Data sheet | Item number: 870-831
4-conductor through terminal block; 2.5 mm²; side and center marking; for
DIN-rail 35 x 15 and 35 x 7.5; CAGE CLAMP®
www.wago.com/870-831
Color:
Item description
Safety information 1:
Max. insulation diameter: 4.4mm
29.03.2019 Page 1/11
Data
Electrical data
Ratings per IEC/EN 60664-1
Rated voltage (III / 3)
500 V
Rated impulse voltage (III / 3)
6 kV
Rated current
24 A
Connection data
Connection technology
CAGE CLAMP®
Actuation type
Operating tool
Connectable conductor materials
Copper
Solid conductor
0.08 … 2.5 mm² / 28 … 12 AWG
Fine-stranded conductor
0.08 … 4 mm² / 28 … 12 AWG
Strip length
6 … 7 mm / 0.24 … 0.28 inch
Total number of connection points
4
Total number of potentials
1
Number of levels
1
Type of wiring
Front-entry wiring
Leiterquerschnitte eindrähtig
0.08 mm²
Geometrical Data
Width
5 mm / 0.197 inch
Height from upper-edge of DIN-35 rail
27.5 mm / 1.083 inch
Depth
55 mm / 2.165 inch
Plug width
5 mm / 0.197 inch
Mechanical data
Design
horizontal
Type of mounting
DIN-35 rail
Marking level
Side marking
Material Data
Color
gray
Insulating material
Polyamide 66 (PA 66)
Fire load
0.118 MJ
Weight
7.33 g
Commercial data
29.03.2019 Page 2/11
Commercial data
Product Group
16 (Rail Mounted Terminal Block with CCC)
Country of origin
DE
GTIN
4045454094621
Approvals / Certificates
Country specific Approvals
Logo
Certificate
name
Approval
Additional Approval Text
CCA
DEKRA Certification B.V.
EN 60947
NTR NL
7468
CCA
EN 60947
2189801.01
Approval
ABS
American Bureau of Shipping
14HG1293677PDA
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE00001V2
LR
Lloyds Register
EN 60947
91/20112
(E9)
Ship Approvals
Logo
Certificate
name
UL-Approvals
Logo
Approval
cURus
UL International Germany GmbH
UL 1059
Certificate
name
20160928E45172
Compatible products
29.03.2019 Page 3/11
tools
Item no.: 210-657
Operating tool with partially insulated shaft; Blade (3.5 x 0.5) mm; short
www.wago.com/210-657
Item no.: 210-658
Operating tool with partially insulated shaft; Blade (3.5 x 0.5) mm; short; angled
www.wago.com/210-658
Item no.: 210-720
Operating tool with partially insulated shaft; Type 2, blade (3.5 x 0.5) mm
www.wago.com/210-720
Carrier rail
Item no.: 210-112
www.wago.com/210-112
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm
Item no.: 210-113
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715
www.wago.com/210-113
Item no.: 210-114
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715
www.wago.com/210-114
Item no.: 210-115
www.wago.com/210-115
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm
Item no.: 210-118
Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715
www.wago.com/210-118
Item no.: 210-196
Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715
www.wago.com/210-196
Item no.: 210-197
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715
www.wago.com/210-197
Item no.: 210-198
Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715
www.wago.com/210-198
Item no.: 210-504
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715
www.wago.com/210-504
Item no.: 210-505
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715
www.wago.com/210-505
Item no.: 210-506
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715
www.wago.com/210-506
Item no.: 210-508
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715
www.wago.com/210-508
Marking accessories
Item no.: 2009-115
WMB-Inline; for smartPRINTER; on reel; stretchable 5 - 5.2 mm; plain; snap-on type
www.wago.com/2009-115
29.03.2019 Page 4/11
Item no.: 2009-115/000-002
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type
/000-002
Item no.: 2009-115/000-006
/000-006
Item no.: 2009-115/000-007
/000-007
Item no.: 2009-115/000-012
/000-012
Item no.: 2009-115/000-017
/000-017
