Data sheet from 27.01.2009
Item no.:
733-336
Product description:
HEADER; STRAIGHT SOLDER PIN0.8x0.8 MM; 6 POLE; PIN
SPACING 2.5 MM / 0.098 IN; 100% PROTECTED AGAINST
MISMATING; MATING DIRECTION PERPENDICULAR TO
PCB
Packing unit 200 pieces
Product group
3 (Multi Conn. System)
Pin spacing from
2,5 mm
Pin spacing from
0,098 in
pole count
6
Measured voltage EN
250 V
Measured shock voltage
2,5 kV
Pollution degree
2
Current intensity EN
4A
Weight
0,883 g
Color
light grey
Height
8,9 mm
Height
0,35 in
Width
17,5 mm
Width
0,689 in
Depth
7,8 mm
Depth
0,307 in
1 von 2
Item number
Admission office
Approval no.
Voltage [V]
Current [A]
733-336
ABS
04-HG469925-PDA
250
4
733-336
BV
11915/A0
250
4
733-336
CCA
NL5640
250
4
733-336
CSA
154112-1465035
150
4
733-336
DNV
E-6997
250
4
733-336
GL
17296-00HH
250
4
733-336
KEMA
2077592.01
250
4
733-336
LR
96/20035
250
6
733-336
RMR
11130002
250
4
733-336
UR
E45171
250
4
733-336
UR
E45172
150
4
Sorting criteria: admission office - approval number
© WAGO Kontakttechnik GmbH & Co. KG
Specifications are subject to changes and errors may be expected
2 von 2
Cross section [ mm² ]
28-20
28-20
很抱歉,暂时无法提供与“733-340”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+52.933511+6.86119
- 10+44.7799910+5.80434
- 100+28.19908100+3.65514
- 500+26.02631500+3.37351
- 1000+24.812931000+3.21623
- 国内价格 香港价格
- 1+44.395781+5.75454
- 10+37.7523910+4.89343
- 100+32.08905100+4.15936
- 500+28.64446500+3.71287
- 1000+27.278281000+3.53579
- 国内价格
- 1+15.97320
- 10+13.31640
- 30+11.65320
