Printview: Female connector; 3-pole; Pin spacing 3.5 mm / 0.138 in; 100% protected against mismating;
codable - Item No.: 734-103
protected against mismating; codable
Item No.: 734-103
Female connector; 3-pole; Pin spacing 3.5 mm / 0.138 in; 100% protected against mismating; codable
Marking
Business data
Supplier
WAGO
Item no.
734-103
GTIN / EAN
4044918492416
Content
1
Order amount
200
Customer item number
Notes
Item description:Universal connection for all conductor typesEasy cable pre-assembly and on-unit wiring via vertical
and horizontal CAGE CLAMP® actuationStrain relief plates and housings for in-the-field assembly100% protected
against mismatingCoding option available
Technical data
Miscellaneous
Packaging type
BOX
Ratings per
IEC/EN 60664-1
Rated voltage (III / 3) [V]
160 [V]
WAGO Kontakttechnik GmbH & Co. KG
1
Technical data
Rated impulse voltage (III / 3) [kV]
2.5 [kV]
Rated voltage (III/2) [V]
160 [V]
Rated impulse voltage (III / 2) [kV]
2.5 [kV]
Rated voltage (II / 2) [V]
320 [V]
Rated impulse voltage (II / 2) [kV]
2.5 [kV]
Rated current [A]
10 [A]
Legend (ratings)
(III / 2) Overvoltage category III / Pollution degree 2
Approvals per
UL 1059
Rated voltage UL (Use Group B) [V]
300 [V]
Rated current UL (Use Group B) [A]
10 [A]
Rated voltage UL (Use Group D) [V]
300 [V]
Rated current UL (Use Group D) [A]
10 [A]
Rated voltage CSA (Use Group B) [V]
300 [V]
Rated current CSA (Use Group B) [A]
10 [A]
Rated voltage CSA (Use Group D) [V]
300 [V]
Rated current CSA (Use Group D) [A]
10 [A]
No. of poles
3
Total number of connection points
3
Total number of potentials
3
Number of connection types
1
Number of levels
1
Connection technology
CAGE CLAMP®
Number of connection points (connection type)
1
Actuation type
Operating tool
Solid conductor
0.08 … 1.5 mm² / 28 … 14 AWG
Fine-stranded conductor
Fine-stranded conductor with ferrule with plastic collar
0.25 … 1.5 mm² / …
Fine-stranded conductor with ferrule without plastic collar 0.25 … 1.5 mm² / …
Strip length
6 … 7 mm / 0.24 … 0.28 Inch
Pin spacing
3.5 mm (0.138 in)
Width
12.7 mm / 0.5 Inch
Height
13.4 mm / 0.528 Inch
Depth
18.6 mm / 0.732 Inch
Contact type (pluggable connector)
Female connector/socket
2
Technical data
Connector connection type
for conductors
Mismating protection
ja
Color
light gray
Material group
I
Insulating material
Polyamide 66 (PA 66)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Copper alloy
Contact plating
tin-plated
Fire load [MJ]
0.042 [MJ]
Weight [g]
2.461 [g]
Limit temperature range
-60 … 100 °C
3
Images & drawings
4
5
6
Address
Hansastr. 27
32423 Minden
Telefon: 0571/887-0
Fax: 0571/887-169
http://www.wago.com
© WAGO Kontakttechnik GmbH & Co. KG
Technische Änderungen und Irrtümer vorbehalten.
7
很抱歉,暂时无法提供与“734-103”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+60.776841+7.86589
- 国内价格
- 1+14.06160
- 10+11.71800
- 30+10.24920
- 国内价格 香港价格
- 1+32.767381+4.24084
- 10+32.0689210+4.15044
- 25+31.7471325+4.10879
- 50+31.4253550+4.06715
- 100+23.45622100+3.03576
- 250+23.22256250+3.00552
- 500+22.98810500+2.97518
- 1000+22.278211000+2.88330
- 国内价格 香港价格
- 1+32.012091+4.14309
- 10+31.3298310+4.05479
- 25+31.0156725+4.01413
- 50+30.7015250+3.97347
- 100+22.91537100+2.96577
- 250+22.68731250+2.93625
- 500+22.45846500+2.90663
- 1000+21.764731000+2.81685
