870-911
870-911
    WAGO(万可电子)
    端子块连接器 2 位置 馈通式 灰色 12-28 AWG
870-911 数据手册
Data sheet from 19.01.2012 Item no.: 870-911 Product description: 2-Conductor through terminal block Produkt kann von Bild abweichen / product may differ Packing unit 100 pieces RoHS compliant Product group 16 (RAIL MOUNTED TERMINAL BLOCK WITH CCC) Cross section [mm²] 0.08 - 2.5 mm² Cross section [AWG] 28 - 14 AWG Wiring method s + f-st Connection method CAGE CLAMP®COMPACT CONNECTION Cross section [mm²] 0.08 - 4 mm² Cross section [AWG] 28 - 12 AWG Wiring method f Connection method CAGE CLAMP®COMPACT CONNECTION Measured voltage EN 500 V Measured shock voltage 6 kV Pollution degree 3 Current intensity EN 24 A Weight 4.081 g Color grey Wiring type Front-entry No. of connection Points 2 No. of potentials 1 Height 1 von 4 26.5 mm Height 1.04 in Width 5 mm Width 0.197 in 2 von 4 Data sheet from 19.01.2012 Depth 34.5 mm Depth 1.36 in Strip length from 6 mm Strip length to 7 mm Strip length 0.26 in Mounting TS 15 3 von 4 Data sheet from 19.01.2012 Item number Admission office Approval no. Voltage [V] Current [A] Cross section [ mm² ] 870-911 cURus E45172 300 20 28-12 Sorting criteria: admission office - approval number © WAGO Kontakttechnik GmbH & Co. KG Specifications are subject to changes and errors may be expected 4 von 4
870-911 价格&库存
很抱歉,暂时无法提供与“870-911”相匹配的价格&库存,您可以联系我们找货
  • 1+31.476401+4.07730
    库存:25
