770-724
770-724
    WAGO(万可电子)
    P=10mm
    接线端子 间距:10.00mm 1x4P 面板安装
770-724 数据手册
3 Handling WINSTA ®  MIDI, 770 Series Conductor termination with CAGE CLAMP® S Preparation We recommend pulling the pre-latched strain relief housing PWFSUIFDBCMFQSJPSUPUFSNJOBUJPO)PXFWFS UIFTUSBJO SFMJFGDBOCFNPVOUFEBUBMBUFSUJNFBTXFMM 1. 4USJQMFOHUI PVUFSJOTVMBUJPO Strip length  3. Extended ground conductor ǒYNN1 ǒNN ǒNN 5PUFSNJOBUFmOFTUSBOEFEDPOEVDUPST PQFODMBNQJOHVOJU WJBNNTDSFXESJWFSBOEJOTFSUTUSJQQFEDPOEVDUPSVOUJM it hits backstop. Conductor termination with CAGE CLAMP® S Insert stripped solid conductor until it hits backstop. 5PUFSNJOBUFmOFTUSBOEFEDPOEVDUPST PQFODMBNQJOHVOJU WJBNNTDSFXESJWFSBOEJOTFSUTUSJQQFEDPOEVDUPSVOUJM it hits backstop. 5PSFNPWFUIFDPOEVDUPS BDUVBUFUIFDMBNQWJBN TDSFXESJWFSBOEQVMMPVUUIFDPOEVDUPS Prepare strain relief housing by snapping together upper and bottom part. 5JHIUFOTUSBJOSFMJFGTDSFXVTJOHBNNTDSFXESJWFS Strain relief installation -BUDIUIFTUSBJOSFMJFGIPVTJOHPOUIFQMVHTPDLFU/PUFUIF i501wJOTDSJQUJPO Variable coding Simply break or cut off the coding pin from the socket. Marking *OTFSUDPEJOHQJOJOUPQMVH CSFBLmSTU VOUJMJUFOHBHFT 14USJQMFOHUI PVUFSJOTVMBUJPOQPMFNN UPQPMFNN Marking strain relief housing via WSB quick marking system. 3 WINSTA® MIDI Snap-In Sockets and Plugs, 4-Pole  2 x 0.5 – 4 mm² 1 400 V/6 kV/3 IN 25 A Cutout dimensions Plate thickness: 0.5 – 2 mm Cutout tolerance: + 0.1 mm 2 x AWG 20 – 12 L 9 mm / 0.35 in 2 Approvals 2 x 0.5 – 4 mm² 1 400 V/6 kV/3 IN 25 A 2 x AWG 20 – 12 L 9 mm / 0.35 in 2 Approvals Description Color Pluggable connectors, snap-in device connection, 4-pole, with CAGE CLAMP®S connection Socket  Item No. black XIJUF Pack. Unit Color Item No. Pack. Unit Socket with protruding interface 770-704 770-724    black XIJUF 770-704/009-000 770-724/009-000   'PSi$MFBO&BSUIwBQQMJDBUJPOT MPBEJOHVQUP"  green 770-2324   Item-Specific Accessories Lockout cap, GPSTPDLFU TFQBSBCMF QPMF black XIJUF  Lockout cap, GPSTPDLFU TFQBSBCMF QPMF 770-201  770-221  black XIJUF 770-201  770-221 Accessories, 770 Series Lockout cap, GPSDVUPVU QPMF black XIJUF   black XIJUF 770-644  770-694 1,2 >
770-724 价格&库存
很抱歉,暂时无法提供与“770-724”相匹配的价格&库存,您可以联系我们找货
