; as a DIN A4 sheet; MARKED; 33-48 (400x); Height of marker strip: 2.3 mm/0.091 in; Strip
/250-206
25.09.2019 Page 4/6
Item no.: 210-331/250-207
Marking strips; as a DIN A4 sheet; MARKED; 1-48 (100x); Height of marker strip: 2.3 mm/0.091 in; Strip
/250-207
Item no.: 735-500
Test pin; 1 mm Ø; with solder connection for test wire
www.wago.com/735-500
Item no.: 210-251
Operating tool; for female and male connectors with CAGE CLAMP® connection; MCS MINI & MICRO;
yellow
www.wago.com/210-251
Item no.: 210-719
Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft
www.wago.com/210-719
Item no.: 233-331
Operating tool; for female and male connectors with CAGE CLAMP® connection; insulated; yellow
www.wago.com/233-331
Item no.: 233-332
Operating tool; for 233 and 733 Series; of insulating material
www.wago.com/233-332
Item no.: 233-335
www.wago.com/233-335
Item no.: 733-130
Operating tool; for male and female connectors with CAGE CLAMP®; loose; natural
www.wago.com/733-130
Item no.: 733-191
Operating tool; for male and female connectors with CAGE CLAMP®; loose; yellow
www.wago.com/733-191
check
tools
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
3.6 MB
Download
URL
Download
CAD/CAE-Data
CAD data
3D Download 733-102/037-000
EPLAN
EPLAN Data Portal 733-102/037-000
Download
25.09.2019 Page 5/6
Subject to changes.
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
25.09.2019 Page 6/6
很抱歉,暂时无法提供与“733-102/037-000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 29+28.1863029+3.64896
- 50+25.8561050+3.34730
- 100+23.89250100+3.09309
- 250+21.86239250+2.83028
- 500+20.60118500+2.66700
- 1000+19.573551000+2.53397
- 国内价格
- 1+54.19932
- 10+38.43074
- 100+28.48787
- 250+26.04368
- 500+24.61988
- 1000+23.51643