Item no.: 2009-115/000-023
/000-023
Item no.: 2009-115/000-024
/000-024
Item no.: 2009-145
Mini-WSB Inline; for smartPRINTER; on reel; stretchable 5 - 5.2 mm; plain; snap-on type
www.wago.com/2009-145
Item no.: 2009-145/000-002
/000-002
Item no.: 2009-145/000-005
/000-005
Item no.: 2009-145/000-006
/000-006
Item no.: 2009-145/000-007
/000-007
Item no.: 2009-145/000-012
/000-012
Item no.: 2009-145/000-023
/000-023
Item no.: 2009-145/000-024
/000-024
29.03.2019 Page 5/11
Item no.: 248-501
Miniature WSB Quick marking system; plain; Marker width 5 mm; 10 strips with 10 markers per card
www.wago.com/248-501
Item no.: 248-501/000-002
Mini-WSB marking card; as card; not stretchable; plain; snap-on type
/000-002
Item no.: 248-501/000-005
Mini-WSB marking card; as card; plain; snap-on type
/000-005
Item no.: 248-501/000-006
/000-006
Item no.: 248-501/000-007
/000-007
Item no.: 248-501/000-012
/000-012
Item no.: 248-501/000-017
/000-017
Item no.: 248-501/000-023
/000-023
Item no.: 248-501/000-024
/000-024
Item no.: 709-177
Marking strips; on reel; 7.5 mm wide; not stretchable; plain; snap-on type
www.wago.com/709-177
Item no.: 709-178
www.wago.com/709-178
Item no.: 709-196
Marking strips; for laser printer
www.wago.com/709-196
Item no.: 709-198
Marking strips
www.wago.com/709-198
Item no.: 793-501
WMB marking card; as card; not stretchable; plain; snap-on type
www.wago.com/793-501
Item no.: 793-501/000-002
/000-002
Item no.: 793-501/000-005
/000-005
Item no.: 793-501/000-006
29.03.2019 Page 6/11
/000-006
Item no.: 793-501/000-007
/000-007
Item no.: 793-501/000-012
/000-012
Item no.: 793-501/000-017
/000-017
Item no.: 793-501/000-023
/000-023
Item no.: 793-501/000-024
/000-024
Item no.: 793-5501
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501
type
Item no.: 793-5501/000-002
/000-002
type
Item no.: 793-5501/000-005
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type
/000-005
Item no.: 793-5501/000-006
/000-006
Item no.: 793-5501/000-007
/000-007
Item no.: 793-5501/000-012
/000-012
Item no.: 793-5501/000-017
/000-017
Item no.: 793-5501/000-023
/000-023
Item no.: 793-5501/000-024
/000-024
General accessories
29.03.2019 Page 7/11
General accessories
Item no.: 870-182
Adaptor
www.wago.com/870-182
Item no.: 870-183
Adaptor
www.wago.com/870-183
Item no.: 870-184
Adaptor
www.wago.com/870-184
Item no.: 870-425
Tap-off module; with anti-rotation protection; modular; suitable for 870 Series terminal blocks with
jumper slots in the current bar
www.wago.com/870-425
Item no.: 870-426
Tap-off module; modular; suitable for 870 Series terminal blocks with jumper slots in the current bar
www.wago.com/870-426
Item no.: 870-427
Spacer module; modular; bridging commoned terminal blocks
www.wago.com/870-427
Item no.: 209-106
Mounting carrier; for isolated mounting on DIN 35 rails
www.wago.com/209-106
Item no.: 249-116
Screwless end stop; 6 mm wide
www.wago.com/249-116
Item no.: 249-117
Screwless end stop; 10 mm wide
www.wago.com/249-117
assembling
Insulation stop
Item no.: 280-470
Insulation stop; 0.08 - 0.2 mm² "s" (0.14 mm² "f-st"); 5 pieces/strip
www.wago.com/280-470
Item no.: 280-471
Insulation stop; 0.25 - 0.5 mm²; 5 pieces/strip
www.wago.com/280-471
Item no.: 280-472
Insulation stop; 0.75 - 1 mm²; 5 pieces/strip
www.wago.com/280-472
Item no.: 709-110
Wire commoning chain; insulated; 4 connections; 3 x 110 mm
www.wago.com/709-110
Item no.: 709-111
Wire commoning chain; insulated; 3 connections; 2 x 120 mm
www.wago.com/709-111
Item no.: 709-112
Wire commoning chain; insulated; 3 connections; 2 x 170 mm
www.wago.com/709-112
Item no.: 870-402
Push-in type jumper bar; insulated; 2-way; Nominal current 18 A
www.wago.com/870-402
Item no.: 870-403
Push-in type jumper bar; insulated; 3-way; Nominal current 18 A
www.wago.com/870-403
