Printview: PCB terminal strip; 1 solder pin/pole, staggered; 3-pole; pin spacing 3.5 mm / 0.138 in; with
push-button; with test port for test plug up to 2 mm Ø - Item No.: 805-103
spacing 3.5 mm / 0.138 in; with push-button; with test port for test
plug up to 2 mm Ø
Item No.: 805-103
PCB terminal strip; 1 solder pin/pole, staggered; 3-pole; pin spacing 3.5 mm / 0.138 in; with push-button; with test
Marking
Business data
Supplier
WAGO
Item no.
805-103
GTIN / EAN
4045454731519
Content
1
Order amount
105
Customer item number
Notes
Terminal strips with push-button actuated Push-in CAGE CLAMP®Push-in termination of solid and ferruled, finestranded conductorsPush-buttons that close flush with minimal force for convenient termination/removal of finestranded conductorsConvenient, tool-free operationVersions with/without test slots and spacersVersions available
with custom internal commoning (factory assembly), e.g., commoning ground conductor
Technical data
Miscellaneous
No. of poles
3
Pin Spacing
3.5 mm (0.137 in %)
Total number of connection points
3
Total number of potentials
3
Color
gray
WAGO Kontakttechnik GmbH & Co. KG
1
Technical data
Ratings according to 1
IEC/EN 60664-1
Overvoltage category EN 1
III
Pollution degree (1)
2
Rated voltage EN (1) [V]
320 [V]
Rated surge voltage (1) [kV]
4 [kV]
Nominal current [A]
17.5 [A]
Overvoltage category EN 2
II
Degree of pollution (2)
2
Rated voltage EN (2) [V]
630 [V]
Rated surge voltage (2) [kV]
4 [kV]
Nominal current (2) [A]
17.5 [A]
Overvoltage category EN 3
III
Degree of pollution (3)
3
Rated voltage EN (3) [V]
250 [V]
Rated surge voltage (3) [kV]
4 [kV]
Nominal current (3) [A]
17.5 [A]
Number of individual connection objects at the product
1
Connection technology (1)
Push-in CAGE CLAMP®
Solid sizes 1
0.2 … 1.5 mm² / 24 … 16 AWG
Fine-stranded wires 1
Fine-stranded wires with insulated ferrule 1
0.25 … 1 mm² / …
Fine-stranded wires with uninsulated ferrule 1
0.25 … 1 mm² / …
Strip length 1
9 … 10 mm / 0.35 … 0.39 in
Type of wiring
Side-entry wiring
Solder pin arrangement
staggered solder pin
Solder pin length [mm]
3.2 [mm]
Solder pin width A [mm]
0.5 [mm]
Solder pin width B [mm]
0.75 [mm]
Tolerance of drilled hole [mm]
1.1(+ 0.1) [mm]
Material group
I
Insulating material
Polyamide 46 (PA 46)
Flammability rating per UL 94
V0
Limit temperature range
-60 C … 105 C
Clamping spring material
Chrome-nickel spring steel (CrNi)
2
Technical data
Contact material
Electrolytic copper (Ecu)
Contact plating
tin-plated
Fire load [MJ]
0.032 [MJ]
Weight [g]
1.482 [g]
Width
12 mm / 0.472 in
Height
13.7 mm / 0.539 in
Height from the surface
10.5 mm / 0.413 in
Length
13.6 mm / 0.535 in
3
Images & drawings
4
5
Address
Hansastr. 27
32423 Minden
Telefon: 0571/887-0
Fax: 0571/887-169
http://www.wago.com
© WAGO Kontakttechnik GmbH & Co. KG
Technische Änderungen und Irrtümer vorbehalten.
6
很抱歉,暂时无法提供与“805-103”相匹配的价格&库存,您可以联系我们找货
