734-124
734-124
    WAGO(万可电子)
    P=3.5mm
    接线端子 间距:3.50mm
734-124 数据手册
Data sheet from 15.09.2013 Item no.: 734-124 Product description: FEMALE CONNECTOR 24 POLE PIN SPACING 3.5 MM / 0.138 IN 100% PROTECTED AGAINST MISMATING WITH CODING FINGERS Produkt kann von Bild abweichen / product may differ Packing unit 25 pieces RoHS compliant Product group 3 (Multi Conn. System) Weight 18.309 g Color light gray No. of connection Points 24 No. of potentials 24 pole count 24 Height 13.4 mm Height 0.528 in Width 86.2 mm Width 3.394 in Depth 18.6 mm Depth 0.732 in Pin spacing from 3.5 mm Pin spacing from 0.138 in Pollution degree 2 Measured voltage EN 160 V Measured shock voltage 2.5 kV Current intensity EN 1 von 4 10 A Pollution degree 2 Measured voltage EN 320 V Measured shock voltage 2.5 kV Current intensity EN 10 A 2 von 4 Data sheet from 15.09.2013 Connection method CAGE CLAMP® CONNECTION Cross section [mm²] 0.08 - 1.5 mm² Wiring method solid Cross section [mm²] 0.08 - 1.5 mm² Cross section [mm²] 0.25 - 1.5 mm² Cross section [mm²] 0.25 - 1.5 mm² Cross section [AWG] 28 - 14 AWG Strip length from 6 mm Strip length to 7 mm Material group I xxx-xxx/035-000 Strain relief plate 35 mm 3 von 4 Data sheet from 15.09.2013 Item no. Admission office Approval no. Voltage [V] Current [A] Cross section [ mm² ] 734-124 ABS 04-HG469925/1-PDA 250 10 0,5-1,5 734-124 CCA NL5641 250 10 0,5-1,5 734-124 CSA 154112-1465035 300 10 28-14 734-124 KEMA 2077592.02 250 10 0,5-1,5 734-124 UR E45171 250 10 28-14 734-124 UR E45172 300 10 28-14 Sorting criteria: admission office - approval number © WAGO Kontakttechnik GmbH & Co. KG Specifications are subject to changes and errors may be expected 4 von 4
734-124
- 物料型号:734-124 - 器件简介:24极母头连接器,具有3.5毫米/0.138英寸的引脚间距,100%防错配对,带有编码手指。 - 引脚分配:24个连接点,24个极点。 - 参数特性: - 重量:18.309克 - 颜色:浅灰色 - 高度:13.4毫米/0.528英寸 - 宽度:86.2毫米/3.394英寸 - 深度:18.6毫米/0.732英寸 - 污染等级:2 - 额定电压:160V(污染等级2时为320V) - 额定冲击电压:2.5kV - 额定电流:1von4为10A,2von4为10A - 功能详解:CAGE CLAMP®连接方式,适用于0.08至1.5平方毫米的实心导线或0.25至1.5平方毫米的绞合导线。 - 应用信息:RoHS合规,包装单位为25件。 - 封装信息:材料组xxx-xxx/035-000,带有35毫米的防拔板。
734-124 价格&库存
很抱歉,暂时无法提供与“734-124”相匹配的价格&库存,您可以联系我们找货
