773-332
773-332
    WAGO(万可电子)
773-332 数据手册
Data sheet  |  Item number: 773-332 Mounting carrier; 773 Series - 2.5 mm² / 4 mm² / 6 mm²; for DIN-35 rail mounting/screw mounting; orange www.wago.com/773-332 Color: Data Geometrical Data Width 18 mm / 0.709 inch Height from upper-edge of DIN-rail 26 mm / 1.024 inch Depth 61 mm / 2.402 inch Material Data Color orange Fire load 0.255 MJ Weight 8.5 g Commercial data Product Group 7 (Push Wire Conn.) Packaging type BOX Country of origin DE GTIN 4044918526524 Customs tariff number 39269097900 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 22.05.2020    Page 1/5 Data sheet  |  Item number: 773-332 www.wago.com/773-332 Customs tariff number 39269097900 Counterpart Compatible products Marking accessories Item no.: 210-834 Marking strips; on reel; 5 mm wide; plain; Self-adhesive; white www.wago.com/210-834 General accessories Item no.: 773-102 PUSH WIRE® connector for junction boxes; for solid and stranded conductors; max. 2.5 mm²; 2conductor; transparent housing; yellow cover; Surrounding air temperature: max 60°C; 2,50 mm² www.wago.com/773-102 Item no.: 773-104 PUSH WIRE® connector for junction boxes; for solid and stranded conductors; max. 2.5 mm²; 4conductor; transparent housing; orange cover; Surrounding air temperature: max 60°C; 2,50 mm² www.wago.com/773-104 Item no.: 773-106 PUSH WIRE® connector for junction boxes; for solid and stranded conductors; max. 2.5 mm²; 6conductor; transparent housing; violet cover; Surrounding air temperature: max 60°C; 2,50 mm² www.wago.com/773-106 Item no.: 773-108 PUSH WIRE® connector for junction boxes; for solid and stranded conductors; max. 2.5 mm²; 8conductor; transparent housing; dark gray cover; Surrounding air temperature: max 60°C; 2,50 mm² www.wago.com/773-108 Item no.: 773-112 PUSH WIRE® connector for junction boxes; for solid and stranded conductors; max. 2.5 mm²; 2conductor; transparent housing; green cover; Surrounding air temperature: max 60°C; 2,50 mm² www.wago.com/773-112 Item no.: 773-114 PUSH WIRE® connector for junction boxes; for solid and stranded conductors; max. 2.5 mm²; 4conductor; transparent housing; green cover; Surrounding air temperature: max 60°C; 2,50 mm² www.wago.com/773-114 Item no.: 773-116 PUSH WIRE® connector for junction boxes; for solid and stranded conductors; max. 2.5 mm²; 6conductor; transparent housing; green cover; Surrounding air temperature: max 60°C; 2,50 mm² www.wago.com/773-116 Item no.: 773-118 PUSH WIRE® connector for junction boxes; for solid and stranded conductors; max. 2.5 mm²; 8conductor; transparent housing; green cover; Surrounding air temperature: max 60°C; 2,50 mm² www.wago.com/773-118 Item no.: 773-124 PUSH WIRE® connector for junction boxes; for solid and stranded conductors; max. 2.5 mm²; 4conductor; transparent housing; light gray cover; Surrounding air temperature: max 60°C; 2,50 mm² www.wago.com/773-124 Item no.: 773-162 PUSH WIRE® connector for junction boxes; for solid and stranded conductors; max. 2.5 mm²; 2conductor; transparent housing; yellow cover; Surrounding air temperature: max 60°C; 2,50 mm² www.wago.com/773-162 Item no.: 773-164 PUSH WIRE® connector for junction boxes; for solid and stranded conductors; max. 2.5 mm²; 4conductor; transparent housing; orange cover; Surrounding air temperature: max 60°C; 2,50 mm² www.wago.com/773-164 Item no.: 773-166 PUSH WIRE® connector for junction boxes; for solid and stranded conductors; max. 2.5 mm²; 6Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/773-166 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 22.05.2020    Page 2/5 Data sheet  |  Item number: 773-332 www.wago.com/773-332 PUSH WIRE® connector for junction boxes; for solid and stranded conductors; max. 2.5 mm²; 6conductor; transparent housing; black cover; Surrounding air temperature: max 60°C; 2,50 mm² www.wago.com/773-166 Item no.: 773-168 PUSH WIRE® connector for junction boxes; for solid and stranded conductors; max. 2.5 mm²; 8conductor; transparent housing; dark gray cover; Surrounding air temperature: max 60°C; 2,50 mm² www.wago.com/773-168 Item no.: 773-173 PUSH WIRE® connector for junction boxes; for solid and stranded conductors; max. 6 mm²; 3conductor; transparent housing; red cover; Surrounding air temperature: max 60°C; 6,00 mm² www.wago.com/773-173 Item no.: 773-514 PUSH WIRE® connector for junction boxes; for solid and stranded conductors; max. 2.5 mm²; 4conductor; Black housing; black cover; Max. surrounding air temperature: 105 °C; 2,50 mm² www.wago.com/773-514 Item no.: 773-602 PUSH WIRE® connector for junction boxes; for solid conductors; max. 4 mm²; 2-conductor; Brown clear www.wago.com/773-602 housing; white cover; Surrounding air temperature: max 60°C; 2,50 mm² Item no.: 773-604 PUSH WIRE® connector for junction boxes; for solid conductors; max. 4 mm²; 4-conductor; Brown clear www.wago.com/773-604 housing; red cover; Surrounding air temperature: max 60°C; 2,50 mm² Item no.: 773-606 PUSH WIRE® connector for junction boxes; for solid conductors; max. 4 mm²; 6-conductor; Brown clear www.wago.com/773-606 housing; brown cover; Surrounding air temperature: max 60°C; 2,50 mm² Downloads Documentation Bid Text 773-332 Feb 19, 2019 xml 2.6 kB Download May 17, 2017 doc 24.1 kB Download Apr 3, 2019 pdf 2.1 MB Download URL Download URL Download GAEB X81 - Datei 773-332 doc - Datei Additional Information Technical explanations CAD/CAE-Data CAD data 2D/3D Models 773-332 CAE data EPLAN Data Portal 773-332 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 22.05.2020    Page 3/5 Data sheet  |  Item number: 773-332 www.wago.com/773-332 URL WSCAD Universe 773-332 Download Handling Instructions Assembly Snap the mounting carrier onto the DIN-rail. Use the cover as an end plate. Remove the mounting carrier from the DINrail. Application Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 22.05.2020    Page 4/5 Data sheet  |  Item number: 773-332 www.wago.com/773-332 A mounting carrier (see accessories) suits applications where the connectors must be marked and secured in position. The DIN-35 rail-mount carrier fits up to two connectors and can also be mounted on on a flat surface using two screws. Using this PUSH WIRE® connector, a large range of wiring applications can be achieved in distribution or junction boxes. To mention just a few: potential multiplication and changing from or to 6 mm² conductor size. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 22.05.2020    Page 5/5
773-332 价格&库存
很抱歉,暂时无法提供与“773-332”相匹配的价格&库存,您可以联系我们找货
    • 50+4.92158
    库存:150