Item no.: 870-404
Push-in type jumper bar; insulated; 4-way; Nominal current 18 A
www.wago.com/870-404
Jumper
Item no.: 870-405
29.03.2019 Page 8/11
Item no.: 870-405
Push-in type jumper bar; insulated; 5-way; Nominal current 18 A
www.wago.com/870-405
Item no.: 870-405/011-000
Ready-made push-in type jumper bar; insulated; 3-way (1-3-5); Nominal current 18 A
/011-000
Item no.: 870-406
Push-in type jumper bar; insulated; 6-way; Nominal current 18 A
www.wago.com/870-406
Item no.: 870-407
Push-in type jumper bar; insulated; 7-way; Nominal current 18 A
www.wago.com/870-407
Item no.: 870-407/011-000
/011-000
Item no.: 870-408
Push-in type jumper bar; insulated; 8-way; Nominal current 18 A
www.wago.com/870-408
Item no.: 870-409
Push-in type jumper bar; insulated; 9-way; Nominal current 18 A
www.wago.com/870-409
Item no.: 870-409/011-000
/011-000
Item no.: 870-410
Push-in type jumper bar; insulated; 10-way; Nominal current 18 A
www.wago.com/870-410
Item no.: 870-433
Push-in type jumper bar; insulated; from 1 to 3; Nominal current 18 A
www.wago.com/870-433
Item no.: 870-434
Push-in type jumper bar; insulated; from 1 to 4; Nominal current 18 A
www.wago.com/870-434
Item no.: 870-435
Push-in type jumper bar; insulated; from 1 to 5; Nominal current 18 A
www.wago.com/870-435
Item no.: 870-436
Push-in type jumper bar; insulated; from 1 to 6; Nominal current 18 A
www.wago.com/870-436
Item no.: 870-437
Push-in type jumper bar; insulated; from 1 to 7; Nominal current 18 A
www.wago.com/870-437
Item no.: 870-438
Push-in type jumper bar; insulated; from 1 to 8; Nominal current 18 A
www.wago.com/870-438
Item no.: 870-439
Push-in type jumper bar; insulated; from 1 to 9; Nominal current 18 A
www.wago.com/870-439
Item no.: 870-440
Push-in type jumper bar; insulated; from 1 to 10; Nominal current 18 A
www.wago.com/870-440
Protective Warning Marker
Item no.: 280-405
Protective warning marker; with high-voltage symbol, black; for 5 terminal blocks
www.wago.com/280-405
ferrule
Item no.: 216-121
29.03.2019 Page 9/11
Item no.: 216-121
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated
www.wago.com/216-121
Item no.: 216-122
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated
www.wago.com/216-122
Item no.: 216-123
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated
www.wago.com/216-123
Item no.: 216-124
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated
www.wago.com/216-124
Item no.: 216-131
Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-131
Item no.: 216-132
Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-132
Item no.: 216-221
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated
www.wago.com/216-221
Item no.: 216-222
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated
www.wago.com/216-222
Item no.: 216-223
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated
www.wago.com/216-223
Item no.: 216-224
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated
www.wago.com/216-224
Item no.: 216-321
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated
www.wago.com/216-321
Item no.: 216-322
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated
www.wago.com/216-322
Item no.: 870-943
End and intermediate plate; 1 mm thick
www.wago.com/870-943
Item no.: 870-944
www.wago.com/870-944
Item no.: 870-948
Separator plate; 1 mm thick
www.wago.com/870-948
Item no.: 870-949
www.wago.com/870-949
End plate
Downloads
CAD files
CAD data
3D Download 870-831
URL
Download
29.03.2019 Page 10/11
Subject to changes.
WAGO Corporation
Germantown, WI 53022
Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222
Email: info.us@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at {0}.
29.03.2019 Page 11/11
很抱歉,暂时无法提供与“870-831”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+47.758491+6.18640
