852-1111
852-1111
    WAGO(万可电子)
    网络 开关 5 个端口 IP30
852-1111 数据手册
Data sheet  |  Item number: 852-1111 Industrial-ECO-Switch; 5-port 1000Base-T; black www.wago.com/852-1111 Color: 06.11.2019    Page 1/7 Data sheet  |  Item number: 852-1111 www.wago.com/852-1111 Item description The 852-1111 is a 5-port 1000Base-T industrial ETHERNET switch supporting Auto-Negotiation and Auto-MDI-/MDI-X detection for each port. Using the switch's 5 ports, several segments can be created to reduce the network load, while providing a dedicated bandwidth to each user node. The 852-1111 Switch is a cost-effect solution to keep up with the constant demands of IP-based, industrial communication needs. The switch is easy to configure and install and is best suited for small to medium-sized networks. Features: 5 ETHERNET Ports, 10/100/1000 Mbps autonegotiation Front-panel diagnostic LEDs Supports Auto-MDI/MDI-X functions Full/half-duplex transfer modes for each port Store-and-forward switching method Integrated address look-up table, supports up to 8000 absolute MAC addresses Overvoltage protection IEEE 802.3x flow control in full-duplex mode Prioritization of Profinet Ethernet Frame (EtherType=0x8892) according to IEEE802.1p DIN-35 rail mounting 06.11.2019    Page 2/7 Data sheet  |  Item number: 852-1111 www.wago.com/852-1111 Data Technical Data Switchingmodus Store‐and‐forward, non-blocking Number of 1000Base-T ports 5 Communication standards IEEE 802.3 10BASE-T IEEE 802.3u 100BASE-TX IEEE 802.3ab 1000BASE-T IEEE 802.3x Flow Control IEEE 802.1p Prioritization MAC table (large) 8000 addresses Jumbo frame size 9000 Byte Supply voltage DC 9 … 48 V Energy consumption max. 3  W Baud rate Copper cable: 10/1000 Mbit/s Transmission medium (communication/fieldbus) Copper cable: Cat. 5 or higher, max. line length: 100 m Topology Star Indicators Device: LED (PWR) green: Power supply; per port: LED (100, 1000) green: Status 100 Mbps, 1000 Mbps port 1 … 5 Connection data Connection technology: communication/fieldbus Copper cable: 5 x RJ-45 Anschlusstechnik: Versorgung 1 x im Gerät verbaute Stiftleiste: 231-433/001-000; mitgelieferte Federleiste (Steckverbinder MCS): 231-103/026-000 Geometrical Data Width 23.4 mm / 0.921 inch Height from upper-edge of DIN-35 rail 81 mm / 3.189 inch Depth 109.2 mm / 4.299 inch Mechanical data Weight 190 Color black Housing material Sheet steel Conformity marking CE Environmental Requirements Surrounding air (operating) temperature -40 … 70 °C Surrounding air (storage) temperature -40 … 80 °C Protection class IP30 Relative air humidity (no condensation) 95 % Type of mounting DIN-35 rail 06.11.2019    Page 3/7 Data sheet  |  Item number: 852-1111 www.wago.com/852-1111 Type of mounting DIN-35 rail Vibration resistance acc. to IEC 60068-2-6 Shock resistance acc. to IEC 60068-2-27 Commercial data Product Group 27 (Special components I/O) Packaging type BOX Country of origin TW GTIN 4050821808916 Customs Tariff No. 85176200000 Compatible products wiring and connectors Item no.: 750-975 ETHERNET RJ-45 connector, IP20; ETHERNET 10/100 Mbit/s; for field assembly; light gray www.wago.com/750-975 Item no.: 750-976 PROFINET RJ-45 connector, IP20; ETHERNET 10/100 Mbit/s; for field assembly www.wago.com/750-976 Item no.: 750-977/000-011 Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568A; AWG 22 www.wago.com/750-977 /000-011 Item no.: 750-977/000-012 Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568B; AWG 22 www.wago.com/750-977 /000-012 Item no.: 750-977/000-013 Connector PROFINET; RJ-45; Cat. 6A; straight; AWG 22 www.wago.com/750-977 /000-013 Item no.: 750-977/000-021 Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568A; AWG 24 www.wago.com/750-977 /000-021 Item no.: 750-977/000-022 Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568B; AWG 24 www.wago.com/750-977 /000-022 Item no.: 750-978/000-011 Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568A; AWG 22; Strain relief www.wago.com/750-978 /000-011 Item no.: 750-978/000-012 Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568B; AWG 22; Strain relief www.wago.com/750-978 /000-012 Item no.: 750-978/000-013 www.wago.com/750-978 06.11.2019    Page 4/7 Data sheet  |  Item number: 852-1111 www.wago.com/852-1111 Item no.: 750-978/000-013 Connector PROFINET; RJ-45; Cat. 6A; straight; AWG 22; Strain relief www.wago.com/750-978 /000-013 Item no.: 750-978/000-021 Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568A; AWG 24; Strain relief www.wago.com/750-978 /000-021 Item no.: 750-978/000-022 Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568B; AWG 24; Strain relief www.wago.com/750-978 /000-022 Item no.: 750-979/000-011 Connector ETHERNET; RJ-45; Cat. 6A; angled; Code T568A; AWG 22; Strain relief www.wago.com/750-979 /000-011 Item no.: 750-979/000-012 Connector ETHERNET; RJ-45; Cat. 6A; angled; Code T568B; AWG 22; Strain relief www.wago.com/750-979 /000-012 Item no.: 750-979/000-013 Connector PROFINET; RJ-45; Cat. 6A; angled; AWG 22; Strain relief www.wago.com/750-979 /000-013 Item no.: 750-979/000-021 Connector ETHERNET; RJ-45; Cat. 6A; angled; Code T568A; AWG 24; Strain relief www.wago.com/750-979 /000-021 Item no.: 750-979/000-022 Connector ETHERNET; RJ-45; Cat. 6A; angled; Code T568B; AWG 24; Strain relief www.wago.com/750-979 /000-022 power supply Item no.: 787-1102 Switched-mode power supply; Compact; 1-phase; 24 VDC output voltage; 1.3 A output current; DC OK www.wago.com/787-1102 signal Item no.: 787-1112 Switched-mode power supply; Compact; 1-phase; 24 VDC output voltage; 2.5 A output current; DC OK www.wago.com/787-1112 signal Item no.: 787-1122 Switched-mode power supply; Compact; 1-phase; 24 VDC output voltage; 4 A output current; DC OK signal www.wago.com/787-1122 Item no.: 787-1226 Switched-mode power supply; Compact; 1-phase; 24 VDC output voltage; 6 A output current www.wago.com/787-1226 Item no.: 787-1702 Switched-mode power supply; Eco; 1-phase; 24 VDC output voltage; 1.25 A output current www.wago.com/787-1702 Item no.: 787-1712 Switched-mode power supply; Eco; 1-phase; 24 VDC output voltage; 2.5 A output current www.wago.com/787-1712 Item no.: 787-1722 Switched-mode power supply; Eco; 1-phase; 24 VDC output voltage; 5 A output current www.wago.com/787-1722 transfer module Item no.: 289-172 Interface module; RJ-45; RJ-45; Cat. 5; in mounting carrier www.wago.com/289-172 Item no.: 289-175 06.11.2019    Page 5/7 Data sheet  |  Item number: 852-1111 www.wago.com/852-1111 Item no.: 289-175 Interface module; RJ-45; PCB terminal blocks, double-row; Cat. 5; in mounting carrier; with shield connection; with shield clamping saddle; 1,50 mm² www.wago.com/289-175 Item no.: 289-195 Interface module; RJ-45; IDC technology; Cat. 6; in mounting carrier; with shield connection www.wago.com/289-195 Item no.: 289-196 Interface module; RJ-45; with power jumper contacts; PCB terminal blocks; Cat. 5 www.wago.com/289-196 General accessories Item no.: 852-9101 DNV Carrier rail adapter; for ETHERNET Switches 852-111/ 852-1111 marine approval; - www.wago.com/852-9101 Downloads Documentation Manual 5-Port 1000BASE-T Industrial ECO Switch V 1.3.0 pdf 332.8 kB Download V 1.0.0 pdf 265.8 kB Download pdf 2.0 MB Download URL Download Additional Information Disposal; Electrical and electronic equipment, Packaging System Description Industrial Switches ‒ General Product Information CAD/CAE-Data CAD data 2D/3D Models 852-1111 CAE data EPLAN Data Portal 852-1111 Download WSCAD Universe 852-1111 Download 06.11.2019    Page 6/7 Data sheet  |  Item number: 852-1111 www.wago.com/852-1111 Installation Notes   Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 06.11.2019    Page 7/7
852-1111 价格&库存
很抱歉,暂时无法提供与“852-1111”相匹配的价格&库存,您可以联系我们找货
